[Swift-commit] r3797 - trunk/docs
noreply at svn.ci.uchicago.edu
Mon Dec 13 22:00:44 CST 2010
Author: skenny
Date: 2010-12-13 22:00:44 -0600 (Mon, 13 Dec 2010)
New Revision: 3797
Modified:
trunk/docs/userguide.xml
Log:
documented using shell wrapper instead of individual entries in tc.data
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml 2010-12-14 01:53:43 UTC (rev 3796)
+++ trunk/docs/userguide.xml 2010-12-14 04:00:44 UTC (rev 3797)
@@ -3611,12 +3611,15 @@
<para>Some example entries:
<screen>
localhost echo /bin/echo INSTALLED INTEL32::LINUX null
+localhost touch /bin/touch INSTALLED INTEL32::LINUX null
TGUC touch /usr/bin/touch INSTALLED INTEL32::LINUX GLOBUS::maxwalltime="0:1"
+TGUC R /usr/bin/R INSTALLED INTEL32::LINUX env::R_LIBS=/home/skenny/R_libs
</screen>
</para>
<para>
The fields are: site, transformation name, executable path, installation
-status, platform, and profile entrys.
+status, platform, and profile entries.
</para>
<para>
The site field should correspond to a site name listed in the sites
@@ -3637,7 +3640,29 @@
The profiles field should be set to <literal>null</literal> if no profile entries are to be
specified, or should contain the profile entries separated by semicolons.
</para>
+ <section id="transformationcatalog.shell_invocation"><title>shell invocation</title>
+ <para>
+Because the above implementation requires an entry for each executable on a given site, it is often preferable to simply have a single element for each site in the transformation catalog representing a wrapper that sets the environment and then invokes the shell to call a given application. This wrapper is installed on the site and can be used to set the <literal>PATH</literal> and other environment variables prior to invoking the shell so that each executable need not be entered in the <literal>tc.data</literal> file.
+ </para>
+ <para>for example, the entries for <literal>TGUC</literal> and <literal>localhost</literal> can now each be collapsed into a single line:
+<screen>
+localhost shell /usr/local/bin/swiftshell INSTALLED INTEL32::LINUX null
+TGUC shell /usr/local/bin/swiftshell INSTALLED INTEL32::LINUX null
+</screen>
+where <literal>swiftshell</literal> sets up the users's environment so that all the installed applications are added to the <literal>PATH</literal> before the application is invoked.
+ </para>
+<para>
+<literal>touch</literal> would now be called in the SwiftScript like this:
+<screen>
+app (file tout) shelltest(){
+ shell "touch" @filename(tout);
+</screen>
+</para>
+ </section>
</section>
<section id="buildoptions"><title>Build options</title>
<para>
See <ulink url="http://www.ci.uchicago.edu/swift/downloads/">the
More information about the Swift-commit
