[Swift-commit] r3788 - in www: . docs
Mon Dec 13 15:56:02 CST 2010
Author: wozniak
Date: 2010-12-13 15:56:02 -0600 (Mon, 13 Dec 2010)
New Revision: 3788
Modified:
   www/docs/index.php
   www/update.sh
Log:
Enable second userguide links
Modified: www/docs/index.php
--- www/docs/index.php	2010-12-13 21:53:52 UTC (rev 3787)
+++ www/docs/index.php	2010-12-13 21:56:02 UTC (rev 3788)
@@ -67,6 +67,12 @@
 	information on swift. It is assumed that the reader is already familiar with
 	the material in the Quickstart and Tutorial documents.
 </p>
+	<li><strong>current</strong>
+          [<a href="../guides/release-0.91/userguide/">multi-page html</a>]
+          [<a href="../guides/userguide.php">single-page html</a>]
+          [<a href="../guides/userguide.pdf"
+              onClick="javascript: pageTracker._trackPageview('/swift/guides/userguide.pdf');">pdf</a>]
+        </li>
 	<li><strong>trunk</strong>
           [<a href="../guides/trunk/userguide/">multi-page html</a>]
Modified: www/update.sh
--- www/update.sh	2010-12-13 21:53:52 UTC (rev 3787)
+++ www/update.sh	2010-12-13 21:56:02 UTC (rev 3788)
@@ -1,24 +1,36 @@
 #!/bin/sh
+update_docs()
+  DIR=$1
+  echo "--------- Updating docs: ${DIR} ----------"
+  pushd ${DIR}
+  svn update
+  chmod -R g+w .svn 2>/dev/null
+  chmod -R g+w formatting/.svn 2>/dev/null
+  chmod a+rx . userguide
+  pushd userguide
+  popd
+  ./buildguides.sh
+  chmod g+w *.php
+  chmod g+w *.pdf
+  chmod -R g+w userguide
+  popd
+  return 0
 umask 002
 echo "--------- Updating www...  ----------"
 svn update
 chmod a+r docs/index.php
 echo "--------- Updating docs... ----------"
-echo "--------- Updating docs: trunk... ----------"
-pushd guides/trunk
-svn update
-chmod -R g+w .svn 2>/dev/null
-chmod -R g+w formatting/.svn 2>/dev/null
-chmod a+rx . userguide
-pushd userguide
-popd
-./buildguides.sh
-chmod g+w *.php
-chmod g+w *.pdf
-chmod -R g+w userguide
-popd
+for SET in guides/trunk guides/release-0.91
+do
+  update_docs ${SET}
+done
 echo "---------     All done     ----------"
