[Swift-commit] r3774 - trunk/docs/formatting
    noreply at svn.ci.uchicago.edu
    Mon Dec 13 15:08:04 CST 2010
Author: wozniak
Date: 2010-12-13 15:08:04 -0600 (Mon, 13 Dec 2010)
New Revision: 3774
Modified:
   trunk/docs/formatting/swiftsh_html_chunked.xsl
Log:
Clean whitespace
Modified: trunk/docs/formatting/swiftsh_html_chunked.xsl
--- trunk/docs/formatting/swiftsh_html_chunked.xsl	2010-12-13 21:06:47 UTC (rev 3773)
+++ trunk/docs/formatting/swiftsh_html_chunked.xsl	2010-12-13 21:08:04 UTC (rev 3774)
@@ -10,29 +10,29 @@
 	<!--<xsl:import href="http://docbook.sourceforge.net/release/xsl/current/html/chunk.xsl"/>-->
 		testing: if you want to generate your own html without installing
-		stylesheets, substitute the following url for the import href above:
+		stylesheets, substitute the following url for the import href above:
 	<!-- speed up the chunking process? -->
 	<xsl:param name="chunk.fast">1</xsl:param>
-		Use graphics in admonitions? like 'warnings' 'important' 'note' etc
+		Use graphics in admonitions? like 'warnings' 'important' 'note' etc
 	<xsl:param name="admon.graphics">1</xsl:param>
 	<!-- Set path to admonition graphics  -->
 	<xsl:param name="admon.graphics.path">/docbook-images/</xsl:param>
 		Set path to docbook graphics (testing)
-        <xsl:param name="admon.graphics.path">file:///Z:/testing/alliance/docbook-images/</xsl:param>
+        <xsl:param name="admon.graphics.path">file:///Z:/testing/alliance/docbook-images/</xsl:param>
-		Again, if 1 above, what is the filename extension for admon graphics?
+		Again, if 1 above, what is the filename extension for admon graphics?
 	<xsl:param name="admon.graphics.extension" select="'.gif'"/>
 	<!-- Set path to callout graphics -->
@@ -42,10 +42,10 @@
 	<xsl:param name="chunk.section.depth">0</xsl:param>
 		Are parts automatically enumerated?
-		<xsl:param name="part.autolabel">0</xsl:param>
+		<xsl:param name="part.autolabel">0</xsl:param>
 	<!-- Are chapters automatically enumerated? -->
 	<xsl:param name="chapter.autolabel">0</xsl:param>
@@ -54,7 +54,7 @@
 	<!-- how deep should each toc be? (how many levels?) -->
 	<xsl:param name="toc.max.depth">2</xsl:param>
-		How deep should recursive sections appear in the TOC for chapters?
+		How deep should recursive sections appear in the TOC for chapters?
 	<xsl:param name="toc.section.depth">4</xsl:param>
@@ -62,18 +62,18 @@
 	<xsl:param name="chunk.first.sections">1</xsl:param>
-		Instead of using default filenames, use ids for filenames (dbhtml
+		Instead of using default filenames, use ids for filenames (dbhtml
 		directives take precedence) taking this out to avoid breaking any
 		current bookmarks
                 <xsl:param name="use.id.as.filename">1</xsl:param>
 	<!-- custom toc - book only shows chapter -->
 	<xsl:template match="preface|chapter|appendix|article" mode="toc">
 		<xsl:param name="toc-context" select="."/>
 		<xsl:choose>
 			<xsl:when test="local-name($toc-context) = 'book'">
 				<xsl:call-template name="subtoc">
@@ -99,49 +99,49 @@
 	<xsl:param name="glossentry.show.acronym">yes</xsl:param>
 		Name of the glossary collection file
 		<xsl:param name="glossary.collection" select="'glossary.xml'"></xsl:param>
 		Generate links from glossterm to glossentry automatically?
 		<xsl:param name="glossterm.auto.link">1</xsl:param>
 		if non-zero value for previous parameter, does automatic glossterm
 		linking only apply to firstterms?
-		<xsl:param name="firstterm.only.link">1</xsl:param>
+		<xsl:param name="firstterm.only.link">1</xsl:param>
 		permit wrapping of long lines of code
-		<xsl:attribute-set name="monospace.verbatim.properties"
+		<xsl:attribute-set name="monospace.verbatim.properties"
 			use-attribute-sets="verbatim.properties monospace.properties">
 			<xsl:attribute name="wrap-option">wrap</xsl:attribute>
-		</xsl:attribute-set>
+		</xsl:attribute-set>
 	<!-- INCORPORATING DOCBOOK PAGES INTO WEBSITE -->
-		make sure there's a DOCTYPE in the html output (otherwise, some css renders strangely
+		make sure there's a DOCTYPE in the html output (otherwise, some css renders strangely
 	<xsl:param name="chunker.output.doctype-public" select="'-//W3C//DTD HTML 4.01 Transitional//EN'"/>
 	<xsl:param name="chunker.output.doctype-system" select="'http://www.w3.org/TR/html4/loose.dtd'"/>
 	<!-- add elements to the HEAD tag -->
-	<xsl:template name="user.head.content">
+	<xsl:template name="user.head.content">
 		<link href="http://www.ci.uchicago.edu/swift/css/style1col.css" rel="stylesheet" type="text/css"/>
 		<script type="text/javascript" src="http://www.ci.uchicago.edu/swift/dhtml.js"></script>
 		<script type="text/javascript" src="http://www.ci.uchicago.edu/swift/shCoreu.js"></script>
@@ -165,7 +165,7 @@
 		<xsl:param name="content">
 			<xsl:apply-imports/>
 		</xsl:param>
 		<xsl:call-template name="user.preroot"/>
 		<html>
@@ -186,9 +186,9 @@
       </xsl:call-template>
 				<xsl:call-template name="user.header.content"/>
-				<xsl:call-template name="breadcrumbs" />
+				<xsl:call-template name="breadcrumbs" />
 				<xsl:copy-of select="$content"/>
 				<xsl:call-template name="user.footer.content"/>
       <xsl:call-template name="footer.navigation">
@@ -213,7 +213,7 @@
 	</xsl:template>
-		prevent h1 and h2 using clear: both - want to control in css, instead
+		prevent h1 and h2 using clear: both - want to control in css, instead
 	<xsl:template name="section.heading">
@@ -231,14 +231,14 @@
 				</xsl:attribute>
 			</a>
 			<xsl:copy-of select="$title"/>
 		</xsl:element>
 	</xsl:template>
 	<xsl:template name="user.header.navigation">
 		<xsl:text disable-output-escaping="yes"><![CDATA[
 		<!-- entire page container -->
 		<div id="container">
 			<!-- header -->
@@ -256,13 +256,13 @@
 		</xsl:text>
 	</xsl:template>
 	<xsl:template name="user.footer.content">
 			</div>
 			<!-- end content container-->
 			<!-- footer -->
-			<div id="footer"><?php require('../../inc/footer.php') ?></div>
+			<div id="footer"><?php require('../../inc/footer.php') ?></div>
 			<!-- end footer -->
 		</div>
More information about the Swift-commit
