[Swift-commit] r3770 - trunk/tests
Mon Dec 13 11:54:26 CST 2010
Author: wozniak
Date: 2010-12-13 11:54:26 -0600 (Mon, 13 Dec 2010)
New Revision: 3770
Modified:
   trunk/tests/nightly.sh
Log:
Minor improvements to run on Intrepid
Modified: trunk/tests/nightly.sh
--- trunk/tests/nightly.sh	2010-12-13 17:46:18 UTC (rev 3769)
+++ trunk/tests/nightly.sh	2010-12-13 17:54:26 UTC (rev 3770)
@@ -15,6 +15,8 @@
 # Everything for a Swift test is written in its RUNDIR
 # The temporary output always goes to OUTPUT (TOPDIR/exec.out)
+# Note that some schedulers restrict your choice of RUNDIR
 # Each *.swift test may be accompanied by a
 # *.setup.sh, *.check.sh, and/or *.clean.sh script
 # and a *.timeout specifier
@@ -44,6 +46,9 @@
 # PID TREE:
 # Background processes are used so that hung Swift jobs can be killed
 # These are the background processes (PIDs are tracked)
+# Note that PID management has not yet been perfected.  Check ps
+# in error cases.
 # nightly.sh
 # +-monitor()
 #   +-sleep
@@ -172,6 +177,18 @@
   fi
+# Ensure all given variables are set
+checkvars() {
+  while (( ${#*} ))
+   do
+   VAR=$1
+   V=$( eval "echo \${${VAR}+1}" )
+   [[ $V == 1 ]] || crash "Not set: $VAR"
+   shift
+  done
+  return 0
 crash() {
   MSG=$1
   echo $MSG
@@ -568,7 +585,21 @@
 test_exec() {
   banner "$TEST (part $SEQ)"
   echo "Executing $TEST (part $SEQ)"
-  process_exec "$@"
+  pwd
+  printf "\nExecuting: $@" >>$LOG
+  rm -f $OUTPUT
+  "$@" > $OUTPUT 2>&1
+  EXITCODE=$?
+  if [ "$EXITCODE" == "127" ]; then
+    echo "Command not found: $@" > $OUTPUT
+  fi
+  if [ -f $OUTPUT ]; then
+    cat $OUTPUT >> $LOG
+  fi
   RESULT=$( result )
   test_log
   out test $SEQ "$LASTCMD" $RESULT $TEST_LOG
@@ -576,6 +607,7 @@
   check_bailout
   let "SEQ=$SEQ+1"
+  return $EXITCODE
 # Background process monitoring function
@@ -761,6 +793,18 @@
   out package "swift-$DATE.tar.gz"
+# Environment must contain PROJECT, QUEUE, and WORK
+make_sites_sed() {
+  checkvars WORK QUEUE PROJECT
+    echo "s at _WORK_@$WORK@"
+    echo "s at _HOST_@$GLOBUS_HOSTNAME@"
+    echo "s at _PROJECT_@$PROJECT@"
+    echo "s at _QUEUE_@$QUEUE@"
+  } > $RUNDIR/sites.sed
+  return 0
 if which ifconfig > /dev/null; then
   IFCONFIG=ifconfig
 else
@@ -770,10 +814,11 @@
 GLOBUS_HOSTNAME=$( $IFCONFIG | grep inet | head -1 | cut -d ':' -f 2 | \
                    awk '{print $1}' )
 [ $? != 0 ] && crash "Could not obtain GLOBUS_HOSTNAME!"
 group_sites_xml() {
   TEMPLATE=$GROUP/sites.template.xml
   if [ -f $TEMPLATE ]; then
-    sed "s at _WORK_@$PWD/work@;s at _HOST_@$GLOBUS_HOSTNAME@" < $TEMPLATE > sites.xml
+    sed -f $RUNDIR/sites.sed < $TEMPLATE > sites.xml
     [ $? != 0 ] && crash "Could not create sites.xml!"
     echo "Using: $GROUP/sites.template.xml"
   else
@@ -851,6 +896,8 @@
 date > $LOG
+make_sites_sed
 header
 start_test_results
 cd $TOPDIR
@@ -914,6 +961,7 @@
             $TESTDIR/cdm/ps \
             $TESTDIR/cdm/star
             $TESTDIR/cdm/ps/pinned
+	    # $TESTDIR/site/intrepid
 GROUPCOUNT=1
