[Swift-commit] r3767 - provenancedb/apps/oops
noreply at svn.ci.uchicago.edu
Sun Dec 12 17:47:03 CST 2010
Author: lgadelha
Date: 2010-12-12 17:47:03 -0600 (Sun, 12 Dec 2010)
New Revision: 3767
Removed:
provenancedb/apps/oops/raptor_extractor.sh
Modified:
provenancedb/apps/oops/oops_extractor.sh
Log:
Minor fixes.
Modified: provenancedb/apps/oops/oops_extractor.sh
--- provenancedb/apps/oops/oops_extractor.sh 2010-12-12 23:29:54 UTC (rev 3766)
+++ provenancedb/apps/oops/oops_extractor.sh 2010-12-12 23:47:03 UTC (rev 3767)
@@ -85,8 +85,7 @@
$SQLCMD -t -A -F " " -f query.sql -o result.txt
while read dataset filename; do
- DATASET_ID=$(awk '{if (NR==1) print $1}' result.txt)
- FILENAME=$(awk '{if (NR==1) print $2}' result.txt | sed 's/file:\/\/localhost\///g')
+ FILENAME=$(echo $filename | sed 's/file:\/\/localhost\///g')
while read token1 token2 token3 token4; do
if [ "$token2" = "(Initial Energy:" ]; then
initialenergy=$(echo $token3 | awk 'BEGIN { FS = "\)" }; {print $1}')
Deleted: provenancedb/apps/oops/raptor_extractor.sh
--- provenancedb/apps/oops/raptor_extractor.sh 2010-12-12 23:29:54 UTC (rev 3766)
+++ provenancedb/apps/oops/raptor_extractor.sh 2010-12-12 23:47:03 UTC (rev 3767)
@@ -1,75 +0,0 @@
-#!/bin/bash
-# Annotation extractor for the OOPS application
-# The directory $PROTESTS/swift-logs contains symbolic links to
-# OOPS' Swift logs.
-PROVDB_HOME=~/provenancedb
-PROTESTS_HOME=/gpfs/pads/oops/aashish/CASP
-IMPORT_HOME=~/protests
-source $PROVDB_HOME/etc/provenance.config
-# provdb_imported records runs already imported to the provenance database
-cd $IMPORT_HOME
-if [ ! -a provdb_imported_raptor ]; then
- touch provdb_imported_raptor
-fi
-cd $PROTESTS_HOME
-for k in $(ls -1);
-do
- cd $PROTESTS_HOME/$k
- for i in $(ls | grep run.raptorloops; ls | grep run.loops);
- do
- cd $IMPORT_HOME
- if ! grep --silent $i provdb_imported_raptor; then
- if grep --silent "Swift finished with no errors" $PROTESTS_HOME/$k/$i/RaptorLoops-*.log; then
- # swift-prov-import-all-logs also controls what already has been
- # imported, so it does not repeat work
- echo "export LOGREPO=$PROTESTS_HOME/$k/$i" > $PROVDB_HOME/etc/provenance.config
- echo "export SQLCMD=\"psql -U provdb -h db.ci.uchicago.edu provdb\"" >> $PROVDB_HOME/etc/provenance.config
- $PROVDB_HOME/swift-prov-import-all-logs
- cd $IMPORT_HOME
- echo $i >> provdb_imported_raptor
- cd swift-logs
- # annotate workflows with their oops runid
- OOPS_RUN_ID=$(echo $i | awk -F . '{print $3}')
- cd $PROTESTS_HOME/$k/$i
- LOG_FILENAME=$(ls | grep RaptorLoops- | grep "\."log$)
- WORKFLOW_ID=$(echo "select id from workflow where log_filename like '%$LOG_FILENAME%'" | $SQLCMD -t | awk '{print $1}')
- cd $IMPORT_HOME/swift-logs
- echo "insert into annot_wf_txt values ('$WORKFLOW_ID','oops_run_id','$OOPS_RUN_ID');" | $SQLCMD
- echo "select file.id,file.filename from process, ds_usage, ds_containment, file where process.id=ds_usage.process_id and ds_usage.dataset_id=out_id and file.id=ds_containment.in_id and filename like '%.params' and process.name='PrepLoop' and process.workflow_id='$WORKFLOW_ID';" > query.sql;
- $SQLCMD -t -A -F " " -f query.sql -o result.txt
- cd $PROTESTS_HOME/$k/run.raptorloops.$OOPS_RUN_ID
- while read line; do
- NAME=$(echo $line | awk 'BEGIN { FS = "=" }; {print $1}')
- if [ "$NAME" = "SAMPLE RANGE" ]; then
- VALUE1=$(echo $line | awk 'BEGIN { FS = "=" }; {print $2}' | awk 'BEGIN { FS = "-" }; {print $1}')
- VALUE2=$(echo $line | awk 'BEGIN { FS = "=" }; {print $2}' | awk 'BEGIN { FS = "-" }; {print $2}')
- echo "insert into annot_ds_num values ('$DATASET_ID', '$NAME BEGIN', $VALUE1);" | $SQLCMD
- echo "insert into annot_ds_num values ('$DATASET_ID', '$NAME END', $VALUE2);" | $SQLCMD
- fi
- if [ "$NAME" = "RESTRAIN DISTANCE" ]; then
- VALUE1=$(echo $line | awk 'BEGIN { FS = "=" }; {print $2}' | awk 'BEGIN { FS = "," }; {print $1}')
- VALUE2=$(echo $line | awk 'BEGIN { FS = "=" }; {print $2}' | awk 'BEGIN { FS = "," }; {print $2}')
- echo "insert into annot_ds_num values ('$DATASET_ID', '$NAME 1', $VALUE1);" | $SQLCMD
- echo "insert into annot_ds_num values ('$DATASET_ID', '$NAME 2', $VALUE2);" | $SQLCMD
- fi
- if [ "$NAME" = "MAXIMUM NUMBER OF STEPS" ]; then
- VALUE=$(echo $line | awk 'BEGIN { FS = "=" }; {print $2}')
- echo "insert into annot_ds_num values ('$DATASET_ID', '$NAME', $VALUE);" | $SQLCMD
- fi
- done < $FILENAME
- fi
- fi
- done
-done
More information about the Swift-commit
