[Swift-commit] r3751 - provenancedb
noreply at svn.ci.uchicago.edu
Wed Dec 8 17:05:00 CST 2010
Author: lgadelha
Date: 2010-12-08 17:05:00 -0600 (Wed, 08 Dec 2010)
New Revision: 3751
Modified:
provenancedb/swift-prov-import-all-logs
Log:
Minor fixes.
Modified: provenancedb/swift-prov-import-all-logs
--- provenancedb/swift-prov-import-all-logs 2010-12-08 22:38:54 UTC (rev 3750)
+++ provenancedb/swift-prov-import-all-logs 2010-12-08 23:05:00 UTC (rev 3751)
@@ -42,7 +42,7 @@
if [ "$EXISTING" -eq "0" ]; then
PROV_ENABLED=$(grep provenance $filename | wc -l)
- if [ "$PROV_ENABLED" -ge "0" ]; then
+ if [ $PROV_ENABLED -gt 0 ]; then
echo IMPORTING
if grep --silent "DEBUG Loader Swift finished with no errors" $filename; then
@@ -72,7 +72,7 @@
# import-run-to-xml $filename
else
- echo SKIP: provenance.log not true in swift.properties
+ echo SKIP: provenance.log not set to true in etc/swift.properties
fi
else
echo SKIP: Already known in workflow
More information about the Swift-commit
