[Swift-commit] r3732 - provenancedb
noreply at svn.ci.uchicago.edu
Wed Dec 1 21:37:14 CST 2010
Author: lgadelha
Date: 2010-12-01 21:37:14 -0600 (Wed, 01 Dec 2010)
New Revision: 3732
Modified:
provenancedb/prov-init.sql
provenancedb/prov-to-sql.sh
Log:
Minor corrections to import scripts.
Modified: provenancedb/prov-init.sql
--- provenancedb/prov-init.sql 2010-12-01 21:00:54 UTC (rev 3731)
+++ provenancedb/prov-init.sql 2010-12-02 03:37:14 UTC (rev 3732)
@@ -231,8 +231,6 @@
PRIMARY KEY (array_id,from_id,to_id,step_id)
-- this GRANT does not work for sqlite; you'll get a syntax error but
-- ignore it, as it is not needed in sqlite
GRANT ALL ON
Modified: provenancedb/prov-to-sql.sh
--- provenancedb/prov-to-sql.sh 2010-12-01 21:00:54 UTC (rev 3731)
+++ provenancedb/prov-to-sql.sh 2010-12-02 03:37:14 UTC (rev 3732)
@@ -9,7 +9,7 @@
echo Generating SQL for $RUNID
-rm -f tmp-ds.sql tmp-p.sql tmp-e.sql tmp-e2.sql tmp-dsu.sql tmp-dsc.sql tmp-f.sql tmp-v.sql tmp-import.sql import.sql
+rm -f tmp-u.sql tmp-ds.sql tmp-p.sql tmp-e.sql tmp-e2.sql tmp-dsu.sql tmp-dsc.sql tmp-f.sql tmp-v.sql tmp-import.sql import.sql
# this gives a distinction between the root process for a workflow and the
# workflow itself. perhaps better to model the workflow as a process
More information about the Swift-commit
