[Swift-commit] r3582 - trunk/libexec
Mon Aug 30 13:06:16 CDT 2010
Author: wozniak
Date: 2010-08-30 13:06:16 -0500 (Mon, 30 Aug 2010)
New Revision: 3582
Modified:
   trunk/libexec/_swiftwrap
   trunk/libexec/cdm_lib.sh
Log:
Make sure CDM does not do anything when not enabled
Modified: trunk/libexec/_swiftwrap
--- trunk/libexec/_swiftwrap	2010-08-30 17:18:21 UTC (rev 3581)
+++ trunk/libexec/_swiftwrap	2010-08-30 18:06:16 UTC (rev 3582)
@@ -367,23 +367,25 @@
 	fi
 done
-logstate "LINK_CDM_OUTPUTS"
-SKIPPED_OUTPUT=()
-GATHER_OUTPUT=()
-for L in $OUTF ; do
-	CDM_POLICY=$( cdm_lookup shared/cdm.pl $CDM_FILE $L )
-	if [[ $CDM_POLICY != "DEFAULT" &&
-              $CDM_POLICY != "BROADCAST"* ]]; then
-		log "CDM_POLICY: $L -> $CDM_POLICY"
-    	        eval cdm_action $DIR "OUTPUT" $L $CDM_POLICY
-		SKIPPED_OUTPUT=( $SKIPPED_OUTPUT $L )
-	fi
-	if [ $CDM_POLICY == "GATHER" ]; then
-		GATHER_OUTPUT=( $GATHER_OUTPUT $L )
-	elif [ $CDM_POLICY == "LOCAL" ]; then
-		CDM_LOCAL_OUTPUT=( $CDM_LOCAL_OUTPUT $L )
-	fi
-done
+if [ ! -z $CDM_FILE ]; then
+    logstate "LINK_CDM_OUTPUTS"
+    SKIPPED_OUTPUT=()
+	GATHER_OUTPUT=()
+	for L in $OUTF ; do
+		CDM_POLICY=$( cdm_lookup shared/cdm.pl $CDM_FILE $L )
+		if [[ $CDM_POLICY != "DEFAULT" &&
+			  $CDM_POLICY != "BROADCAST"* ]]; then
+			log "CDM_POLICY: $L -> $CDM_POLICY"
+    	    eval cdm_action $DIR "OUTPUT" $L $CDM_POLICY
+			SKIPPED_OUTPUT=( $SKIPPED_OUTPUT $L )
+		fi
+		if [ $CDM_POLICY == "GATHER" ]; then
+			GATHER_OUTPUT=( $GATHER_OUTPUT $L )
+		elif [ $CDM_POLICY == "LOCAL" ]; then
+			CDM_LOCAL_OUTPUT=( $CDM_LOCAL_OUTPUT $L )
+		fi
+	done
+fi
 logstate "EXECUTE"
 cd $DIR
@@ -490,5 +492,7 @@
 # Local Variables:
 # mode: sh
-# sh-basic-offset: 8
+# sh-basic-offset: 4
+# tab-width: 4
+# indent-tabs-mode: 1
 # End:
Modified: trunk/libexec/cdm_lib.sh
--- trunk/libexec/cdm_lib.sh	2010-08-30 17:18:21 UTC (rev 3581)
+++ trunk/libexec/cdm_lib.sh	2010-08-30 18:06:16 UTC (rev 3582)
@@ -10,7 +10,7 @@
 	FILE=$3
 	RESULT="DEFAULT"
-	if [ -f $CDM_PL ]; then
+	if [ ! -z $CDM_FILE ] && [ -f $CDM_PL ] && [ -f $CDM_FILE ]; then
 		RESULT=$( perl $CDM_PL lookup $FILE < $CDM_FILE 2> $INFO )
 		checkError 254 "cdm_lookup(): failed! (malformed CDM file?)"
 	fi
