[Swift-commit] r3539 - in usertools/swift/swiftconfig: bin lib/perl
noreply at svn.ci.uchicago.edu
Mon Aug 16 00:35:45 CDT 2010
Author: davidk
Date: 2010-08-16 00:35:45 -0500 (Mon, 16 Aug 2010)
New Revision: 3539
Modified:
usertools/swift/swiftconfig/bin/swiftconfig
usertools/swift/swiftconfig/bin/swiftrun
usertools/swift/swiftconfig/lib/perl/SwiftConfig.pm
Log:
Preliminary version of TC editing
Modified: usertools/swift/swiftconfig/bin/swiftconfig
--- usertools/swift/swiftconfig/bin/swiftconfig 2010-08-15 22:20:15 UTC (rev 3538)
+++ usertools/swift/swiftconfig/bin/swiftconfig 2010-08-16 05:35:45 UTC (rev 3539)
@@ -15,18 +15,16 @@
use File::Which qw(which where);
# Variables used for sites.xml
-my $option_templates = q{}; # List all templates
-my $option_remove = q{}; # Remove entry from sites.xml
-my $option_edit = q{}; # Edit mode
-my $option_sites = q{}; # List all usable sites
-my $option_describe = q{}; # Print raw XML configuration
-my $option_default = q{}; # When adding a site, use all defaults
-my $option_template = q{}; # Create config from template specified
-my $option_copy = q{}; # Copy an existing configuration
+my $option_templates = q{}; # List all templates
+my $option_remove = q{}; # Remove entry from sites.xml
+my $option_edit = q{}; # Edit mode
+my $option_sites = q{}; # List all usable sites
+my $option_describe = q{}; # Print raw XML configuration
+my $option_default = q{}; # When adding a site, use all defaults
+my $option_template = q{}; # Create config from template specified
+my $option_copy = q{}; # Copy an existing configuration
+my $option_applications = q{}; # Edit applications
-my @execution_providers =
- ( "gt4", "local", "pbs", "condor", "ssh", "coaster", );
# Assign variables from command line options
GetOptions(
'remove=s' => \$option_remove,
@@ -38,11 +36,13 @@
'template=s' => \$option_template,
'edit=s' => \$option_edit,
'copy=s' => \$option_copy,
+ 'apps|applications' => \$option_applications,
'help|man' => sub { pod2usage(-verbose => 2); },
# Prepare data
my $xml = new XML::Simple();
+initialize_swiftconfig();
# Create all required directories
my $dotswift_directory = "$ENV{'HOME'}/.swift";
@@ -64,7 +64,7 @@
if ( !-e "$sites_input_file" ) {
die "Unable to find configuration for $sites_input_file\n";
- my $xml_ref = update_xml("$sites_input_file", 0, $option_default, @execution_providers);
+ my $xml_ref = update_xml("$sites_input_file", 0, $option_default);
my $new_sitename = $xml_ref->{handle};
my $output_directory = "$dotswift_directory/sites/$new_sitename";
if ( -d "$output_directory" ) {
@@ -154,7 +154,7 @@
ForceArray => [qw(workdirectory profile)],
KeyAttr => [],
- $xml_ref = update_xml("$sites_file", 1, $option_default, @execution_providers);
+ $xml_ref = update_xml("$sites_file", 1, $option_default);
# Save
my $xml_out_ref = $xml->XMLout(
@@ -207,10 +207,7 @@
# Edit sites
my $initial_exurl = $xml_ref->{execution}{url};
- $xml_ref = update_xml( "$output_directory/sites.xml",
- 1,
- $option_default,
- @execution_providers);
+ $xml_ref = update_xml( "$output_directory/sites.xml", 1, $option_default,);
my $new_exurl = $xml_ref->{execution}{url};
@@ -231,6 +228,55 @@
+# Add/Edit applications
+if($option_applications) {
+ my @applications = glob("$dotswift_directory/apps/*");
+ foreach(@applications) {
+ $_ = strip_directory($_);
+ my ($base, $ext) = split('\.');
+ $_ = $base;
+ push(@applications, 'new');
+ my $application_set = get_entry('Select application set', 'linux', 0,
+ @applications);
+ if($application_set eq 'new') {
+ $application_set = get_entry('Name of new application set', '', 0);
+ my $now = time();
+ if(-e "$dotswift_directory/apps/$application_set.apps") {
+ print "Set named $application_set already exists\n";
+ return;
+ open(APPFILE, ">$dotswift_directory/apps/$application_set.apps")
+ || die "Unable to create file $dotswift_directory/apps/$application_set.apps";
+ print "$application_set set created\n\n";
+ close(APPFILE);
+ my $quit = 0;
+ while($quit == 0) {
+ print "\n(E)dit, (a)dd, (r)emove, (l)ist, or (q)uit: ";
+ my $edit_or_add = <STDIN>;
+ chomp($edit_or_add);
+ if(lc($edit_or_add) eq 'a') {
+ add_application("$dotswift_directory/apps/$application_set.apps");
+ elsif(lc($edit_or_add) eq 'q') {
+ $quit = 1;
+ elsif(lc($edit_or_add) eq 'r') {
+ remove_application("$dotswift_directory/apps/$application_set.apps");
+ elsif(lc($edit_or_add) eq 'l') {
+ list_applications("$dotswift_directory/apps/$application_set.apps");
+ elsif(lc($edit_or_add) eq 'e') {
+ edit_application("$dotswift_directory/apps/$application_set.apps");
__END__
=head1 NAME
Modified: usertools/swift/swiftconfig/bin/swiftrun
--- usertools/swift/swiftconfig/bin/swiftrun 2010-08-15 22:20:15 UTC (rev 3538)
+++ usertools/swift/swiftconfig/bin/swiftrun 2010-08-16 05:35:45 UTC (rev 3539)
@@ -26,6 +26,7 @@
# Create run directory
my $script_filename = strip_directory($option_script);
my @run_directories = <run.????>;
@@ -35,46 +36,72 @@
my ($run_number) = $run_directories[-1] =~ m{(\d+)};
$run_number++;
my $run_directory = getcwd() . "/" . sprintf "run.%04s", $run_number;
+my @sites_xml;
create_directory($run_directory);
copy_file( "$option_script", "$run_directory" );
-# Create configuration files for run
-foreach my $site (@option_sites) {
- # Handle 'all' to use all available configurations at once
- if( lc($site) eq 'all' ) {
- foreach my $all_site(<$dotswift_directory/sites/*>) {
- if ( !-d "$all_site" ) {
- die "Unable to find directory for $all_site\n";
+# Sites.xml for 'all'
+if( grep /all/, @option_sites ) {
+ foreach my $all_site(<$dotswift_directory/sites/*>) {
+ if ( !-d "$all_site" ) {
+ die "Unable to find directory for $all_site\n";
+ if ( !-e "$all_site/sites.xml" ) {
+ die "Unable to find sites.xml for $all_site\n";
+ open(CURRENT_SITE, "$all_site/sites.xml")
+ || die "Unable to open $all_site/sites.xml";
+ my @current_site_data = <CURRENT_SITE>;
+ push(@sites_xml, @current_site_data);
+ close(CURRENT_SITE);
+ # Add applications
+ my @all_apps = glob("$dotswift_directory/apps/*.apps");
+ foreach my $current_app_file(@all_apps) {
+ open(CURRENT_APP, $current_app_file) || die "Unable to open app file $current_app_file\n";
+ my @current_app_data = <CURRENT_APP>;
+ close(CURRENT_APP);
+ $all_site = strip_directory($all_site);
+ foreach(@current_app_data) {
+ s/\$HOST/$all_site/ig;
- if ( !-e "$all_site/sites.xml" ) {
- die "Unable to find sites.xml for $all_site\n";
- if ( !-e "$all_site/tc.data" ) {
- die "Unable to find tc.data for $all_site\n";
- cat_file( "$all_site/sites.xml", "$run_directory/sites.xml" );
- cat_file( "$all_site/tc.data", "$run_directory/tc.data" );
+ open(RUNTC, ">>$run_directory/tc.data") || die "Unable to write to $run_directory/tc.data\n";
+ print RUNTC @current_app_data;
+ close(RUNTC);
- # Normal, non-'all' site
- else {
+# Sites.xml for non-'all'
+else {
+ foreach my $site (@option_sites) {
if ( !-d "$dotswift_directory/sites/$site" ) {
- die "Unable to find entry for $site\n";
+ die "Unable to find configuration for $site\n";
if ( !-e "$dotswift_directory/sites/$site/sites.xml" ) {
die "Unable to find sites.xml for $site\n";
+ open(CURRENT_SITE, "$dotswift_directory/sites/$site/sites.xml")
+ || die "Unable to open $dotswift_directory/sites/$site/sites.xml";
+ s/\$HOST/$site/ig;
+ close(RUNTC);
- if ( !-e "$dotswift_directory/sites/$site/tc.data" ) {
- die "Unable to find tc.data for $site\n";
- cat_file( "$dotswift_directory/sites/$site/sites.xml",
- "$run_directory/sites.xml" );
- cat_file( "$dotswift_directory/sites/$site/tc.data",
- "$run_directory/tc.data" );
# Link input data
foreach my $input_file (@option_inputs) {
# Check for relative path
@@ -91,14 +118,9 @@
|| die "Unable to create symlink to $new_path\n";
-# Complete XML tags
-open( SITEFILE, "$run_directory/sites.xml" )
- || die "Unable to open $run_directory/sites.xml\n";
-my @sitedata = <SITEFILE>;
-close(SITEFILE);
open( SITEFILE, ">$run_directory/sites.xml" )
|| die "Unable to open $run_directory/sites.xml for writing\n";
-print SITEFILE "<config>\n at sitedata</config>\n";
+print SITEFILE "<config>\n at sites_xml</config>\n";
close(SITEFILE);
# Run swift
Modified: usertools/swift/swiftconfig/lib/perl/SwiftConfig.pm
--- usertools/swift/swiftconfig/lib/perl/SwiftConfig.pm 2010-08-15 22:20:15 UTC (rev 3538)
+++ usertools/swift/swiftconfig/lib/perl/SwiftConfig.pm 2010-08-16 05:35:45 UTC (rev 3539)
@@ -16,25 +16,19 @@
require Exporter;
our @ISA = qw(Exporter);
-# Items to export into callers namespace by default. Note: do not export
-# names by default without a very good reason. Use EXPORT_OK instead.
-# Do not simply export all your public functions/methods/constants.
-# This allows declaration use SwiftConfig ':all';
-# If you do not need this, moving things directly into @EXPORT or @EXPORT_OK
-# will save memory.
-our %EXPORT_TAGS = ( 'all' => [ qw(
+our %EXPORT_TAGS = ( 'all' => [ qw() ] );
our @EXPORT_OK = ( @{ $EXPORT_TAGS{'all'} } );
our @EXPORT = qw(create_directory get_entry add_ssh remove_ssh
update_tc_hostname update_xml write_file print_directory strip_directory
-copy_file cat_file
+copy_file cat_file add_application edit_application remove_application
+list_applications initialize_swiftconfig
our $VERSION = '0.01';
# Prepare data
+my @execution_providers =
+ ( "gt4", "local", "pbs", "condor", "ssh", "coaster", );
# Create a new directory if it does not exist
sub create_directory {
@@ -221,7 +215,7 @@
sub update_xml {
# Set up data
- my ($xml_filename, $edit_mode, $option_default, @execution_providers) = @_;
+ my ($xml_filename, $edit_mode, $option_default) = @_;
# Values for edit mode
# 0 - Edit all
# 1 - All but name
@@ -248,7 +242,7 @@
'Execution Provider',
$xml_ref->{execution}{provider},
$option_default,
- @execution_providers,
+ @execution_providers,
my $current_exprovider = $xml_ref->{execution}{provider};
@@ -331,7 +325,6 @@
'Filesystem Provider',
$xml_ref->{filesystem}{provider},
$option_default,
if ( $xml_ref->{filesystem}{url} ) {
@@ -345,7 +338,6 @@
$profile->{content} =
get_entry( $profile->{key}, $profile->{content}, $option_default);
return $xml_ref;
@@ -403,6 +395,155 @@
return $filename;
+# Add an application
+sub add_application {
+ my ($app_filename) = @_;
+ open(APPFILE, "+<$app_filename") || die "Unable to open application file $app_filename for writing\n";
+ print "Enter name of new application: ";
+ my $app_name = <STDIN>;
+ chomp($app_name);
+ foreach(<APPFILE>){
+ my ($site, $name, $path, $status, $platform, $profile) = split(/\s+/);
+ if($name eq $app_name) {
+ print "$name already exists\n";
+ return;
+ my $app_path_guess = which("$app_name");
+ if(!$app_path_guess) {
+ $app_path_guess = "/path/to/$app_name";
+ my $app_path = get_entry("Path", $app_path_guess, 0);
+ my $app_time = get_entry("Walltime (hh:mm:ss)", "00:20:00", 0);
+ while($app_time !~ m/(\d+:\d+:\d+)/ ) {
+ print "Error: incorrect format\n";
+ $app_time = get_entry("Walltime", $1, 0);
+ print APPFILE "\$HOST\t$app_name\t$app_path\tINSTALLED\tINTEL32::LINUX\tGLOBUS::maxwalltime=\"$app_time\"\n";
+ close(APPFILE);
+ print "Added $app_name\n";
+# Remove an application
+sub remove_application {
+ open(APPFILE, "$app_filename") || die "Unable to open application file $app_filename\n";
+ my $app_to_remove = get_entry("Name of application to remove", '', 0);
+ my @app_data;
+ my $found=0;
+ foreach my $line (<APPFILE>){
+ my ($site, $name, $path, $status, $platform, $profile) = split(/\s+/, $line);
+ if($name eq $app_to_remove) {
+ $found=1;
+ else {
+ push(@app_data, $line);
+ close(APPFILE);
+ if(!$found) {
+ print "Unable to find application named $app_to_remove\n";
+ return;
+ else {
+ write_file($app_filename, @app_data);
+ print "Removed $app_to_remove\n";
+# List applications
+sub list_applications {
+ open(APPFILE, $app_filename) || die "Unable to open application file $app_filename\n";
+ my @app_data = <APPFILE>;
+ close(APPFILE);
+ my ($site, $name, $path, $status, $platform, $profile);
+ my $counter=0;
+ foreach(@app_data) {
+ ($site, $name, $path, $status, $platform, $profile) = split(/\s+/);
+ my $nicely_formatted = sprintf("%-15s %-30s %-35s", $name, $path, $profile);
+ print "$nicely_formatted\n";
+# Edit application
+sub edit_application {
+ close(APPFILE);
+ print "Application to edit: ";
+ my $app_to_edit = <STDIN>;
+ chomp($app_to_edit);
+ my $found=0;
+ if( $name eq $app_to_edit) {
+ $found=1;
+ my $previous_name = $name;
+ # App name
+ $name = get_entry("New application name", $name, 0);
+ if($name ne $previous_name) {
+ $path = which("$name");
+ # Path
+ if(!$path) {
+ $path = "/path/app";
+ $path = get_entry("New path", $path, 0);
+ # Time
+ my $time = '';
+ my $wallfound=0;
+ my $counter=0;
+ my @profiles = split(/;/, $profile);
+ foreach (@profiles) {
+ if( m/maxwalltime=\"(\d+:\d+:\d+)\"/ig ) {
+ $wallfound=1;
+ $time = get_entry("Walltime", $1, 0);
+ while($time !~ m/(\d+:\d+:\d+)/ ) {
+ s/(\d+:\d+:\d+)/$time/g;
+ if( !$wallfound ) {
+ $time = get_entry("Time", "00:20:00", 0);
+ push(@profiles, "GLOBUS::maxwalltime=\"$time\"");
+ $profile = join(';', @profiles);
+ $_ = "$site\t$name\t$path\t$status\t$platform\t$profile\n";
+ if(!$found) {
+ print "Unable to find application named $app_to_edit\n";
+ return;
+ else {
+ print "$app_to_edit updated\n";
+ open(APPFILE, ">$app_filename") || die "Unable to open application file $app_filename for writing\n";
+ print APPFILE @app_data;
+ close(APPFILE);
+# Initialize swiftconfig. Prepare things it needs for first run
+sub initialize_swiftconfig {
+ create_directory("$ENV{'HOME'}/.swift");
+ create_directory("$ENV{'HOME'}/.swift/sites");
+ if(!-e "$ENV{'HOME'}/.swift/apps") {
+ create_directory("$ENV{'HOME'}/.swift/apps");
+ my @app_files = glob("$FindBin::Bin/../etc/apps/*.apps");
+ foreach my $app_file(@app_files) {
+ copy_file($app_file, "$ENV{'HOME'}/.swift/apps");
1;
__END__
@@ -443,12 +584,11 @@
$filename is the filename of the tc.data
$tc_hostname is the value of the new hostname
-update_xml($xml_filename, $edit_mode, $option_default, @execution_providers)
+update_xml($xml_filename, $edit_mode, $option_default)
Edit and update a sites.xml file
$xml_filename filename to edit
There are currently two edit modes: 0=edit everything, 1=everything but name
$option_default, if true, will automatically use defaults
- @execution_providers is the list of all valid execution providers
write_file($filename, @data)
Write to $filename with @data. Handle errors
More information about the Swift-commit
