[Swift-commit] r3535 - usertools/swift/swiftconfig/bin
Sat Aug 14 17:45:00 CDT 2010
Author: davidk
Date: 2010-08-14 17:45:00 -0500 (Sat, 14 Aug 2010)
New Revision: 3535
Modified:
   usertools/swift/swiftconfig/bin/swiftconfig
Log:
Better transitioning between execution providers
Modified: usertools/swift/swiftconfig/bin/swiftconfig
--- usertools/swift/swiftconfig/bin/swiftconfig	2010-08-14 01:22:46 UTC (rev 3534)
+++ usertools/swift/swiftconfig/bin/swiftconfig	2010-08-14 22:45:00 UTC (rev 3535)
@@ -84,18 +84,23 @@
         return $entry_value;
-    if(!@allowable_values) {
+   if(!@allowable_values) {
         print "$entry_description [$entry_value]: ";
     else {
         print "$entry_description [";
+        my $counter=0;
         foreach my $allowable(@allowable_values) {
+            if($counter != 0) {
+                print " ";
             if($allowable eq $entry_value) {
-                print "*$allowable ";
+                print "*$allowable";
             else {
-                print "$allowable ";
+                print "$allowable";
+           $counter++;
         print "]: ";
@@ -283,6 +288,53 @@
         $xml_ref->{handle} = get_entry( 'Site Entry Name', $xml_ref->{handle}, $option_default);
+    # Execution
+    my $initial_exprovider = $xml_ref->{execution}{provider};
+    $xml_ref->{execution}{provider} = get_entry(
+        'Execution Provider',
+        $xml_ref->{execution}{provider},
+        $option_default,
+        @execution_providers,
+    my $current_exprovider = $xml_ref->{execution}{provider};
+    # Handle changes in execution provider
+    if( $initial_exprovider ne $current_exprovider ) {
+        # Add SSH fields
+        if( $current_exprovider eq 'ssh' ) {
+            if( !$xml_ref->{execution}{url} ) {
+                $xml_ref->{execution}{url} = 'unknown';
+        # Add coaster fields
+        if( $current_exprovider eq 'coaster' ) {
+            if( !$xml_ref->{execution}{jobmanager} ) {
+                $xml_ref->{execution}{jobmanager} = 'unknown';
+            if( !$xml_ref->{execution}{url} ){
+    # Job manager
+    if ( $xml_ref->{execution}{jobmanager}) {
+                get_entry( 'Execution Job Manager',
+                $xml_ref->{execution}{jobmanager},
+                $option_default
+    # Execution URL
+    if ( $xml_ref->{execution}{url} ) {
+                get_entry( 'Execution URL',
+                            $xml_ref->{execution}{url},
+                            $option_default
     # Grid FTP
     if ( $xml_ref->{gridftp} ) {
         $xml_ref->{gridftp}{url} =
@@ -318,28 +370,6 @@
-    # Execution
-    if ( $xml_ref->{execution} ) {
-        if ( $xml_ref->{execution}{provider} ) {
-            $xml_ref->{execution}{provider} = get_entry(
-                'Execution Provider',
-                $xml_ref->{execution}{provider},
-                $option_default,
-                @execution_providers,
-        if ( $xml_ref->{execution}{jobmanager} ) {
-            $xml_ref->{execution}{jobmanager} =
-                get_entry( 'Execution Job Manager',
-                $xml_ref->{execution}{jobmanager},
-                $option_default);
-        if ( $xml_ref->{execution}{url} ) {
-            $xml_ref->{execution}{url} =
-                get_entry( 'Execution URL', $xml_ref->{execution}{url}, $option_default);
     # Filesystem
     if ( $xml_ref->{filesystem} ) {
         if ( $xml_ref->{filesystem}{provider} ) {
@@ -432,13 +462,18 @@
 if ($option_describe) {
     my $site_file = "$dotswift_directory/sites/$option_describe/sites.xml";
     if ( !-e $site_file ) {
-        die "Unable to find $site_file\n";
+        die "Unable to locate configuration for $option_describe\n";
     system("cat $site_file");
 # Remove an entry
 if ($option_remove) {
+    if ( !-d "$dotswift_directory/sites/$option_remove" ) {
+        die "Unable to find configuration named $option_remove\n";
     my $xml_filename = "$dotswift_directory/sites/$option_remove/sites.xml";
     my $xml_ref = $xml->XMLin(
         $xml_filename,
@@ -447,14 +482,11 @@
     # Remove SSH entry if needed
-    if($xml_ref->{execution}{provider} eq "ssh") {
-        remove_ssh($xml_ref->{execution}{url});
+    #if($xml_ref->{execution}{provider} eq "ssh") {
+    #    remove_ssh($xml_ref->{execution}{url});
     # Remove directory
-    if ( !-d "$dotswift_directory/sites/$option_remove" ) {
-        die "Unable to find site entry for $option_remove\n";
     rmtree("$dotswift_directory/sites/$option_remove")
         || die 'Unable to remove directory '
         . "$dotswift_directory/sites/$option_remove\n";
@@ -486,12 +518,9 @@
         ForceArray => [qw(workdirectory profile)],
         KeyAttr    => [],
+    $xml_ref = update_xml("$sites_file", 1);
-    my $initial_exurl = $xml_ref->{execution}{url};
-    $xml_ref = update_xml("$sites_file", 1);
-    my $new_exurl = $xml_ref->{execution}{url};
-    #my $new_sitename = $xml_ref->{handle};
+   # Save
     my $xml_out_ref = $xml->XMLout(
         $xml_ref,
         RootName      => 'pool',
@@ -501,9 +530,6 @@
     # Add/modify/remove ssh entries as needed
     if ( $xml_ref->{execution}{provider} eq 'ssh' ) {
-        if ( $initial_exurl && $initial_exurl ne $new_exurl ) {
-            remove_ssh( $initial_exurl );
         add_ssh( $xml_ref->{handle}, $xml_ref->{execution}{url} );
