[Swift-commit] r3530 - in usertools/swift/swiftconfig: bin etc
Fri Aug 13 10:43:27 CDT 2010
Author: davidk
Date: 2010-08-13 10:43:27 -0500 (Fri, 13 Aug 2010)
New Revision: 3530
Modified:
   usertools/swift/swiftconfig/bin/swiftconfig
   usertools/swift/swiftconfig/bin/swiftrun
   usertools/swift/swiftconfig/etc/TODO
Log:
Swiftconfig: edit, copy, template
pod for swiftrun
Help option displays pod for both swiftconfig and swiftrun
editing modes
Modified: usertools/swift/swiftconfig/bin/swiftconfig
--- usertools/swift/swiftconfig/bin/swiftconfig	2010-08-13 05:12:44 UTC (rev 3529)
+++ usertools/swift/swiftconfig/bin/swiftconfig	2010-08-13 15:43:27 UTC (rev 3530)
@@ -5,6 +5,7 @@
 use Cwd qw(abs_path);
 use File::Copy;
 use File::Path;
+use Pod::Usage;
 my $swift_home = q{};
 if ( $ENV{'SWIFT_HOME'} && -e "$ENV{'SWIFT_HOME'}/bin/swift" ) {
@@ -37,37 +38,32 @@
 use XML::Simple;
 use Data::Dumper;
-# Variables used for translation catalog
-#my $tc_host     = 'localhost';         # Host name
-#my $tc_name     = q{};                 # Translation name
-#my $tc_path     = "/usr/bin/$name";    # Full path of executable location
-#my $tc_status   = 'INSTALLED';         # Installation status (not used)
-#my $tc_platform = 'INTEL32::LINUX';    # Platform (not used)
-#my $tc_profile  = 'null';              # Profile entries
 # Variables used for sites.xml
 my $option_templates = q{};            # List all templates
 my $option_remove    = q{};            # Remove entry from sites.xml
-my $option_modify    = q{};            # Modify mode
-my $option_add       = q{};            # Add entry
+my $option_edit      = q{};            # Edit mode
 my $option_sites     = q{};            # List all usable sites
 my $option_describe  = q{};            # Print raw XML configuration
 my $option_default   = q{};            # When adding a site, use all defaults
+my $option_template  = q{};            # Create config from template specified
+my $option_copy      = q{};            # Copy an existing configuration
 my @execution_providers =
     ( "gt4", "local", "pbs", "condor", "ssh", "coaster", );
 # Assign variables from command line options
 GetOptions(
-    'add=s'                 => \$option_add,
     'remove=s'              => \$option_remove,
     'templates'             => \$option_templates,
-    'modify=s'              => \$option_modify,
     'swift_home=s'          => \$swift_home,
     'sites'                 => \$option_sites,
     'describe=s'            => \$option_describe,
     'default|defaults'      => \$option_default,
     'full'                  => sub { $option_default = 0; },
+    'template=s'            => \$option_template,
+    'edit=s'                => \$option_edit,
+    'copy=s'                => \$option_copy,
+    'help'                  => sub { pod2usage(-verbose => 2); },
 # Create a new directory if it does not exist
@@ -83,6 +79,7 @@
 sub get_entry {
     my ( $entry_description, $entry_value, $use_default, @allowable_values, ) = @_;
+    # If use_default is specified, automatically plug in the default value
     if($use_default) {
         return $entry_value;
@@ -250,7 +247,12 @@
 sub update_xml {
     # Set up data
-    my ($xml_filename) = @_;
+    my ($xml_filename, $edit_mode) = @_;
+    # Values for edit mode
+    # 0 - Edit all
+    # 1 - All but name
+    # 2 - Customized.. to do
     if ( !-e $xml_filename ) {
         die "Unable to update xml file $xml_filename\n";
@@ -262,8 +264,10 @@
     # Handle
-    $xml_ref->{handle} = get_entry( 'Site Entry Name', $xml_ref->{handle}, $option_default);
+    if($edit_mode == 0) {
+        $xml_ref->{handle} = get_entry( 'Site Entry Name', $xml_ref->{handle}, $option_default);
     # Grid FTP
     if ( $xml_ref->{gridftp} ) {
         $xml_ref->{gridftp}{url} =
@@ -368,24 +372,20 @@
-# If a template is specified, find the correct one and modify as needed
-if ($option_add) {
+# Add configuration from a template
+if ($option_template) {
     # Update XML info
-    my $from_directory   = "$template_directory/$option_add";
+    my $from_directory   = "$template_directory/$option_template";
     my $sites_input_file = "$from_directory/sites.xml";
     if ( !-e "$sites_input_file" ) {
-        $from_directory   = "$dotswift_directory/sites/$option_add";
-        $sites_input_file = "$from_directory/sites.xml";
-        if ( !-e "$sites_input_file" ) {
-            die "Unable to find $sites_input_file\n";
+        die "Unable to find configuration for $sites_input_file\n";
-    my $xml_ref          = update_xml("$sites_input_file");
+    my $xml_ref          = update_xml("$sites_input_file", 0);
     my $new_sitename     = $xml_ref->{handle};
     my $output_directory = "$dotswift_directory/sites/$new_sitename";
     if ( -d "$output_directory" ) {
-        die "Entry for $new_sitename already exists\n";
+        die "Configuration for $new_sitename already exists\n";
     # Update and copy files to reflect input
@@ -402,7 +402,7 @@
     write_file( "$output_directory/sites.xml", $xml_out_ref );
-    if ( $option_add ne $new_sitename ) {
+    if ( $option_template ne $new_sitename ) {
         my $tc_filename = "$output_directory/tc.data";
         update_tc_hostname( "$tc_filename", $new_sitename );
@@ -456,16 +456,16 @@
 # Modify a site entry
-if ($option_modify) {
-    my $output_directory = "$dotswift_directory/sites/$option_modify";
+if ($option_edit) {
+    my $output_directory = "$dotswift_directory/sites/$option_edit";
     create_directory($output_directory);
     my $sites_file = "$output_directory/sites.xml";
     if ( !-e "$sites_file" ) {
-        die "Unable to find configuration for $option_modify\n";
+        die "Unable to find configuration for $option_edit\n";
-    my $xml_filename = "$dotswift_directory/sites/$option_modify/sites.xml";
+    my $xml_filename = "$output_directory/sites.xml";
     my $xml_ref = $xml->XMLin(
         $xml_filename,
         ForceArray => [qw(workdirectory profile)],
@@ -473,9 +473,9 @@
     my $initial_exurl = $xml_ref->{execution}{url};
-    $xml_ref = update_xml("$sites_file");
+    $xml_ref = update_xml("$sites_file", 1);
     my $new_exurl = $xml_ref->{execution}{url};
-    my $new_sitename = $xml_ref->{handle};
+    #my $new_sitename = $xml_ref->{handle};
     my $xml_out_ref = $xml->XMLout(
         $xml_ref,
@@ -484,29 +484,74 @@
-    # If the sitename has changed, move files
-    if ( $new_sitename ne $option_modify ) {
-        $output_directory = "$dotswift_directory/sites/$new_sitename";
-        if ( -d "$output_directory" ) {
-            die "Directory for $new_sitename already exists\n";
-        move( "$dotswift_directory/sites/$option_modify",
-            "$output_directory" )
-            || die "Unable to rename $dotswift_directory/sites/$option_modify"
-            . " to $output_directory";
-        my $tc_filename = "$output_directory/tc.data";
-        update_tc_hostname( "$tc_filename", $new_sitename );
     # Add/modify/remove ssh entries as needed
     if ( $xml_ref->{execution}{provider} eq 'ssh' ) {
-        if ( $initial_exurl ne $new_exurl ) {
+        if ( $initial_exurl && $initial_exurl ne $new_exurl ) {
             remove_ssh( $initial_exurl );
         add_ssh( $xml_ref->{handle}, $xml_ref->{execution}{url} );
+# Copy a configuration
+if($option_copy) {
+    my $input_directory = "$dotswift_directory/sites/$option_copy";
+    my $input_site = "$input_directory/sites.xml";
+    if( !-e $input_site) {
+        die "Unable to find configuration for $option_copy\n";
+    my $new_config_name = get_entry( 'New Configuration Name', '', 0);
+    my $output_directory = "$dotswift_directory/sites/$new_config_name";
+    if(-d "$output_directory") {
+        die "Configuration for $new_config_name already exists\n";
+    create_directory($output_directory);
+    my @files_to_copy = <$input_directory/*>;
+    foreach my $file_to_copy (@files_to_copy) {
+        copy( $file_to_copy, "$output_directory" )
+            || die "Unable to copy $file_to_copy to $output_directory\n";
+    # Rename and save
+    my $xml_ref = $xml->XMLin(
+        $xml_filename,
+        ForceArray => [qw(workdirectory profile)],
+        KeyAttr    => [],
+    $xml_ref->{handle} = $new_config_name;
+    my $xml_out_ref = $xml->XMLout(
+        $xml_ref,
+        RootName      => 'pool',
+        SuppressEmpty => 1,
+    write_file( "$output_directory/sites.xml", $xml_out_ref );
+    # Edit sites
+    my $initial_exurl = $xml_ref->{execution}{url};
+    $xml_ref = update_xml( "$output_directory/sites.xml", 1);
+    my $new_exurl = $xml_ref->{execution}{url};
+    $xml_out_ref = $xml->XMLout(
+        $xml_ref,
+    # Update tc
+    my $tc_filename = "$output_directory/tc.data";
+    update_tc_hostname( "$tc_filename", $new_config_name );
+    # Add ssh entries as needed
+    if ( $xml_ref->{execution}{provider} eq 'ssh' ) {
+        add_ssh( $xml_ref->{handle}, $xml_ref->{execution}{url} );
 __END__
 =head1 NAME
@@ -527,33 +572,27 @@
 =head1 DESCRIPTION
 General operations:
-   -add sitename	add a site from template
-   -remove site	removes a site from sites.xml
-   -templates		display all available sites in template
-   -modify site	Specifies the name of a site to modify
-   -describe site   Prints the raw XML site configuration
+   -template sitename	Add a configuration based on a template
+   -remove site	     Removes a site configuration
+   -templates		     Display all available templates
+   -sites                Displays all existing configurations
+   -edit site	          Specifies the name of a configuration to edit
+   -describe site        Prints the raw XML site configuration
+   -copy site            Copies a configuration
+   -default              Do not prompt for values, always use defaults
+   -full                 Edit every available configuration option
 =head1 EXAMPLES
 List all templates available for adding
    swiftconfig -templates
-Add a site from template into working sites.xml
-   swiftconfig -add teraport
+Add a site from template into a working configuration
+   swiftconfig -template ssh
-Modify the work directory of a site
-   swiftconfig -modify teraport
+Edit a configuration
+   swiftconfig -edit teraport
 Remove a site
    swiftconfig -remove teraport
-=head1 CAVEATS
-Swiftconfig will attempt to automatically determine the location of swift
-configuration files. It first checks for an environment variable called
-$SWIFT_HOME. If that is not found, it will look for the location of "swift"
-in the path.
-The XML library that swiftconfig uses ignores comments in XML. All comments
-will be stripped from sites.xml as it gets modified.
 =cut
Modified: usertools/swift/swiftconfig/bin/swiftrun
--- usertools/swift/swiftconfig/bin/swiftrun	2010-08-13 05:12:44 UTC (rev 3529)
+++ usertools/swift/swiftconfig/bin/swiftrun	2010-08-13 15:43:27 UTC (rev 3530)
@@ -10,6 +10,7 @@
 use Getopt::Long qw(:config permute pass_through);
 use File::Which qw(which where);
 use XML::Simple;
+use Pod::Usage;
 # Figure out the path to Swift
@@ -83,6 +84,7 @@
     'site|sites=s{,}'   => \@option_sites,
     'script=s'          => \$option_script,
     'input|inputs=s{,}' => \@option_inputs,
@@ -184,3 +186,41 @@
 # Execute
 system($system_command);
+__END__
+=head1 NAME
+swiftrun - Run swift using configurations generated by swiftconfig
+=head1 SYNOPSIS
+swiftrun [B<-option> value]
+=head1 OVERVIEW
+The swiftrun program allows you to execute swift using configurations
+generated by swiftconfig.
+=head1 DESCRIPTION
+General operations:
+   -site <site1 site2>	Execute swift on given sitename(s)
+   -script file.swift	Specify the swift script to run
+   -input <file1 file2>  Link to data required for execution
+=head1 EXAMPLES
+Run a script on a single site
+   swiftrun -site local -script my.script
+Run a script on multiple sites
+   swiftrun -site host1 host2 -script my.script
+Run a script on all available configurations
+    swiftrun -site all -script my.script
+Link multiple files
+   swiftrun -site local -script my.script -input /foo/file* /foo2/file*
+=cut
Modified: usertools/swift/swiftconfig/etc/TODO
--- usertools/swift/swiftconfig/etc/TODO	2010-08-13 05:12:44 UTC (rev 3529)
+++ usertools/swift/swiftconfig/etc/TODO	2010-08-13 15:43:27 UTC (rev 3530)
@@ -2,9 +2,6 @@
 In the short term, re-add ability to edit TC file with an interactive editor
 Longer term, eliminate TC and search PATH instead
-Non-Swiftrun related command line arguments should be passed on to be handled
-by swift
 Running and testing on more setups, OSG, teragrid, others
 Job tagging with search capabilities
@@ -12,9 +9,6 @@
 Ability to create groups of related sites for runs, ability to run on all
 sites (-site all, -site mygroup, etc)
-Bypass swift shell script
 Have swiftrun be flexible enough to work for new users, as well as advanced users
-Add a -link or similar option to create symlinks to input data within run directory
 Add -help or similar
