[Swift-commit] r3521 - in trunk: . bin
noreply at svn.ci.uchicago.edu
Tue Aug 10 23:50:29 CDT 2010
Author: davidk
Date: 2010-08-10 23:50:29 -0500 (Tue, 10 Aug 2010)
New Revision: 3521
Added:
trunk/bin/swift
trunk/bin/swift.bat
Modified:
trunk/build.xml
trunk/launchers.xml
Log:
Swift usage statistics
Added: trunk/bin/swift
--- trunk/bin/swift (rev 0)
+++ trunk/bin/swift 2010-08-11 04:50:29 UTC (rev 3521)
@@ -0,0 +1,152 @@
+#! /bin/sh
+EXEC=org.griphyn.vdl.karajan.Loader
+OPTIONS=
+CYGWIN=
+CPDELIM=":"
+HEAPMAX=256M
+if echo `uname` | grep -i "cygwin"; then
+ CYGWIN="yes"
+ CPDELIM=";"
+fi
+fixCommandLine() {
+ COMMANDLINE=
+ while [ "X$1" != "X" ] ; do
+ COMMANDLINE="${COMMANDLINE} '$1'"
+ shift
+ done
+ echo $COMMANDLINE
+updateOptions() {
+ if [ "X$1" != "X" ] ; then
+ OPTIONS="$OPTIONS -D$2=$1"
+ fi
+####### MAIN BODY ##########
+if [ ! -d "$SWIFT_HOME" ] ; then
+ SWIFT_HOME=`dirname $0`"/.."
+ if [ ! -f "$SWIFT_HOME/lib/cog-swift-svn.jar" ] && [ ! -f "$SWIFT_HOME/lib/cog.jar" ] ; then
+ MY_PATH=`which $0`
+ SWIFT_HOME=`dirname $MY_PATH`"/.."
+ echo "Error: SWIFT_HOME is not set, and all attempts at guessing it failed"
+ exit
+ fi
+ fi
+fi
+OPTIONS="$OPTIONS -Djava.endorsed.dirs=$SWIFT_HOME/lib/endorsed"
+LOCALCLASSPATH=$SWIFT_HOME/etc$CPDELIM$SWIFT_HOME/libexec
+for JAR in $SWIFT_HOME/lib/*.jar; do
+ LOCALCLASSPATH="$LOCALCLASSPATH$CPDELIM$JAR"
+done
+LOCALCLASSPATH=$LOCALCLASSPATH$CPDELIM$CLASSPATH
+CMDLINE=`fixCommandLine "$@"`
+### SETUP OTHER ENV VARIABLES ####
+USERID=`id | awk '{printf("%s\n", substr($1, 5, index($1, "(")-5 ) ) }'`
+if [ "X$GLOBUS_HOSTNAME" = "X" ] && [ "X$HOSTNAME" != "X" ]; then
+ GLOBUS_HOSTNAME=$HOSTNAME
+fi
+updateOptions "$USERID" "UID"
+updateOptions "$GLOBUS_INSTALL_PATH" "GLOBUS_INSTALL_PATH"
+updateOptions "$GLOBUS_DEPLOY_PATH" "GLOBUS_DEPLOY_PATH"
+updateOptions "$GLOBUS_TCP_PORT_RANGE" "GLOBUS_TCP_PORT_RANGE"
+updateOptions "$GLOBUS_TCP_SOURCE_PORT_RANGE" "GLOBUS_TCP_SOURCE_PORT_RANGE"
+updateOptions "$GLOBUS_UDP_SOURCE_PORT_RANGE" "GLOBUS_UDP_SOURCE_PORT_RANGE"
+updateOptions "$GLOBUS_HOSTNAME" "GLOBUS_HOSTNAME"
+updateOptions "$X509_USER_CERT" "X509_USER_CERT"
+updateOptions "$X509_USER_KEY" "X509_USER_KEY"
+updateOptions "$X509_CERT_DIR" "X509_CERT_DIR"
+updateOptions "$X509_USER_PROXY" "X509_USER_PROXY"
+updateOptions "$SWIFT_HOME" "COG_INSTALL_PATH"
+updateOptions "$SWIFT_HOME" "swift.home"
+#Use /dev/urandom instead of /dev/random for seeding RNGs
+#This will lower the randomness of the seed, but avoid
+#large delays if /dev/random does not have enough entropy collected
+updateOptions "file:///dev/urandom" "java.security.egd"
+if [ "X$HEAPMAX" != "X" ]; then
+ OPTIONS="-Xmx$HEAPMAX $OPTIONS"
+fi
+# Anonymous usage statistics
+LISTENER="bridled.ci.uchicago.edu"
+PORT="9999"
+if [ -z "$SWIFT_USAGE_STATS" ]; then
+ SWIFT_USAGE_STATS=1
+fi
+# To disable usage statistics, uncomment the line below
+#SWIFT_USAGE_STATS=0
+PATH=$PATH:/sbin
+IFCONFIG=`which ifconfig`
+if [ -x "$IFCONFIG" ]; then
+ MAC=`$IFCONFIG |grep HWaddr`
+fi
+MD5SUM=`which md5sum`
+if [ ! -x "$MD5SUM" ]; then
+ echo "warning: unable to find md5sum"
+ SWIFT_USAGE_STATS=0
+fi
+NC=`which nc`
+if [ ! -x "$NC" ]; then
+ echo "warning: unable to find nc"
+fi
+if [ "$SWIFT_USAGE_STATS" = 1 ]; then
+ for var in "$@"
+ do
+ SCRIPT=`echo $var|grep -i .swift`
+ if [ -e "$SCRIPT" ]; then
+ SCRIPT=$var
+ SCRIPTID=`$MD5SUM $SCRIPT|cut -d ' ' -f1`
+ SCRIPTLENGTH=`wc -l $SCRIPT|cut -d ' ' -f1`
+ fi
+ done
+ HOSTNAME=`hostname`
+ USERID=`echo $USERID $HOSTNAME $MAC | $MD5SUM |cut -d ' ' -f1`
+ DATE=`date`
+ KEY=`echo $USERID $DATE $$ | $MD5SUM | cut -d ' ' -f1`
+ echo $KEY $USERID $SCRIPTID $SCRIPTLENGTH -1 0| $NC -u $LISTENER $PORT
+fi
+### EXECUTE ############
+if test -n "$CYGWIN"; then
+ set CLASSPATHSAVE=$CLASSPATH
+ export CLASSPATH="$LOCALCLASSPATH"
+ eval java ${OPTIONS} ${COG_OPTS} ${EXEC} ${CMDLINE}
+ export CLASSPATH=$CLASSPATHSAVE
+else
+ eval java ${OPTIONS} ${COG_OPTS} -classpath ${LOCALCLASSPATH} ${EXEC} ${CMDLINE}
+fi
+return_code=$?
+ echo $KEY $USERID $SCRIPTID $SCRIPTLENGTH $return_code 1| $NC -u $LISTENER $PORT
+fi
+exit $return_code
Property changes on: trunk/bin/swift
___________________________________________________________________
Added: trunk/bin/swift.bat
--- trunk/bin/swift.bat (rev 0)
+++ trunk/bin/swift.bat 2010-08-11 04:50:29 UTC (rev 3521)
@@ -0,0 +1,78 @@
+ at echo off
+if "X%SWIFT_HOME%" == "X" goto nocogpath
+goto cogpath
+:nocogpath
+ set UNSET_SWIFT_HOME=1
+ set SWIFT_HOME=..
+ if NOT EXIST "%SWIFT_HOME%\lib\cog-swift-svn.jar" goto nocogpath15
+ goto cogpath
+:nocogpath15
+ if NOT EXIST "%SWIFT_HOME%\lib\cog.jar" goto nocogpath2
+ goto cogpath
+:nocogpath2
+ rem test for expansion extensions first, so that we don't enter an infinite loop
+ set PARTIAL_PATH=test
+ set PARTIAL_PATH=%PARTIAL_PATH:~-2%
+ if NOT "%PARTIAL_PATH%" == "st" goto nocogpath3
+ set PARTIAL_PATH=%~f0
+ set FIRST_BACKSLASH=1
+:loop
+ set LAST_CHAR=%PARTIAL_PATH:~-1%
+ set PARTIAL_PATH=%PARTIAL_PATH:~0,-1%
+ if "%LAST_CHAR%" == "\" goto found
+ if "X%PARTIAL_PATH%" == "X" goto nocogpath3
+ goto loop
+:found
+ if "%FIRST_BACKSLASH%" == "0" goto found2
+ set FIRST_BACKSLASH=0
+ goto loop
+:found2
+ set SWIFT_HOME=%PARTIAL_PATH%
+ if NOT EXIST "%SWIFT_HOME%\lib\cog-swift-svn.jar" goto nocogpath25
+ goto cogpath
+:nocogpath25
+ if NOT EXIST "%SWIFT_HOME%\lib\cog.jar" goto nocogpath3
+ goto cogpath
+:nocogpath3
+ echo Error: SWIFT_HOME not set and all attempts at guessing it failed
+ goto end
+:cogpath
+ set OPTS=-DCOG_INSTALL_PATH="%SWIFT_HOME%" -Dswift.home="%SWIFT_HOME%"%COG_OPTS% -Djava.endorsed.dirs="%SWIFT_HOME%\lib\endorsed"
+ set LOCALCLASSPATH=%CLASSPATH%;%SWIFT_HOME%\etc;%SWIFT_HOME%\libexec
+ for %%J in ("%SWIFT_HOME%\lib\*.jar") DO call :setpath %%J
+ set SAVECLASSPATH=%CLASSPATH%
+ set CLASSPATH=%LOCALCLASSPATH%
+ java %OPTS% org.griphyn.vdl.karajan.Loader %*
+ set CLASSPATH=%SAVECLASSPATH%
+:end
+ if "%UNSET_SWIFT_HOME%"=="1" goto restore
+ goto done
+:setpath
+ set LOCALCLASSPATH=%LOCALCLASSPATH%;%*
+ goto done
+:restore
+ set SWIFT_HOME=
+ set PARTIAL_PATH=
+ set LAST_CHAR=
+ set FIRST_BAKSLASH=
+:done
Modified: trunk/build.xml
--- trunk/build.xml 2010-08-10 21:32:56 UTC (rev 3520)
+++ trunk/build.xml 2010-08-11 04:50:29 UTC (rev 3521)
@@ -213,45 +213,6 @@
<copy todir="${dist.dir}/etc"
file="${cog.dir}/modules/${module.name}/etc/log4j.properties"
overwrite="true"/>
- <replace file="${dist.dir}/bin/swift">
- <replacetoken>COG_INSTALL_PATH</replacetoken>
- <replacevalue>SWIFT_HOME</replacevalue>
- </replace>
- <replacetoken>LOCALCLASSPATH=$SWIFT_HOME/etc</replacetoken>
- <replacevalue>LOCALCLASSPATH=$SWIFT_HOME/etc$CPDELIM$SWIFT_HOME/libexec</replacevalue>
- </replace>
- <replacetoken>HEAPMAX=
-</replacetoken>
- <replacevalue>HEAPMAX=256M
-</replacevalue>
- </replace>
- <replacetoken>updateOptions "$SWIFT_HOME" "SWIFT_HOME"
-</replacetoken>
- <replacevalue>updateOptions "$SWIFT_HOME" "COG_INSTALL_PATH"
-updateOptions "$SWIFT_HOME" "swift.home"
-#Use /dev/urandom instead of /dev/random for seeding RNGs
-#This will lower the randomness of the seed, but avoid
-#large delays if /dev/random does not have enough entropy collected
-updateOptions "file:///dev/urandom" "java.security.egd"
-</replacevalue>
- </replace>
- <replace file="${dist.dir}/bin/swift.bat">
- </replace>
- <replacetoken>set LOCALCLASSPATH=%CLASSPATH%;%SWIFT_HOME%\etc</replacetoken>
- <replacevalue>set LOCALCLASSPATH=%CLASSPATH%;%SWIFT_HOME%\etc;%SWIFT_HOME%\libexec</replacevalue>
- </replace>
- <replacetoken>set OPTS=</replacetoken>
- <replacevalue>set OPTS=-DCOG_INSTALL_PATH="%SWIFT_HOME%" -Dswift.home="%SWIFT_HOME%"</replacevalue>
- </replace>
<chmod perm="+x" file="${dist.dir}/bin/swift"/>
<chmod perm="+x" file="${dist.dir}/bin/swift-osg-ress-site-catalog"/>
<chmod perm="+x" file="${dist.dir}/libexec/cdm_broadcast.sh"/>
Modified: trunk/launchers.xml
--- trunk/launchers.xml 2010-08-10 21:32:56 UTC (rev 3520)
+++ trunk/launchers.xml 2010-08-11 04:50:29 UTC (rev 3521)
@@ -1,7 +1,5 @@
<project name="Launchers" default="create" basedir=".">
<target name="create">
- <delete file="${dist.dir}/bin/swift.bat"/>
- <delete file="${dist.dir}/bin/swift"/>
<ant antfile="${main.buildfile}" target="launcher">
<property name="launcher-name" value="VDLx2Karajan"/>
<property name="class-name" value="org.griphyn.vdl.engine.Karajan"/>
@@ -10,10 +8,6 @@
<property name="launcher-name" value="VDLt2VDLx"/>
<property name="class-name" value="org.griphyn.vdl.toolkit.VDLt2VDLx"/>
</ant>
- <ant antfile="${main.buildfile}" target="launcher">
- <property name="launcher-name" value="swift"/>
- <property name="class-name" value="org.griphyn.vdl.karajan.Loader"/>
- </ant>
</target>
<target name="webstart">
</target>
More information about the Swift-commit
