[Swift-commit] r3509 - trunk/tests
noreply at svn.ci.uchicago.edu
Tue Aug 10 14:19:16 CDT 2010
Author: wozniak
Date: 2010-08-10 14:19:16 -0500 (Tue, 10 Aug 2010)
New Revision: 3509
Modified:
trunk/tests/nightly.sh
Log:
Handle stdout, more docs
Modified: trunk/tests/nightly.sh
--- trunk/tests/nightly.sh 2010-08-10 19:18:00 UTC (rev 3508)
+++ trunk/tests/nightly.sh 2010-08-10 19:19:16 UTC (rev 3509)
@@ -10,6 +10,14 @@
# Everything for a Swift test is written in its RUNDIR
# The temporary output always goes to OUTPUT (TOPDIR/exec.out)
+# Each *.swift test may be accompanied by a
+# *.setup.sh, *.check.sh, and/or *.clean.sh script
+# These may setup and inspect files in RUNDIR including swift.out
+# OUTPUT is the stdout of the current test
+# stdout.txt retains stdout from the previous test (for *.clean.sh)
+# output_*.txt is the HTML-linked permanent output from a test
printhelp() {
echo "nightly.sh <options> <output>"
echo ""
@@ -90,7 +98,7 @@
RUNDIR=$TOPDIR/$RUNDIRBASE
LOGBASE=$RUNDIRBASE/tests.log
LOG=$TOPDIR/$LOGBASE
-OUTPUT=$TOPDIR/exec.out
+OUTPUT=$RUNDIR/exec.out
HTMLPATH=$RUNDIRBASE/tests-$DATE.html
HTML=$TOPDIR/$HTMLPATH
@@ -339,13 +347,14 @@
echo $WIDTH
-# TLOG = this (current) log
-tlog() {
+# TLOG = test log
+test_log() {
TLOG="output_$LOGCOUNT.txt"
rm -fv $TLOG
banner "$LASTCMD" $RUNDIR/$TLOG
if [ -f $OUTPUT ]; then
cp -v $OUTPUT $RUNDIR/$TLOG 2>>$LOG
+ cp -v $OUTPUT stdout.txt
fi
let "LOGCOUNT=$LOGCOUNT+1"
@@ -411,7 +420,7 @@
echo "Executing $TEST (part $SEQ)"
aexec "$@"
RESULT=$( result )
- tlog
+ test_log
out test $SEQ "$LASTCMD" $RESULT $TLOG
check_bailout
@@ -427,7 +436,7 @@
aexec $SCRIPT
RESULT=$( result )
- tlog
+ test_log
out test "$SYMBOL" "$LASTCMD" $RESULT
check_bailout
More information about the Swift-commit
