[Swift-commit] r3501 - usertools/swift/swiftconfig/bin
    noreply at svn.ci.uchicago.edu
    Mon Aug  9 21:11:28 CDT 2010
Author: davidk
Date: 2010-08-09 21:11:28 -0500 (Mon, 09 Aug 2010)
New Revision: 3501
Modified:
   usertools/swift/swiftconfig/bin/swiftconfig
   usertools/swift/swiftconfig/bin/swiftrun
Log:
Better handling of auth.defaults
Modified: usertools/swift/swiftconfig/bin/swiftconfig
--- usertools/swift/swiftconfig/bin/swiftconfig	2010-08-08 21:06:36 UTC (rev 3500)
+++ usertools/swift/swiftconfig/bin/swiftconfig	2010-08-10 02:11:28 UTC (rev 3501)
@@ -1,5 +1,6 @@
-#!/usr/bin/perl
+#!/usr/bin/perl -w
+use strict;
 use Cwd;
 use Cwd qw(abs_path);
 use File::Copy;
@@ -11,7 +12,7 @@
 my @execution_path = split( '/', abs_path($0) );
-my @execution_path = splice( @execution_path, 0, $#execution_path - 1 );
+ at execution_path = splice( @execution_path, 0, $#execution_path - 1 );
 my $parent_directory = join( '/', @execution_path );
 if ( !$swift_home ) {
@@ -37,12 +38,12 @@
 use Data::Dumper;
 # Variables used for translation catalog
-my $tc_host     = 'localhost';         # Host name
-my $tc_name     = q{};                 # Translation name
-my $tc_path     = "/usr/bin/$name";    # Full path of executable location
-my $tc_status   = 'INSTALLED';         # Installation status (not used)
-my $tc_platform = 'INTEL32::LINUX';    # Platform (not used)
-my $tc_profile  = 'null';              # Profile entries
+#my $tc_host     = 'localhost';         # Host name
+#my $tc_name     = q{};                 # Translation name
+#my $tc_path     = "/usr/bin/$name";    # Full path of executable location
+#my $tc_status   = 'INSTALLED';         # Installation status (not used)
+#my $tc_platform = 'INTEL32::LINUX';    # Platform (not used)
+#my $tc_profile  = 'null';              # Profile entries
 # Variables used for sites.xml
 my $option_templates = q{};            # List all templates
@@ -50,9 +51,9 @@
 my $option_modify    = q{};            # Modify mode
 my $option_add       = q{};            # Add entry
 my $option_sites     = q{};            # List all usable sites
+my $option_describe  = q{};            # Print raw XML configuration
 my @execution_providers =
     ( "gt4", "local", "pbs", "condor", "ssh", "coaster", );
-my $key_file = "$ENV{'HOME'}/.ssh/id_rsa";
 # Assign variables from command line options
 GetOptions(
@@ -67,7 +68,7 @@
 # Create a new directory if it does not exist
 sub create_directory {
-    $directory = $_[0];
+    my $directory = $_[0];
     if ( !-d "$directory" ) {
         mkdir "$directory", 0700
             or die "Unable to create directory $directory\n";
@@ -101,7 +102,7 @@
             print 'Invalid value selected. Please select from: '
                 . "$error_message\n";
             $entry_value = get_entry( $entry_description, $entry_value,
-                @allowable_entry_values, );
+                @allowable_values, );
@@ -118,72 +119,91 @@
 create_directory("$dotswift_directory/sites");
 # Determine the template directory
-my @execution_path = split( '/', abs_path($0) );
+ at execution_path = split( '/', abs_path($0) );
 my $template_directory = join( '/', @execution_path ) . '/etc/sites';
 # Add new entry to auths.default
 sub add_ssh {
     my ( $ssh_site, $ssh_url) = @_;
     # Open authfile
-    my $auth_file = "$dotswift_directory/sites/$ssh_site/auth.defaults";
-    create_directory("$dotswift_directory/sites/$ssh_site");
-    if ( -e "$auth_file" ) {
-        open( AUTH_FILE, "$auth_file" )
-            || die "Unable to open auth file $auth_file for reading!\n";
+    my $auth_file = "$ENV{'HOME'}/.ssh/auth.defaults";
+    if( -e "$auth_file") {
+        open( AUTH_FILE, "<$auth_file")
+            || die "Unable to open $auth_file for reading\n";
     else {
-        open( AUTH_FILE, ">$auth_file" )
-            || die "Unable to open $auth_file for writing!\n";
+        open( AUTH_FILE, "+>$auth_file" )
+            || die "Unable to open $auth_file for read/write!\n";
     my @auth_data = <AUTH_FILE>;
     close(AUTH_FILE);
-    # Create RSA keypair if needed
-    #my $keyfile = "$ENV{'HOME'}/.ssh/auth.defaults";
-    #if ( !-e "$keyfile" ) {
-    #    system("ssh-keygen -t rsa -f $keyfile");
-    # Get existing username and passphrase values
+    # Get existing values and modify if found
     my $ssh_username;
-    my $ssh_passphrase;
+    my $ssh_password;
+    my $found = 0;
     foreach (@auth_data) {
-        if (/username/i) {
-            ( my $not_used, $ssh_username, ) = split( '=', $_ );
+        if (/username/i && /^$ssh_url/i) {
+            ( my $setting, $ssh_username, ) = split( '=', $_ );
             chomp($ssh_username);
+            $ssh_username = get_entry( 'Username',   $ssh_username );
+            $_ = "$ssh_url.username=$ssh_username\n";
+            $found = 1;
-        if (/passphrase/i) {
-            ( my $not_used, $ssh_passphrase, ) = split( '=', $_ );
-            chomp($ssh_passphrase);
+        if (/\.password/i && /^$ssh_url/i) {
+            ( my $setting, $ssh_password, ) = split( '=', $_ );
+            chomp($ssh_password);
+            $ssh_password = get_entry( 'Password', $ssh_password );
+            $_ = "$ssh_url.password=$ssh_password\n";
+            $found = 1;
-    if ( !$ssh_username ) {
+    # Add new entry if needed
+    if(!$found) {
         $ssh_username = getlogin();
-    $ssh_username   = get_entry( 'Username',   $ssh_username );
-    $ssh_passphrase = get_entry( 'Passphrase', $ssh_passphrase );
+        $ssh_password = get_entry( 'Password', '');
-    # Remove old auth.defaults if it already exists
-        unlink($auth_file) || die "Unable to remove $auth_file\n";
-        @auth_data = ();
+        # Password based authentication
+        push( @auth_data, "$ssh_url.type=password\n" );
+        push( @auth_data, "$ssh_url.username=$ssh_username\n" );
+        push( @auth_data, "$ssh_url.password=$ssh_password\n" );
-    # Key based authentication
-    #push( @authdata, "$site.type=key\n" );
-    #push( @authdata, "$site.username=$username\n" );
-    #push( @authdata, "$site.key=$keyfile\n" );
-    #push( @authdata, "$site.passphrase=$passphrase\n" );
-    # Password based authentication
-    push( @auth_data, "$ssh_url.type=password\n" );
-    push( @auth_data, "$ssh_url.username=$ssh_username\n" );
-    push( @auth_data, "$ssh_url.password=$ssh_passphrase\n" );
+    # Write data
     write_file( $auth_file, @auth_data );
+# Remove an entry from auth.defaults
+sub remove_ssh {
+    my ( $ssh_url, ) = @_;
+    # Open auth.defaults
+    else {
+        return;
+    my @auth_data = <AUTH_FILE>;
+    close(AUTH_FILE);
+    # Remove
+    foreach (@auth_data) {
+        if (/^$ssh_url/i) {
+            $_ = '';
+    # Write data
+    write_file( $auth_file, @auth_data );
 # Update TC with correct hostname
 sub update_tc_hostname {
     my ( $tc_filename, $tc_host ) = @_;
@@ -191,10 +211,10 @@
     # Store TC data
     open( TC_FILESTREAM, "$tc_filename" )
         or die("Unable to open tc file $tc_filename!");
-    @tc_data = <TC_FILESTREAM>;
+    my @tc_data = <TC_FILESTREAM>;
     close(TC_FILESTREAM);
-    foreach $line (@tc_data) {
+    foreach my $line (@tc_data) {
         # Ignore comments
         my $first_character = substr( $line, 0, 1 );
@@ -277,7 +297,7 @@
             $xml_ref->{execution}{provider} = get_entry(
                 'Execution Provider',
                 $xml_ref->{execution}{provider},
-                @validproviders
+                @execution_providers,
         if ( $xml_ref->{execution}{jobmanager} ) {
@@ -298,7 +318,7 @@
             $xml_ref->{filesystem}{provider} = get_entry(
                 'Filesystem Provider',
                 $xml_ref->{filesystem}{provider},
-                @validproviders
         if ( $xml_ref->{filesystem}{url} ) {
@@ -331,7 +351,7 @@
     chdir($directory)
         || die "Unable to change directories to $directory\n";
     my @files = <*>;
-    foreach $file (@files) {
+    foreach my $file (@files) {
         ( my $basename, my $ext ) = split( /\./, $file );
         my @path = split( '/', $basename );
         print "$basename\n";
@@ -361,9 +381,9 @@
     # Update and copy files to reflect input
     my @files_to_copy = <$from_directory/*>;
     create_directory("$output_directory");
-    foreach $file_to_copy (@files_to_copy) {
+    foreach my $file_to_copy (@files_to_copy) {
         copy( $file_to_copy, "$output_directory" )
-            || die "Unable to copy to $file to $output_directory\n";
+            || die "Unable to copy to $file_to_copy to $output_directory\n";
     my $xml_out_ref = $xml->XMLout(
         $xml_ref,
@@ -394,11 +414,22 @@
 # Remove an entry
 if ($option_remove) {
+    my $xml_filename = "$dotswift_directory/sites/$option_remove/sites.xml";
+    my $xml_ref = $xml->XMLin(
+        $xml_filename,
+        ForceArray => [qw(workdirectory profile)],
+        KeyAttr    => [],
+    # Remove SSH entry if needed
+    if($xml_ref->{execution}{provider} eq "ssh") {
+        remove_ssh($xml_ref->{execution}{url});
+    # Remove directory
     if ( !-d "$dotswift_directory/sites/$option_remove" ) {
-        "Unable to find site entry for $option_remove\n";
+        die "Unable to find site entry for $option_remove\n";
     rmtree("$dotswift_directory/sites/$option_remove")
         || die 'Unable to remove directory '
         . "$dotswift_directory/sites/$option_remove\n";
@@ -417,15 +448,25 @@
 # Modify a site entry
 if ($option_modify) {
     my $output_directory = "$dotswift_directory/sites/$option_modify";
-    my $sites_file       = "$output_directory/sites.xml";
+    create_directory($output_directory);
+    my $sites_file = "$output_directory/sites.xml";
     if ( !-e "$sites_file" ) {
         die "Unable to find configuration for $option_modify\n";
-    my $xml_ref      = update_xml("$sites_file");
+    my $xml_filename = "$dotswift_directory/sites/$option_modify/sites.xml";
+        $xml_filename,
+        KeyAttr    => [],
+    my $initial_exurl = $xml_ref->{execution}{url};
+    $xml_ref = update_xml("$sites_file");
+    my $new_exurl = $xml_ref->{execution}{url};
     my $new_sitename = $xml_ref->{handle};
-    create_directory($output_directory);
         $xml_ref,
         RootName      => 'pool',
@@ -447,7 +488,11 @@
         update_tc_hostname( "$tc_filename", $new_sitename );
+    # Add/modify/remove ssh entries as needed
     if ( $xml_ref->{execution}{provider} eq 'ssh' ) {
+        if ( $initial_exurl ne $new_exurl ) {
+            remove_ssh( $initial_exurl );
         add_ssh( $xml_ref->{handle}, $xml_ref->{execution}{url} );
Modified: usertools/swift/swiftconfig/bin/swiftrun
--- usertools/swift/swiftconfig/bin/swiftrun	2010-08-08 21:06:36 UTC (rev 3500)
+++ usertools/swift/swiftconfig/bin/swiftrun	2010-08-10 02:11:28 UTC (rev 3501)
@@ -1,5 +1,6 @@
-#!/usr/bin/perl
+#!/usr/bin/perl -w
+use strict;
 use Cwd;
 use File::Copy;
@@ -11,7 +12,7 @@
 my @path = split( '/', abs_path($0) );
-my @path = splice( @path, 0, $#path - 1 );
+ at path = splice( @path, 0, $#path - 1 );
 my $parent_directory = join( '/', @path );
 if ( !$swifthome ) {
@@ -31,37 +32,42 @@
-          or die "Unable to create directory $directory\n";
+            or die "Unable to create directory $directory\n";
 # Append one file to another
 sub cat_file {
-    my ($src, $dst) = @_;
-    if(-e $dst){ open(DSTFILE, ">>$dst") or die "Unable to open $dst for append\n"; }
-    else { open(DSTFILE, ">$dst") or die "Unable to open $dst for writing\n"; }
-    open(SRCFILE, $src) || die "Unable to open $src for reading\n";
-    foreach $line(<SRCFILE>) {
+    my ( $src, $dst ) = @_;
+    if ( -e $dst ) {
+        open( DSTFILE, ">>$dst" ) or die "Unable to open $dst for append\n";
+    else {
+        open( DSTFILE, ">$dst" )
+            or die "Unable to open $dst for writing\n";
+    open( SRCFILE, $src ) || die "Unable to open $src for reading\n";
+    foreach my $line (<SRCFILE>) {
         print DSTFILE $line;
 # Copy a file to a new location
 sub copy_file {
-    if(!-e $src) { die "Unable to access $src\n"; }
-    if(!-e $dst) { die "Unable to access $dst\n"; }
-    copy($src, $dst) or die "Unable to copy $src to $dst\n";
+    if ( !-e $src ) { die "Unable to access $src\n"; }
+    if ( !-e $dst ) { die "Unable to access $dst\n"; }
+    copy( $src, $dst ) or die "Unable to copy $src to $dst\n";
 # Strip directory name out of script
 sub strip_directory {
     my ($fullpath) = @_;
-    my @path = split( '/', $fullpath);
-    my $filename = @path[$#path];
+    my @path = split( '/', $fullpath );
+    my $filename = $path[$#path];
     return $filename;
@@ -72,56 +78,61 @@
 use XML::Simple;
 use Data::Dumper;
+my $site;      # Site name to execute upon
+my $script;    # Script name to run
 GetOptions(
-	'site=s'     => \$site,
-     'script=s'   => \$script,
+    'site=s'   => \$site,
+    'script=s' => \$script,
 # Verify user-created profile info exists
-my ($seconds, $minutes, $hours, $days, $months, $years, @junk) = localtime(time);
-$datestring = sprintf "%04s%02s%02s%02s%02s%02s%s", $years+1900, $months+1, $days, $hours, $minutes, $seconds, getpgrp(0);
+my ( $seconds, $minutes, $hours, $days, $months, $years, @junk ) =
+    localtime(time);
+my $datestring = sprintf "%04s%02s%02s%02s%02s%02s%s", $years + 1900,
+    $months + 1, $days, $hours, $minutes, $seconds, getpgrp(0);
 my $dotswift = "$ENV{'HOME'}/.swift";
 # Run job
- at sites = split(/,/, $site);
+my @sites = split( /,/, $site );
 my $script_filename = strip_directory($script);
 create_directory("$dotswift/jobs");
 create_directory("$dotswift/jobs/$script_filename");
 create_directory("$dotswift/jobs/$script_filename/$datestring");
-copy_file("$script", "$dotswift/jobs/$script_filename/$datestring");
+copy_file( "$script", "$dotswift/jobs/$script_filename/$datestring" );
-# Temporarily rename existing auth.defaults
-if(-e "$ENV{'HOME'}/.ssh/auth.defaults") {
-    move("$ENV{'HOME'}/.ssh/auth.defaults", "$ENV{'HOME'}/.ssh/auth.defaults.$datestring") || die "Unable to rename $ENV{'HOME'}/.ssh/auth.defaults";
+# Create configuration file for run
+foreach my $s (@sites) {
+    if ( !-d "$dotswift/sites/$s" ) {
+        print "$dotswift/sites/$site\n";
+        die "Unable to find entry for $s\n";
+    if ( !-e "$dotswift/sites/$s/sites.xml" ) {
+        die "Unable to find sites.xml for $s\n";
+    if ( !-e "$dotswift/sites/$s/tc.data" ) {
+        die "Unable to find tc.data for $s\n";
+    cat_file( "$dotswift/sites/$s/sites.xml",
+        "$dotswift/jobs/$script_filename/$datestring/sites.xml" );
+    cat_file( "$dotswift/sites/$s/tc.data",
+        "$dotswift/jobs/$script_filename/$datestring/tc.data" );
-foreach my $s(@sites) {
-	if(!-d "$dotswift/sites/$s"){ print "$dotswift/sites/$site\n"; die "Unable to find entry for $s\n"; }
-	if(!-e "$dotswift/sites/$s/sites.xml"){ die "Unable to find sites.xml for $s\n"; }
-	if(!-e "$dotswift/sites/$s/tc.data"){ die "Unable to find tc.data for $s\n"; }
-    	cat_file("$dotswift/sites/$s/sites.xml", "$dotswift/jobs/$script_filename/$datestring/sites.xml");
-	cat_file("$dotswift/sites/$s/tc.data", "$dotswift/jobs/$script_filename/$datestring/tc.data");
-        if(-e "$dotswift/sites/$s/auth.defaults"){
-	    cat_file("$dotswift/sites/$s/auth.defaults", "$ENV{'HOME'}/.ssh/auth.defaults");
 # Update XML tags
-open(SITEFILE, "$dotswift/jobs/$script_filename/$datestring/sites.xml") || die "Unable to open $dotswift/jobs/$script_filename/$datestring/sites.xml\n";
+my $site_filename = "$dotswift/jobs/$script_filename/$datestring/sites.xml";
+open( SITEFILE, "$site_filename" ) || die "Unable to open $site_filename\n";
 my @sitedata = <SITEFILE>;
 close(SITEFILE);
-open(SITEFILE, ">$dotswift/jobs/$script_filename/$datestring/sites.xml") || die "Unable to open $dotswift/jobs/$script_filename/$datestring/sites.xml\n";
+open( SITEFILE, ">$site_filename" ) || die "Unable to open $site_filename\n";
 print SITEFILE "<config>\n at sitedata</config>\n";
 close(SITEFILE);
 # Run swift
-chdir("$dotswift/jobs/$script_filename/$datestring") || die "Unable to change directories to $dotswift/job/$script_filename/$datestring\n";
-print "Submitting job. Check $dotswift/jobs/$script_filename/$datestring for details\n";
-system("swift -sites.file $dotswift/jobs/$script_filename/$datestring/sites.xml -tc.file $dotswift/jobs/$script_filename/$datestring/tc.data $script");
+my $run_directory = "$dotswift/jobs/$script_filename/$datestring";
+chdir("$run_directory") || die "Unable to chdir to $run_directory\n";
+print "Submitting job. Check $run_directory for details\n";
+system(
+    "swift -sites.file $site_filename -tc.file $run_directory/tc.data $script"
-# Rename auths.default back to original
-if(-e "$ENV{'HOME'}/.ssh/auth.defaults.$datestring") {
-    move("$ENV{'HOME'}/.ssh/auth.defaults.$datestring", "$ENV{'HOME'}/.ssh/auth.defaults") || die "Unable to rename $ENV{'HOME'}/.ssh/auth.defaults.$datestring";
More information about the Swift-commit
