[Swift-commit] r2976 - trunk/src/org/griphyn/vdl/engine
noreply at svn.ci.uchicago.edu
Wed Jun 24 15:17:48 CDT 2009
Author: benc
Date: 2009-06-24 15:17:48 -0500 (Wed, 24 Jun 2009)
New Revision: 2976
Modified:
trunk/src/org/griphyn/vdl/engine/VariableScope.java
Log:
variable scope debugging info should be DEBUG not INFO log level
Modified: trunk/src/org/griphyn/vdl/engine/VariableScope.java
--- trunk/src/org/griphyn/vdl/engine/VariableScope.java 2009-06-24 20:17:20 UTC (rev 2975)
+++ trunk/src/org/griphyn/vdl/engine/VariableScope.java 2009-06-24 20:17:48 UTC (rev 2976)
@@ -54,9 +54,9 @@
public VariableScope(Karajan c, VariableScope parent, int a) {
if(parentScope!=null) {
- logger.info("New scope "+hashCode()+" with parent scope "+parentScope.hashCode());
+ logger.debug("New scope "+hashCode()+" with parent scope "+parentScope.hashCode());
} else {
- logger.info("New scope "+hashCode()+" with no parent.");
+ logger.debug("New scope "+hashCode()+" with no parent.");
compiler = c;
parentScope = parent;
@@ -75,7 +75,7 @@
declaration already exists. Perhaps error in same scope and
warning if it shadows an outer scope? */
public void addVariable(String name, String type) throws CompilationException {
- logger.info("Adding variable "+name+" of type "+type+" to scope "+hashCode());
+ logger.debug("Adding variable "+name+" of type "+type+" to scope "+hashCode());
if(isVariableDefined(name)) {
throw new CompilationException("Variable "+name+" is already defined.");
@@ -97,7 +97,7 @@
* an exception if the variable is defined in a parent scope
public void addInternalVariable(String name, String type) throws CompilationException {
- logger.info("Adding internal variable " + name + " of type " + type + " to scope " + hashCode());
+ logger.debug("Adding internal variable " + name + " of type " + type + " to scope " + hashCode());
if(isVariableLocallyDefined(name)) {
throw new CompilationException("Variable " + name + " is already defined.");
@@ -162,7 +162,7 @@
ld.setAttribute("waitfor", closeID);
} else {
- logger.info("Variable "+variableName+" is local but has no template.");
+ logger.debug("Variable "+variableName+" is local but has no template.");
StringTemplate postST = compiler.template("partialclose");
postST.setAttribute("var", variableName);
@@ -189,7 +189,7 @@
if(!statementList.contains(closeID)) {
statementList.add(closeID);
- logger.info("added "+closeID+" to variable "+variableName+" in scope "+hashCode());
+ logger.debug("added "+closeID+" to variable "+variableName+" in scope "+hashCode());
} else {
throw new CompilationException("variable "+variableName+" is not writeable in this scope");
@@ -211,21 +211,21 @@
if(decls instanceof StringTemplate) {
StringTemplate declST = (StringTemplate) decls;
if(declST.getAttribute("name").equals(name)) {
-logger.info("thats the declaration for "+name);
+ logger.debug("thats the declaration for "+name);
return declST;
} else { // assume its a List
Iterator it = ((List) decls).iterator();
while(it.hasNext()) {
StringTemplate declST = (StringTemplate) it.next();
-logger.info("looking at declaration "+declST);
+ logger.debug("looking at declaration "+declST);
try {
return declST;
} catch(java.util.NoSuchElementException nse) {
-logger.info("it so definitely wasn't in that one, we got an exception.");
+ logger.debug("it so definitely wasn't in that one, we got an exception.");
// TODO this is not a nice use of exceptions...
More information about the Swift-commit
