[Swift-commit] r2973 - in trunk: resources src/org/griphyn/vdl/engine
noreply at svn.ci.uchicago.edu
Mon Jun 22 12:00:46 CDT 2009
Author: benc
Date: 2009-06-22 12:00:46 -0500 (Mon, 22 Jun 2009)
New Revision: 2973
Modified:
trunk/resources/Karajan.stg
trunk/resources/swiftscript.xsd
trunk/src/org/griphyn/vdl/engine/Karajan.java
Log:
Remove isArray attribute from variables in the XML representation of
SwiftScript, because arrayness is stored in the type attribute now.
Modified: trunk/resources/Karajan.stg
--- trunk/resources/Karajan.stg 2009-06-22 16:57:12 UTC (rev 2972)
+++ trunk/resources/Karajan.stg 2009-06-22 17:00:46 UTC (rev 2973)
@@ -97,7 +97,7 @@
typecheck() ::= <<
-<vdl:typecheck argname="$it.name$" var="{$it.name$}" type="$it.type.name$"$if(it.isArray)$ isArray="true"$endif$/>
+<vdl:typecheck argname="$it.name$" var="{$it.name$}" type="$it.type.name$" />
vdl_execute(outputs,inputs,application,name,line) ::= <<
@@ -291,15 +291,15 @@
</global>
-variable(name,type,isArray,expr,mapping,nil,file,waitfor,datatype) ::= <<
+variable(name,type,expr,mapping,nil,file,waitfor,datatype) ::= <<
<set name="$name$">
$if(mapping)$
- <vdl:new type="$type$" dbgname="$name$"$if(isArray)$ isArray="true"$endif$$if(waitfor)$ waitfor="$waitfor;separator=" "$"$endif$>
+ <vdl:new type="$type$" dbgname="$name$"$if(waitfor)$ waitfor="$waitfor;separator=" "$"$endif$>
$vdl_mapping(mapping=mapping,file=file,waitfor=waitfor)$
</vdl:new>
$else$
$if(file)$
</vdl:new>
$else$
Modified: trunk/resources/swiftscript.xsd
--- trunk/resources/swiftscript.xsd 2009-06-22 16:57:12 UTC (rev 2972)
+++ trunk/resources/swiftscript.xsd 2009-06-22 17:00:46 UTC (rev 2973)
@@ -129,8 +129,6 @@
<xs:attribute name="type" type="xs:QName" use="required"/>
- <xs:attribute default="false" name="isArray" type="xs:boolean"/>
</xs:complexType>
<xs:complexType name="Binding">
@@ -302,8 +300,6 @@
<xs:attribute name="name" type="xs:NCName"/>
- <xs:attribute name="isArray" type="xs:boolean"/>
</xs:complexType>
<xs:complexType name="ActualParameter">
Modified: trunk/src/org/griphyn/vdl/engine/Karajan.java
--- trunk/src/org/griphyn/vdl/engine/Karajan.java 2009-06-22 16:57:12 UTC (rev 2972)
+++ trunk/src/org/griphyn/vdl/engine/Karajan.java 2009-06-22 17:00:46 UTC (rev 2973)
@@ -242,7 +242,6 @@
typeST.setAttribute("name", param.getType().getLocalPart());
typeST.setAttribute("namespace", param.getType().getNamespaceURI());
paramST.setAttribute("type", typeST);
- paramST.setAttribute("isArray", new Boolean(param.getIsArray1()));
if(!param.isNil())
paramST.setAttribute("default",expressionToKarajan(param.getAbstractExpression(), scope));
return paramST;
@@ -252,7 +251,6 @@
StringTemplate variableST = template("variable");
variableST.setAttribute("name", var.getName());
variableST.setAttribute("type", var.getType().getLocalPart());
- variableST.setAttribute("isArray", Boolean.valueOf(var.getIsArray1()));
checkIsTypeDefined(var.getType().getLocalPart());
if(!var.isNil()) {
More information about the Swift-commit
