[Swift-commit] r2969 - trunk/src/org/griphyn/vdl/mapping
noreply at svn.ci.uchicago.edu
Mon Jun 22 07:47:08 CDT 2009
Author: benc
Date: 2009-06-22 07:47:07 -0500 (Mon, 22 Jun 2009)
New Revision: 2969
Modified:
trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
Log:
FILENAME logs should only be output for file-mapped types, not for
externals, arrays, structs or primitive types.
Modified: trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java 2009-06-22 12:01:37 UTC (rev 2968)
+++ trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java 2009-06-22 12:47:07 UTC (rev 2969)
@@ -447,10 +447,30 @@
// anyway - should perhaps only be trying to map leafnodes?
// Mapping
// non-leaf stuff is giving wierd paths anyway
+// TODO this is perhaps an unpleasant way of finding if this is a file-backed
+// leaf node or not
+ boolean filemapped = true;
+ Type type = this.getType();
+ if(type.getName().equals("external")) {
+ filemapped = false;
+ if(type.isPrimitive()) {
+ if(type.isArray()) {
+ if(handles.size()>0) {
try {
- Object path = m.map(pathFromRoot);
- logger.info("FILENAME dataset=" + identifier + " filename="
+ if(filemapped) {
+ Object path = m.map(pathFromRoot);
+ logger.info("FILENAME dataset=" + identifier + " filename="
+ path);
catch (Exception e) {
logger.info("NOFILENAME dataset=" + identifier);
More information about the Swift-commit
