[Swift-commit] r2967 - in trunk: . libexec/log-processing tests/language-behaviour
Mon Jun 22 06:14:00 CDT 2009
Author: benc
Date: 2009-06-22 06:14:00 -0500 (Mon, 22 Jun 2009)
New Revision: 2967
Added:
   trunk/libexec/log-processing/log-to-internal-proc-transitions
Modified:
   trunk/build.xml
   trunk/libexec/log-processing/makefile
   trunk/tests/language-behaviour/run
Log:
Log processing for internal procedure provenance logs
Modified: trunk/build.xml
--- trunk/build.xml	2009-06-22 09:02:33 UTC (rev 2966)
+++ trunk/build.xml	2009-06-22 11:14:00 UTC (rev 2967)
@@ -154,6 +154,7 @@
 		<chmod perm="+x" file="${dist.dir}/libexec/log-processing/log-to-initshareddir-transitions"/>
 		<chmod perm="+x" file="${dist.dir}/libexec/log-processing/log-to-karatasks-transitions"/>
 		<chmod perm="+x" file="${dist.dir}/libexec/log-processing/log-to-compound-transitions"/>
+		<chmod perm="+x" file="${dist.dir}/libexec/log-processing/log-to-internal-proc-transitions"/>
 		<chmod perm="+x" file="${dist.dir}/libexec/log-processing/logs-for-all"/>
 		<chmod perm="+x" file="${dist.dir}/libexec/log-processing/lookup-colour"/>
 		<chmod perm="+x" file="${dist.dir}/libexec/log-processing/max-duration"/>
Added: trunk/libexec/log-processing/log-to-internal-proc-transitions
--- trunk/libexec/log-processing/log-to-internal-proc-transitions	                        (rev 0)
+++ trunk/libexec/log-processing/log-to-internal-proc-transitions	2009-06-22 11:14:00 UTC (rev 2967)
@@ -0,0 +1,17 @@
+#!/bin/bash
+# this will take a log file and produce a set of state transition
+# events for every internal procedure
+# 2009-05-04 18:02:15,499+0200 INFO  vdl:mains INTERNALPROC_START thread=0-1 name=trace
+# 2009-05-04 18:02:15,556+0200 INFO  vdl:mains INTERNALPROC_END thread=0-0
+grep ' INTERNALPROC_START ' $1 | iso-to-secs | \
+sed 's/^\(.*\) INFO  [^ ]* INTERNALPROC_START thread=\([0-9\-]*\) name=\([^ ]*\).*$/\1 \2 START \3/'
+grep ' INTERNALPROC_END ' $1 | iso-to-secs | \
+sed 's/^\(.*\) INFO  [^ ]* INTERNALPROC_END thread=\([0-9\-]*\).*$/\1 \2 END/'
Modified: trunk/libexec/log-processing/makefile
--- trunk/libexec/log-processing/makefile	2009-06-22 09:02:33 UTC (rev 2966)
+++ trunk/libexec/log-processing/makefile	2009-06-22 11:14:00 UTC (rev 2967)
@@ -100,6 +100,9 @@
 compound.transitions: $(LOG)
 	log-to-compound-transitions $(LOG) > compound.transitions
+internalproc.transitions: $(LOG)
+	log-to-internal-proc-transitions $(LOG) > internalproc.transitions
 ## retry analysis
 jobs.retrycount.summary: execute2.event
Modified: trunk/tests/language-behaviour/run
--- trunk/tests/language-behaviour/run	2009-06-22 09:02:33 UTC (rev 2966)
+++ trunk/tests/language-behaviour/run	2009-06-22 11:14:00 UTC (rev 2967)
@@ -90,9 +90,9 @@
   fi
   # check that all execute and execute2 IDs are unique
-  swift-plot-log ${t}-*.log execute.transitions compound.transitions
-  if [ "$( cat compound.transitions execute.transitions | grep ' START ' | cut -d ' ' -f 2 | sort | uniq -d)" != "" ]; then
-    echo EXECUTE AND COMPOUND IDS NOT UNIQUE
+  swift-plot-log ${t}-*.log execute.transitions compound.transitions internalproc.transitions
+  if [ "$( cat compound.transitions execute.transitions internalproc.transitions | grep ' START ' | cut -d ' ' -f 2 | sort | uniq -d)" != "" ]; then
+    echo EXECUTE AND COMPOUND AND INTERNALPROC IDS NOT UNIQUE
     exit 3
   fi
