[Swift-commit] r2964 - trunk/docs
Fri Jun 19 09:04:44 CDT 2009
Author: benc
Date: 2009-06-19 09:04:44 -0500 (Fri, 19 Jun 2009)
New Revision: 2964
Modified:
   trunk/docs/tutorial.xml
Log:
remove outdated references in tutorial that referred to examples/vdsk rather than examples/swift
Modified: trunk/docs/tutorial.xml
--- trunk/docs/tutorial.xml	2009-06-17 15:10:41 UTC (rev 2963)
+++ trunk/docs/tutorial.xml	2009-06-19 14:04:44 UTC (rev 2964)
@@ -44,7 +44,7 @@
 <section> <title>Hello World</title>
     <para>
 The first example program (found in the file
-<filename>examples/vdsk/first.swift</filename>)
+<filename>examples/swift/first.swift</filename>)
 outputs a hello world message into
 a file called <filename>hello.txt</filename>.
     </para>
@@ -66,7 +66,7 @@
 <para>We can run this program as follows:</para>
 <screen>
-$ <userinput>cd examples/vdsk/</userinput>
+$ <userinput>cd examples/swift/</userinput>
 $ <userinput>swift first.swift</userinput>
 Swift v0.2
