[Swift-commit] r2959 - in trunk/src/org/griphyn/vdl/karajan/lib: . swiftscript
Tue Jun 16 10:20:21 CDT 2009
Author: benc
Date: 2009-06-16 10:20:21 -0500 (Tue, 16 Jun 2009)
New Revision: 2959
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/VDLFunction.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractInt.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FileName.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FileNames.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FnArg.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
Log:
Add logging of provenance information for @functions.
Modified: trunk/src/org/griphyn/vdl/karajan/lib/VDLFunction.java
--- trunk/src/org/griphyn/vdl/karajan/lib/VDLFunction.java	2009-06-16 15:19:51 UTC (rev 2958)
+++ trunk/src/org/griphyn/vdl/karajan/lib/VDLFunction.java	2009-06-16 15:20:21 UTC (rev 2959)
@@ -572,4 +572,19 @@
 			return tc;
+	private static int provenanceIDCount = 451000;
+	public static synchronized int nextProvenanceID() {
+		return provenanceIDCount++;
+	public static void logProvenanceResult(int id, DSHandle result, String name) throws ExecutionException {
+		logger.info("FUNCTION id="+id+" name="+name+" result="+result.getIdentifier());
+	public static void logProvenanceParameter(int id, DSHandle parameter, String paramName) throws ExecutionException {
+		logger.info("FUNCTIONPARAMETER id="+id+" input="+parameter.getIdentifier()+" name="+paramName);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractInt.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractInt.java	2009-06-16 15:19:51 UTC (rev 2958)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractInt.java	2009-06-16 15:20:21 UTC (rev 2959)
@@ -35,7 +35,11 @@
 				String str = breader.readLine();
 				freader.close();
 				Double i = new Double(str);
-				return RootDataNode.newNode(Types.FLOAT, i);
+				DSHandle result = RootDataNode.newNode(Types.FLOAT, i);
+				int provid = VDLFunction.nextProvenanceID();
+				VDLFunction.logProvenanceResult(provid, result, "extractint");
+				VDLFunction.logProvenanceParameter(provid, handle, "filename");
+				return result;
 		catch (IOException ioe) {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FileName.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FileName.java	2009-06-16 15:19:51 UTC (rev 2958)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FileName.java	2009-06-16 15:20:21 UTC (rev 2959)
@@ -6,6 +6,7 @@
 import org.globus.cog.karajan.workflow.futures.FutureNotYetAvailable;
 import org.griphyn.vdl.karajan.VDL2FutureException;
 import org.griphyn.vdl.karajan.lib.VDLFunction;
+import org.griphyn.vdl.mapping.DSHandle;
 import org.griphyn.vdl.mapping.RootDataNode;
 import org.griphyn.vdl.type.Types;
@@ -17,7 +18,11 @@
 	public Object function(VariableStack stack) throws ExecutionException {
 		try {
 			String s = argList(filename(stack), true);
-			return RootDataNode.newNode(Types.STRING, s);
+			DSHandle result = RootDataNode.newNode(Types.STRING, s);
+			VDLFunction.logProvenanceParameter(provid, (DSHandle) PA_VAR.getValue(stack), "input");
+			VDLFunction.logProvenanceResult(provid, result, "filename");
+			return result;
 		} catch(VDL2FutureException ve) {
 			synchronized(ve.getHandle().getRoot()) {
 				throw new FutureNotYetAvailable(addFutureListener(stack, ve.getHandle()));
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FileNames.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FileNames.java	2009-06-16 15:19:51 UTC (rev 2958)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FileNames.java	2009-06-16 15:20:21 UTC (rev 2959)
@@ -31,6 +31,10 @@
 		} catch (InvalidPathException e) {
 			throw new ExecutionException("Unexpected invalid path exception",e);
+		logProvenanceParameter(provid, (DSHandle) PA_VAR.getValue(stack), "input");
+		logProvenanceResult(provid, returnArray, "filenames");
 		return returnArray;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FnArg.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FnArg.java	2009-06-16 15:19:51 UTC (rev 2958)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FnArg.java	2009-06-16 15:20:21 UTC (rev 2959)
@@ -15,9 +15,12 @@
 import org.globus.cog.karajan.workflow.ExecutionException;
 import org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction;
 import org.griphyn.vdl.karajan.lib.SwiftArg;
+import org.griphyn.vdl.karajan.lib.VDLFunction;
 public class FnArg extends AbstractFunction {
 	public static final String PARSED_ARGS = "cmdline:named";
@@ -65,7 +68,14 @@
 			throw new ExecutionException("Missing command line argument: " + name);
 		else {
-			return RootDataNode.newNode(Types.STRING, value);
+			DSHandle result = RootDataNode.newNode(Types.STRING, value);
+			int provid=VDLFunction.nextProvenanceID();
+			VDLFunction.logProvenanceResult(provid, result, "arg");
+			VDLFunction.logProvenanceParameter(provid, P_NAME.getRawValue(stack), "name");
+			if(P_VALUE.getRawValue(stack) != null) {
+				VDLFunction.logProvenanceParameter(provid, P_VALUE.getRawValue(stack), "value");
+			return result;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2009-06-16 15:19:51 UTC (rev 2958)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2009-06-16 15:20:21 UTC (rev 2959)
@@ -1,5 +1,7 @@
 package org.griphyn.vdl.karajan.lib.swiftscript;
+import java.io.IOException;
 import java.util.regex.Matcher;
 import java.util.regex.Pattern;
@@ -18,11 +20,11 @@
 import org.griphyn.vdl.type.NoSuchTypeException;
+import org.griphyn.vdl.util.VDL2Config;
 public class Misc extends FunctionsCollection {
-	private static final Logger logger = Logger.getLogger(FunctionsCollection.class);
+	private static final Logger logger = Logger.getLogger(Misc.class);
 	public static final SwiftArg PA_INPUT = new SwiftArg.Positional("input");
 	public static final SwiftArg PA_PATTERN = new SwiftArg.Positional("regexp");
@@ -58,6 +60,7 @@
 	public DSHandle swiftscript_strcat(VariableStack stack) throws ExecutionException, NoSuchTypeException,
 			InvalidPathException {
 		Object[] args = SwiftArg.VARGS.asArray(stack);
 		StringBuffer buf = new StringBuffer();
 		for (int i = 0; i < args.length; i++) {
 			buf.append(TypeUtil.toString(args[i]));
@@ -65,11 +68,23 @@
 		DSHandle handle = new RootDataNode(Types.STRING);
 		handle.setValue(buf.toString());
 		handle.closeShallow();
+		try {
+			if(VDL2Config.getConfig().getProvenanceLog()) {
+				DSHandle[] provArgs = SwiftArg.VARGS.asDSHandleArray(stack);
+				for (int i = 0; i < provArgs.length; i++) {
+					VDLFunction.logProvenanceParameter(provid, (DSHandle)provArgs[i], ""+i);
+				VDLFunction.logProvenanceResult(provid, handle, "strcat");
+		} catch(IOException ioe) {
+			throw new ExecutionException("When logging provenance for strcat", ioe);
 		return handle;
 	public DSHandle swiftscript_strcut(VariableStack stack) throws ExecutionException, NoSuchTypeException,
 		String inputString = TypeUtil.toString(PA_INPUT.getValue(stack));
 		String pattern = TypeUtil.toString(PA_PATTERN.getValue(stack));
 		if (logger.isDebugEnabled()) {
@@ -95,6 +110,9 @@
 		handle.setValue(group);
+		VDLFunction.logProvenanceResult(provid, handle, "strcut");
+		VDLFunction.logProvenanceParameter(provid, PA_INPUT.getRawValue(stack), "input");
+		VDLFunction.logProvenanceParameter(provid, PA_PATTERN.getRawValue(stack), "pattern");
 		return handle;
@@ -111,6 +129,10 @@
 			el.setValue(split[i]);
 		handle.closeDeep();
+		VDLFunction.logProvenanceResult(provid, handle, "strsplit");
 		return handle;
@@ -142,6 +164,12 @@
+		VDLFunction.logProvenanceResult(provid, handle, "regexp");
+		VDLFunction.logProvenanceParameter(provid, PA_TRANSFORM.getRawValue(stack), "transform");
 		return handle;
@@ -151,7 +179,9 @@
 		DSHandle handle = new RootDataNode(Types.INT);
 		handle.setValue(new Double(Integer.parseInt(inputString)));
+		VDLFunction.logProvenanceResult(provid, handle, "toint");
+		VDLFunction.logProvenanceParameter(provid, PA_INPUT.getRawValue(stack), "string");
 		return handle;
