[Swift-commit] r3007 - SwiftApps/SEE/trunk
noreply at svn.ci.uchicago.edu
Tue Jul 14 17:06:08 CDT 2009
Author: aespinosa
Date: 2009-07-14 17:06:08 -0500 (Tue, 14 Jul 2009)
New Revision: 3007
Added:
SwiftApps/SEE/trunk/cmd_mapper.sh
SwiftApps/SEE/trunk/instance_mapper.sh
Modified:
SwiftApps/SEE/trunk/ampl.swift
SwiftApps/SEE/trunk/run_ampl
SwiftApps/SEE/trunk/runampl.sh
Log:
Struct-urized swift script. Added required mappers for clean code
Modified: SwiftApps/SEE/trunk/ampl.swift
--- SwiftApps/SEE/trunk/ampl.swift 2009-07-14 07:59:07 UTC (rev 3006)
+++ SwiftApps/SEE/trunk/ampl.swift 2009-07-14 22:06:08 UTC (rev 3007)
@@ -1,29 +1,57 @@
-type Template {}
-type AMPLIn{}
-type AMPLOut {}
-type STDOut {}
+type Template;
+type AmplIn;
+type StdOut;
-app (AMPLOut expend, AMPLOut limits, AMPLOut price, AMPLOut ratio, AMPLOut solve, STDOut ofile) run_ampl (string instanceID, Template temp, AMPLIn mod, AMPLIn process, AMPLIn output, AMPLIn so, AMPLIn tree)
+type AmplCmd {
+ Template temp;
+ AmplIn mod;
+ AmplIn process;
+ AmplIn output;
+ AmplIn so;
+ AmplIn tree;
+type ExpendDat;
+type LimitsDat;
+type PriceDat;
+type RatioDat;
+type SolveDat;
+type ExpendOut;
+type PriceOut;
+type RatioOut;
+type AmplFilter {
+ ExpendOut expend_out;
+ PriceOut price_out;
+ RatioOut ratio_out;
+type AmplResult {
+ ExpendDat expend;
+ LimitsDat limits;
+ PriceDat price;
+ RatioDat ratio;
+ SolveDat solve;
+ StdOut ofile;
+ AmplFilter out;
+app (AmplResult result) run_ampl (string instanceID, AmplCmd cmd)
- run_ampl instanceID @filename(temp) @filename(mod) @filename(process) @filename(output) @filename(so) @filename(tree) stdout=@filename(ofile);
+ run_ampl instanceID @filename(cmd.temp)
+ @filename(cmd.mod) @filename(cmd.process)
+ @filename(cmd.output) @filename(cmd.so) @filename(cmd.tree)
+ stdout=@filename(result.ofile);
-int runs[]=[5001:10000];
+AmplCmd const_cmd <ext;exec="./cmd_mapper.sh">;
+int runs[]=[2001:2002];
foreach i in runs {
- Template temp <"template">;
- AMPLIn mod <"armington.mod">;
- AMPLIn process <"armington_process.cmd">;
- AMPLIn output <"armington_output.cmd">;
- AMPLIn so <"ces.so">;
- AMPLIn tree <"subproblems/producer_tree.mod">;
string instanceID = @strcat("run", i);
- AMPLOut expend <single_file_mapper;file=@strcat("result/", instanceID, "/expend.dat")>;
- AMPLOut limits <single_file_mapper;file=@strcat("result/", instanceID, "/limits.dat")>;
- AMPLOut price <single_file_mapper;file=@strcat("result/", instanceID, "/price.dat")>;
- AMPLOut ratio <single_file_mapper;file=@strcat("result/", instanceID, "/ratio.dat")>;
- AMPLOut solve <single_file_mapper;file=@strcat("result/", instanceID, "/solve.dat")>;
- STDOut ofile <single_file_mapper;file=@strcat("result/", instanceID, "/stdout")>;
- (expend, limits, price, ratio, solve, ofile)=run_ampl(instanceID, temp, mod, process, output, tree, so);
+ AmplResult res <ext;exec="./instance_mapper.sh", i=instanceID>;
+ res = run_ampl(instanceID, const_cmd);
Added: SwiftApps/SEE/trunk/cmd_mapper.sh
--- SwiftApps/SEE/trunk/cmd_mapper.sh (rev 0)
+++ SwiftApps/SEE/trunk/cmd_mapper.sh 2009-07-14 22:06:08 UTC (rev 3007)
@@ -0,0 +1,8 @@
+#!/bin/bash
+echo "temp template"
+echo "mod armington.mod"
+echo "process armington_process.cmd"
+echo "output armington_output.cmd"
+echo "so ces.so"
+echo "tree subproblems/producer_tree.mod"
Property changes on: SwiftApps/SEE/trunk/cmd_mapper.sh
___________________________________________________________________
Added: SwiftApps/SEE/trunk/instance_mapper.sh
--- SwiftApps/SEE/trunk/instance_mapper.sh (rev 0)
+++ SwiftApps/SEE/trunk/instance_mapper.sh 2009-07-14 22:06:08 UTC (rev 3007)
@@ -0,0 +1,20 @@
+#!/bin/bash
+while getopts ":i:" options; do
+ case $options in
+ i) export instance=$OPTARG ;;
+ *) exit 1;;
+ esac
+done
+echo "expend result/$instance/expend.dat";
+echo "limits result/$instance/limits.dat";
+echo "price result/$instance/price.dat";
+echo "ratio result/$instance/ratio.dat";
+echo "solve result/$instance/solve.dat";
+echo "ofile result/$instance/stdout";
+echo "out.expend_out result/$instance/expend.out";
+echo "out.price_out result/$instance/price.out";
+echo "out.ratio_out result/$instance/ratio.out";
Property changes on: SwiftApps/SEE/trunk/instance_mapper.sh
Modified: SwiftApps/SEE/trunk/run_ampl
--- SwiftApps/SEE/trunk/run_ampl 2009-07-14 07:59:07 UTC (rev 3006)
+++ SwiftApps/SEE/trunk/run_ampl 2009-07-14 22:06:08 UTC (rev 3007)
@@ -1,5 +1,5 @@
#!/bin/bash
-export PATH=$PATH:/home/zzhang/amplbin/
+export PATH=$PATH:/panfs/panasas/CMS/data/amplbin/
export PATH_LICENSE_STRING="2640088036&Todd_Munson&Argonne_National_Laboratory&&USR&&14_12_2001&1000&COMP&GEN&0_0_0&0_0_0&0&0_0"
if [ $# -lt 1 ]; then
Modified: SwiftApps/SEE/trunk/runampl.sh
--- SwiftApps/SEE/trunk/runampl.sh 2009-07-14 07:59:07 UTC (rev 3006)
+++ SwiftApps/SEE/trunk/runampl.sh 2009-07-14 22:06:08 UTC (rev 3007)
@@ -8,5 +8,5 @@
#-tc.file ./tc.data ampl.swift
#swift -runid teraport -sites.file ./sites-teraport.xml \
-swift -runid run3k_firefly -config swift.properties \
+swift -runid testing -config swift.properties \
-sites.file ./ff-grid.xml -tc.file ./tc.data ampl.swift
More information about the Swift-commit
