[Swift-commit] r3004 - SwiftApps/SEE/trunk
noreply at svn.ci.uchicago.edu
Wed Jul 8 09:49:40 CDT 2009
Author: aespinosa
Date: 2009-07-08 09:49:38 -0500 (Wed, 08 Jul 2009)
New Revision: 3004
Modified:
SwiftApps/SEE/trunk/ampl.swift
SwiftApps/SEE/trunk/ff-grid.xml
SwiftApps/SEE/trunk/runampl.sh
SwiftApps/SEE/trunk/swift.properties
SwiftApps/SEE/trunk/template
Log:
update for 5k run
Modified: SwiftApps/SEE/trunk/ampl.swift
--- SwiftApps/SEE/trunk/ampl.swift 2009-07-07 21:41:29 UTC (rev 3003)
+++ SwiftApps/SEE/trunk/ampl.swift 2009-07-08 14:49:38 UTC (rev 3004)
@@ -8,7 +8,7 @@
run_ampl instanceID @filename(temp) @filename(mod) @filename(process) @filename(output) @filename(so) @filename(tree) stdout=@filename(ofile);
-int runs[]=[1:2000];
+int runs[]=[5001:10000];
foreach i in runs {
Template temp <"template">;
AMPLIn mod <"armington.mod">;
Modified: SwiftApps/SEE/trunk/ff-grid.xml
--- SwiftApps/SEE/trunk/ff-grid.xml 2009-07-07 21:41:29 UTC (rev 3003)
+++ SwiftApps/SEE/trunk/ff-grid.xml 2009-07-08 14:49:38 UTC (rev 3004)
@@ -3,17 +3,13 @@
<!-- ff-grid -->
<pool handle="ff-grid" >
<gridftp url="gsiftp://ff-grid.unl.edu/" />
- <!--<execution provider="condor" />-->
- <jobmanager universe="vanilla" url="ff-grid.unl.edu" major="2" minor="2"
- patch="4"/>
- <profile namespace="karajan" key="initialScore">10</profile>
- <profile namespace="karajan" key="jobThrottle">18.0</profile>
+ <execution provider="condor" />
+ <profile namespace="karajan" key="initialScore">10000.0</profile>
+ <profile namespace="karajan" key="jobThrottle">10.0</profile>
<workdirectory >/panfs/panasas/CMS/data/SEE/workdir</workdirectory>
<profile namespace="globus" key="jobType">grid</profile>
<profile namespace="globus" key="queue">default</profile>
<profile namespace="globus" key="gridResource">gt2 ff-grid.unl.edu/jobmanager-pbs</profile>
</pool>
</config>
Modified: SwiftApps/SEE/trunk/runampl.sh
--- SwiftApps/SEE/trunk/runampl.sh 2009-07-07 21:41:29 UTC (rev 3003)
+++ SwiftApps/SEE/trunk/runampl.sh 2009-07-08 14:49:38 UTC (rev 3004)
@@ -8,5 +8,5 @@
#-tc.file ./tc.data ampl.swift
#swift -runid teraport -sites.file ./sites-teraport.xml \
-#swift -runid firefly_run -config swift.properties \
- #-sites.file ./ff-grid.xml -tc.file ./tc.data ampl.swift
+swift -runid run3k_firefly -config swift.properties \
+ -sites.file ./ff-grid.xml -tc.file ./tc.data ampl.swift
Modified: SwiftApps/SEE/trunk/swift.properties
--- SwiftApps/SEE/trunk/swift.properties 2009-07-07 21:41:29 UTC (rev 3003)
+++ SwiftApps/SEE/trunk/swift.properties 2009-07-08 14:49:38 UTC (rev 3004)
@@ -149,7 +149,7 @@
# Default: false
-wrapperlog.always.transfer=false
+wrapperlog.always.transfer=true
# Throttling options #
Modified: SwiftApps/SEE/trunk/template
--- SwiftApps/SEE/trunk/template 2009-07-07 21:41:29 UTC (rev 3003)
+++ SwiftApps/SEE/trunk/template 2009-07-08 14:49:38 UTC (rev 3004)
@@ -1,4 +1,4 @@
-option ampl_include "/home/zzhang/SEE/static/instances/test/@INSTANCE_ID@\
+option ampl_include "/panfs/panasas/CMS/data/SEE/run5kdata/@INSTANCE_ID@\
option solver pathampl;
option path_options "nms_ini_ref_min=1e8 cra_met=none cra_per=no fac_upd_lim=200";
More information about the Swift-commit
