[Swift-commit] r2994 - in trunk: . docs libexec src/org/griphyn/vdl/engine src/org/griphyn/vdl/karajan/lib/swiftscript tests/language-behaviour
noreply at svn.ci.uchicago.edu
Wed Jul 1 10:11:01 CDT 2009
Author: benc
Date: 2009-07-01 10:11:01 -0500 (Wed, 01 Jul 2009)
New Revision: 2994
Added:
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/WriteData.java
trunk/tests/language-behaviour/writeDataPrimitive.out.expected
trunk/tests/language-behaviour/writeDataPrimitive.swift
trunk/tests/language-behaviour/writeDataStringArray.swift
trunk/tests/language-behaviour/writeDataStringArray2.out.expected
trunk/tests/language-behaviour/writeDataStringArray2.swift
trunk/tests/language-behaviour/writeDataStruct.out.expected
trunk/tests/language-behaviour/writeDataStruct.swift
trunk/tests/language-behaviour/writeDataStructArray2.out.expected
trunk/tests/language-behaviour/writeDataStructArray2.swift
Modified:
trunk/CHANGES.txt
trunk/docs/userguide.xml
trunk/libexec/vdl-lib.xml
trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
Log:
New procedure writeData to write data structures to a file.
This should be the inverse of readData: readData(writeData(X)) == X
and, modulo formatting and assuming data is in the correct format,
writeData(readData(X)) == X
The initial use for this is to write out long lists of filenames into a disk
file, rather than passing them on the command line.
Modified: trunk/CHANGES.txt
--- trunk/CHANGES.txt 2009-06-30 12:40:25 UTC (rev 2993)
+++ trunk/CHANGES.txt 2009-07-01 15:11:01 UTC (rev 2994)
@@ -1,3 +1,7 @@
+(07/01/09)
+*** New writeData procedure which writes data structures to files in the same
+ format as used by readData.
(06/30/09)
*** New parameter -condor-g for swift-osg-ress-site-catalog which causes
sites files to be generate which will use a local condor-g installation
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml 2009-06-30 12:40:25 UTC (rev 2993)
+++ trunk/docs/userguide.xml 2009-07-01 15:11:01 UTC (rev 2994)
@@ -2189,6 +2189,12 @@
</para>
</section>
+ <section id="procedure.writedata"><title>writeData</title>
+ <para>
+<literal>writeData</literal> will write out data structures in the format
+described for <literal>readData</literal>
+ </para>
+ </section>
</section>
<section id="engineconfiguration">
Modified: trunk/libexec/vdl-lib.xml
--- trunk/libexec/vdl-lib.xml 2009-06-30 12:40:25 UTC (rev 2993)
+++ trunk/libexec/vdl-lib.xml 2009-07-01 15:11:01 UTC (rev 2994)
@@ -5,6 +5,7 @@
<export name="extractint"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ExtractInt"/></export>
<export name="readdata"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ReadData"/></export>
<export name="readdata2"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ReadData2"/></export>
+ <export name="writedata"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.WriteData"/></export>
<export name="strcat"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="strcut"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="strsplit"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
Modified: trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
--- trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java 2009-06-30 12:40:25 UTC (rev 2993)
+++ trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java 2009-07-01 15:11:01 UTC (rev 2994)
@@ -137,7 +137,15 @@
trace.setAnyNumOfInputArgs();
trace.setInvocationMode(INVOCATION_INTERNAL);
proceduresMap.put("trace", trace);
+ ProcedureSignature writeData = new ProcedureSignature("writeData");
+ FormalArgumentSignature wdInputArg = new FormalArgumentSignature(true);
+ writeData.addInputArg(wdInputArg);
+ FormalArgumentSignature wdOutputArg = new FormalArgumentSignature(true);
+ writeData.addOutputArg(wdOutputArg);
+ writeData.setInvocationMode(INVOCATION_INTERNAL);
+ proceduresMap.put("writeData", writeData);
return proceduresMap;
Added: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/WriteData.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/WriteData.java (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/WriteData.java 2009-07-01 15:11:01 UTC (rev 2994)
@@ -0,0 +1,179 @@
+package org.griphyn.vdl.karajan.lib.swiftscript;
+import java.io.BufferedWriter;
+import java.io.File;
+import java.io.FileWriter;
+import java.io.IOException;
+import java.util.Arrays;
+import java.util.HashSet;
+import java.util.Set;
+import java.util.List;
+import java.util.Map;
+import java.util.TreeMap;
+import java.util.Collection;
+import java.util.Comparator;
+import java.util.Iterator;
+import org.apache.log4j.Logger;
+import org.globus.cog.karajan.arguments.Arg;
+import org.globus.cog.karajan.stack.VariableStack;
+import org.globus.cog.karajan.workflow.ExecutionException;
+import org.griphyn.vdl.karajan.lib.VDLFunction;
+import org.griphyn.vdl.mapping.AbsFile;
+import org.griphyn.vdl.mapping.AbstractDataNode;
+import org.griphyn.vdl.mapping.DSHandle;
+import org.griphyn.vdl.mapping.HandleOpenException;
+import org.griphyn.vdl.mapping.InvalidPathException;
+import org.griphyn.vdl.mapping.Path;
+import org.griphyn.vdl.mapping.PhysicalFormat;
+import org.griphyn.vdl.type.Type;
+import org.griphyn.vdl.type.Types;
+public class WriteData extends VDLFunction {
+ public static final Logger logger = Logger.getLogger(WriteData.class);
+ public static final Arg DEST = new Arg.Positional("dest");
+ public static final Arg SRC = new Arg.Positional("src");
+ public static boolean warning;
+ static {
+ setArguments(WriteData.class, new Arg[] { DEST, SRC });
+ protected Object function(VariableStack stack) throws ExecutionException, HandleOpenException {
+ // dest needs to be mapped to a file, or a string
+ DSHandle dest = (DSHandle) DEST.getValue(stack);
+ // src can be any of several forms of value
+ DSHandle src = (DSHandle) SRC.getValue(stack);
+ waitFor(stack, src);
+ if (dest.getType().equals(Types.STRING)) {
+ writeData((String)dest.getValue(), src);
+ else {
+ PhysicalFormat pf = dest.getMapper().map(Path.EMPTY_PATH);
+ if (pf instanceof AbsFile) {
+ AbsFile af = (AbsFile) pf;
+ if (!af.getProtocol().equalsIgnoreCase("file")) {
+ throw new ExecutionException("writeData only supports local files");
+ writeData(af.getPath(), src);
+ else {
+ throw new ExecutionException("writeData only supports writing to files");
+ dest.closeDeep();
+ return null;
+ private void writeData(String path, DSHandle src) throws ExecutionException {
+ File f = new File(path);
+ try {
+ BufferedWriter br = new BufferedWriter(new FileWriter(f));
+ try {
+ if (src.getType().isArray()) {
+ // each line is an item
+ writeArray(br, src);
+ else if (src.getType().isPrimitive()) {
+ writePrimitive(br, src);
+ else {
+ // struct
+ writeStructHeader(src.getType(), br);
+ writeStruct(br, src);
+ finally {
+ try {
+ br.close();
+ catch (IOException e) {
+ e.printStackTrace();
+ throw new ExecutionException(e);
+ private void writePrimitive(BufferedWriter br, DSHandle src) throws IOException,
+ ExecutionException {
+ br.write(src.getValue().toString());
+ private void writeArray(BufferedWriter br, DSHandle src) throws IOException, ExecutionException {
+ if (src.getType().itemType().isPrimitive()) {
+ writePrimitiveArray(br, src);
+ else {
+ writeStructArray(br, src);
+ private void writePrimitiveArray(BufferedWriter br, DSHandle src) throws IOException,
+ Map m = ((AbstractDataNode) src).getArrayValue();
+ Map c = new TreeMap(new ArrayIndexComparator());
+ c.putAll(m);
+ Iterator i = c.values().iterator();
+ while(i.hasNext()) {
+ br.write(((DSHandle)i.next()).toString());
+ br.newLine();
+ private void writeStructArray(BufferedWriter br, DSHandle src) throws IOException,
+ writeStructHeader(src.getType().itemType(), br);
+ c.putAll(m);
+ writeStruct(br, (DSHandle)i.next());
+ private void writeStructHeader(Type type, BufferedWriter br) throws ExecutionException,
+ IOException {
+ List l = type.getFieldNames();
+ Iterator i = l.iterator();
+ br.write(i.next().toString());
+ br.write(" ");
+ br.newLine();
+ private void writeStruct(BufferedWriter br, DSHandle struct) throws IOException, ExecutionException {
+ List l = struct.getType().getFieldNames();
+ try {
+ DSHandle child = struct.getField(Path.EMPTY_PATH.addLast((String)i.next()));
+ br.write(child.toString());
+ br.write(" ");
+ br.newLine();
+ } catch(InvalidPathException e) {
+ throw new ExecutionException("Unexpectedly invalid path", e);
+ class ArrayIndexComparator implements Comparator {
+ public int compare(Object o1, Object o2) {
+ int i1 = Integer.parseInt((String)o1);
+ int i2 = Integer.parseInt((String)o2);
+ if(i1 < i2) return -1;
+ if(i1 > i2) return 1;
+ return 0;
Added: trunk/tests/language-behaviour/writeDataPrimitive.out.expected
--- trunk/tests/language-behaviour/writeDataPrimitive.out.expected (rev 0)
+++ trunk/tests/language-behaviour/writeDataPrimitive.out.expected 2009-07-01 15:11:01 UTC (rev 2994)
@@ -0,0 +1 @@
+foo
\ No newline at end of file
Added: trunk/tests/language-behaviour/writeDataPrimitive.swift
--- trunk/tests/language-behaviour/writeDataPrimitive.swift (rev 0)
+++ trunk/tests/language-behaviour/writeDataPrimitive.swift 2009-07-01 15:11:01 UTC (rev 2994)
@@ -0,0 +1,8 @@
+type file;
+string s = "foo";
+file f <"writeDataPrimitive.out">;
+f=writeData(s);
Added: trunk/tests/language-behaviour/writeDataStringArray.swift
--- trunk/tests/language-behaviour/writeDataStringArray.swift (rev 0)
+++ trunk/tests/language-behaviour/writeDataStringArray.swift 2009-07-01 15:11:01 UTC (rev 2994)
@@ -0,0 +1,8 @@
+type file;
+string s[] = ["foo", "bar"];
+file f <"writeDataStringArray.out">;
+f=writeData(s);
Added: trunk/tests/language-behaviour/writeDataStringArray2.out.expected
--- trunk/tests/language-behaviour/writeDataStringArray2.out.expected (rev 0)
+++ trunk/tests/language-behaviour/writeDataStringArray2.out.expected 2009-07-01 15:11:01 UTC (rev 2994)
@@ -0,0 +1,5 @@
+foo
+bar
+baz
+qux
+frrrr
Added: trunk/tests/language-behaviour/writeDataStringArray2.swift
--- trunk/tests/language-behaviour/writeDataStringArray2.swift (rev 0)
+++ trunk/tests/language-behaviour/writeDataStringArray2.swift 2009-07-01 15:11:01 UTC (rev 2994)
@@ -0,0 +1,14 @@
+type file;
+string s[];
+file f <"writeDataStringArray2.out">;
+f=writeData(s);
+s[2] = "baz";
+s[3] = "qux";
+s[0] = "foo";
+s[1] = "bar";
+s[4] = "frrrr";
Added: trunk/tests/language-behaviour/writeDataStruct.out.expected
--- trunk/tests/language-behaviour/writeDataStruct.out.expected (rev 0)
+++ trunk/tests/language-behaviour/writeDataStruct.out.expected 2009-07-01 15:11:01 UTC (rev 2994)
@@ -0,0 +1,2 @@
+r c l
+Baz BAZ baz
Added: trunk/tests/language-behaviour/writeDataStruct.swift
--- trunk/tests/language-behaviour/writeDataStruct.swift (rev 0)
+++ trunk/tests/language-behaviour/writeDataStruct.swift 2009-07-01 15:11:01 UTC (rev 2994)
@@ -0,0 +1,14 @@
+type file;
+type S { string l; string c; string r; }
+S s;
+file f <"writeDataStruct.out">;
+f=writeData(s);
+s.l = "baz";
+s.c = "BAZ";
+s.r = "Baz";
Added: trunk/tests/language-behaviour/writeDataStructArray2.out.expected
--- trunk/tests/language-behaviour/writeDataStructArray2.out.expected (rev 0)
+++ trunk/tests/language-behaviour/writeDataStructArray2.out.expected 2009-07-01 15:11:01 UTC (rev 2994)
@@ -0,0 +1,6 @@
+r c l
+Foo FOO foo
+Bar BAR bar
+Baz BAZ baz
+Qux QUX qux
+Frrrr FRRRR frrrr
Added: trunk/tests/language-behaviour/writeDataStructArray2.swift
--- trunk/tests/language-behaviour/writeDataStructArray2.swift (rev 0)
+++ trunk/tests/language-behaviour/writeDataStructArray2.swift 2009-07-01 15:11:01 UTC (rev 2994)
@@ -0,0 +1,26 @@
+type file;
+S s[];
+file f <"writeDataStructArray2.out">;
+f=writeData(s);
+s[2].l = "baz";
+s[2].c = "BAZ";
+s[2].r = "Baz";
+s[3].l = "qux";
+s[3].c = "QUX";
+s[3].r = "Qux";
+s[0].l = "foo";
+s[0].c = "FOO";
+s[0].r = "Foo";
+s[1].l = "bar";
+s[1].c = "BAR";
+s[1].r = "Bar";
+s[4].l = "frrrr";
+s[4].c = "FRRRR";
+s[4].r = "Frrrr";
More information about the Swift-commit
