[Swift-commit] r2052 - in trunk: resources src/org/griphyn/vdl/karajan/lib tests/language-behaviour
noreply at svn.ci.uchicago.edu
Sat Jun 7 08:00:09 CDT 2008
Author: benc
Date: 2008-06-07 08:00:09 -0500 (Sat, 07 Jun 2008)
New Revision: 2052
Added:
trunk/tests/language-behaviour/086-iterate-concurrent.swift
Modified:
trunk/resources/Karajan.stg
trunk/src/org/griphyn/vdl/karajan/lib/InfiniteCountingWhile.java
Log:
fix bug 142 - concurrent mapper should now work inside iterate{}. tests added for that, and also to check that concurrent mapper + restarts + iterate{} works.
Modified: trunk/resources/Karajan.stg
--- trunk/resources/Karajan.stg 2008-06-06 22:40:15 UTC (rev 2051)
+++ trunk/resources/Karajan.stg 2008-06-07 13:00:09 UTC (rev 2052)
@@ -160,8 +160,11 @@
iterate(declarations,statements,cond,var) ::= <<
<vdl:infinitecountingwhile>
+ <set names="\$\$">
+ <each items="{\$}"/>
+ </set>
<set name="$var$">
- <vdl:new type="int" value="{\$}" />
+ <vdl:new type="int" value="{\$\$}" />
</set>
$sub_comp(declarations=declarations, statements=statements)$
<sys:if>
Modified: trunk/src/org/griphyn/vdl/karajan/lib/InfiniteCountingWhile.java
--- trunk/src/org/griphyn/vdl/karajan/lib/InfiniteCountingWhile.java 2008-06-06 22:40:15 UTC (rev 2051)
+++ trunk/src/org/griphyn/vdl/karajan/lib/InfiniteCountingWhile.java 2008-06-07 13:00:09 UTC (rev 2052)
@@ -6,6 +6,9 @@
package org.griphyn.vdl.karajan.lib;
+import java.util.Arrays;
+import java.util.List;
import org.globus.cog.karajan.arguments.Arg;
import org.globus.cog.karajan.workflow.nodes.*;
import org.globus.cog.karajan.stack.VariableStack;
@@ -26,7 +29,7 @@
stack.setVar("#condition", new Condition());
stack.setVar(VAR, "$");
String counterName = (String)stack.getVar(VAR);
- stack.setVar(counterName, new Integer(0)); // should be DSHandle-wrapped
+ stack.setVar(counterName, Arrays.asList(new Integer[] {new Integer(0)}));
super.pre(stack);
@@ -56,9 +59,11 @@
fn = (FlowElement) getElement(0);
String counterName = (String) stack.getVar(VAR);
- int i = ((Integer)stack.getVar(counterName)).intValue();
+ List l = (List)stack.getVar(counterName);
+ Integer wrappedi = (Integer)l.get(0);
+ int i = wrappedi.intValue();
i++;
- stack.setVar(counterName, new Integer(i)); // should be DSHandle-wrapped
+ stack.setVar(counterName, Arrays.asList(new Integer[] {new Integer(i)}));
else {
fn = (FlowElement) getElement(index++);
Added: trunk/tests/language-behaviour/086-iterate-concurrent.swift
--- trunk/tests/language-behaviour/086-iterate-concurrent.swift (rev 0)
+++ trunk/tests/language-behaviour/086-iterate-concurrent.swift 2008-06-07 13:00:09 UTC (rev 2052)
@@ -0,0 +1,14 @@
+type messagefile;
+(messagefile t) greeting() {
+ app {
+ echo "hello" stdout=@filename(t);
+iterate i {
+ messagefile outfile;
+ outfile = greeting();
+} until(i>10);
More information about the Swift-commit
