[Swift-commit] r2165 - trunk/src/org/griphyn/vdl/engine
noreply at svn.ci.uchicago.edu
Thu Jul 31 08:51:31 CDT 2008
Author: benc
Date: 2008-07-31 08:51:30 -0500 (Thu, 31 Jul 2008)
New Revision: 2165
Modified:
trunk/src/org/griphyn/vdl/engine/Karajan.java
Log:
stuff that was missed from 2161 (benc's fault). This commit contributed by Milena Nikolic <nikolicmilena at gmail.com>
Modified: trunk/src/org/griphyn/vdl/engine/Karajan.java
--- trunk/src/org/griphyn/vdl/engine/Karajan.java 2008-07-30 20:44:40 UTC (rev 2164)
+++ trunk/src/org/griphyn/vdl/engine/Karajan.java 2008-07-31 13:51:30 UTC (rev 2165)
@@ -176,8 +176,10 @@
StringTemplate st = template("typeDef");
st.setAttribute("name", typeName);
- if (typeAlias != null && !typeAlias.equals("") && !typeAlias.equals("string"))
- st.setAttribute("type", typeAlias);
+ if (typeAlias != null && !typeAlias.equals("") && !typeAlias.equals("string")) {
+ checkIsTypeDefined(typeAlias);
+ st.setAttribute("type", typeAlias);
TypeStructure ts = theType.getTypestructure();
for (int j = 0; j < ts.sizeOfMemberArray(); j++) {
@@ -228,6 +230,7 @@
procST.setAttribute("optargs", paramST);
else
procST.setAttribute("arguments", paramST);
+ checkIsTypeDefined(param.getType().getLocalPart());
innerScope.addVariable(param.getName(), param.getType().getLocalPart());
for (int i = 0; i < proc.sizeOfInputArray(); i++) {
@@ -238,6 +241,7 @@
else
outerScope.addVariable(param.getName(), param.getType().getLocalPart());
@@ -272,23 +276,7 @@
variableST.setAttribute("type", var.getType().getLocalPart());
variableST.setAttribute("isArray", Boolean.valueOf(var.getIsArray1()));
- /* Checking if variable type is defined */
- String type = var.getType().getLocalPart();
- while (type.substring(type.length() - 2).equals("[]"))
- type = type.substring(0, type.length() - 2);
- if (!type.equals("int") && !type.equals("float") && !type.equals("string")
- && !type.equals("boolean") && !type.equals("external")) {
- boolean typeDefined = false;
- if (types != null) {
- for (int i = 0; i < types.sizeOfTypeArray(); i++)
- if (types.getTypeArray(i).getTypename().equals(type)) {
- typeDefined = true;
- break;
- if (!typeDefined)
- throw new CompilationException("Type " + type + " is not defined.");
+ checkIsTypeDefined(var.getType().getLocalPart());
if(!var.isNil()) {
StringTemplate exprST = expressionToKarajan(var.getAbstractExpression(),scope);
@@ -319,6 +307,9 @@
if (dataset.isSetIsArray1()) {
datasetST.setAttribute("isArray", Boolean.valueOf(dataset.getIsArray1()));
+ checkIsTypeDefined(dataset.getType().getLocalPart());
if (dataset.getFile() != null) {
StringTemplate fileST = new StringTemplate("file");
fileST.setAttribute("name", escapeQuotes(dataset.getFile().getName()));
@@ -341,6 +332,24 @@
scope.addVariable(dataset.getName(), dataset.getType().getLocalPart());
+ void checkIsTypeDefined(String type) throws CompilationException {
+ while (type.substring(type.length() - 2).equals("[]"))
+ type = type.substring(0, type.length() - 2);
+ if (!type.equals("int") && !type.equals("float") && !type.equals("string")
+ && !type.equals("boolean") && !type.equals("external")) {
+ boolean typeDefined = false;
+ if (types != null) {
+ for (int i = 0; i < types.sizeOfTypeArray(); i++)
+ if (types.getTypeArray(i).getTypename().equals(type)) {
+ typeDefined = true;
+ break;
+ if (!typeDefined)
+ throw new CompilationException("Type " + type + " is not defined.");
public void assign(Assign assign, VariableScope scope) throws CompilationException {
try {
More information about the Swift-commit
