[Swift-commit] r2149 - provider-deef/src/org/globus/cog/abstraction/impl/execution/deef
Ben Clifford
benc at hawaga.org.uk
Sun Jul 27 05:03:49 CDT 2008
did you really write this code or is it from somone else?
On Sat, 26 Jul 2008, noreply at www.ci.uchicago.edu wrote:
> Author: wilde
> Date: 2008-07-26 18:59:31 -0500 (Sat, 26 Jul 2008)
> New Revision: 2149
> Modified:
> provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java
> Log:
> Set Swift server IP from cog property for case of multiple interfaces, and create one resource pool per Falkon server
> Modified: provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java
> --- provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java 2008-07-25 00:00:44 UTC (rev 2148)
> +++ provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java 2008-07-26 23:59:31 UTC (rev 2149)
> @@ -37,6 +37,9 @@
> import org.globus.cog.abstraction.impl.common.task.InvalidServiceContactException;
> import org.globus.cog.abstraction.impl.common.task.TaskSubmissionException;
> +import org.globus.common.CoGProperties;
> public class ResourcePool {
> static Logger logger = Logger.getLogger(ResourcePool.class.getName());
> private EndpointReferenceType factoryEPR = null;
> @@ -49,7 +52,8 @@
> private String server = "";
> private int num = 1;
> private static int crtResource = 0;
> - private static ResourcePool rp = null;
> + // private static ResourcePool rp = null;
> + private static HashMap rpmap = null;
> private Map tasks;
> private Notification userNot = null;
> private NotificationThread notThread;
> @@ -60,8 +64,14 @@
> private UserJob job = null;
> public static synchronized ResourcePool instance(String server, int num) throws InvalidServiceContactException {
> + ResourcePool rp = null;
> + if( rpmap == null )
> + rpmap = new HashMap();
> + rp = (ResourcePool) rpmap.get(server);
> if (rp == null) {
> rp = new ResourcePool();
> + rpmap.put(server, rp);
> rp.server = server;
> rp.num = num;
> rp.tasks = Collections.synchronizedMap(new HashMap());
> @@ -166,13 +176,13 @@
> - public EndpointReferenceType getNextResource() {
> + public synchronized EndpointReferenceType getNextResource() {
> int next = crtResource;
> crtResource = (crtResource + 1) % num;
> return (EndpointReferenceType) eprPool.get(next);
> - public GPPortType getNextResourcePort() {
> + public synchronized GPPortType getNextResourcePort() {
> return (GPPortType) gptPool.get(next);
> @@ -208,7 +218,7 @@
> - public static String getMachNamePort(Notification userNot){
> + public static String getMachNamePort__ORIG__(Notification userNot){
> String machName = "";
> //String machIP;
> try {
> @@ -223,6 +233,38 @@
> return machName;
> +/**** From Ioan:
> + public String getMachNamePort__IOANS_EMAIL__(int recvPort)
> + String machName = new String("localhost:"+recvPort);
> + try
> + String method = new String("overide");
> + if (NOTIFICATION_ENDPOINT == null)
> + NOTIFICATION_ENDPOINT = java.net.InetAddress.getLocalHost().getCanonicalHostName();
> + method = new String("automatic");
> + machName = NOTIFICATION_ENDPOINT + ":" + recvPort;
> + System.out.println("Notification Endpoint (" + method + "): " + NOTIFICATION_ENDPOINT);
> + catch (Exception e)
> + System.out.println("WORKER: ERROR: java.net.InetAddress.getLocalHost().getHostName() failed " + e);
> + if (DEBUG) e.printStackTrace();
> + return machName;
> + public static String getMachNamePort(Notification userNot){
> + //String machIP = VDL2Config.getIP();
> + String machIP = CoGProperties.getDefault().getIPAddress();
> + String machNamePort = new String (machIP + ":" + userNot.recvPort);
> + logger.debug("WORKER: Machine ID = " + machNamePort);
> + return machNamePort;
> public int getExecQueueSize() {
> return execQueue.size();
> Swift-commit mailing list
> Swift-commit at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-commit
More information about the Swift-commit
