[Swift-commit] r2130 - SwiftApps/SIDGrid/swift/projects/andric/ccf_emblem/NonParametric_lag_analy
noreply at svn.ci.uchicago.edu
Fri Jul 18 13:01:55 CDT 2008
Author: skenny
Date: 2008-07-18 13:01:55 -0500 (Fri, 18 Jul 2008)
New Revision: 2130
Added:
SwiftApps/SIDGrid/swift/projects/andric/ccf_emblem/NonParametric_lag_analy/lh_NonParametric_lag_analyFILL.swift
Log:
param stuff
Added: SwiftApps/SIDGrid/swift/projects/andric/ccf_emblem/NonParametric_lag_analy/lh_NonParametric_lag_analyFILL.swift
--- SwiftApps/SIDGrid/swift/projects/andric/ccf_emblem/NonParametric_lag_analy/lh_NonParametric_lag_analyFILL.swift (rev 0)
+++ SwiftApps/SIDGrid/swift/projects/andric/ccf_emblem/NonParametric_lag_analy/lh_NonParametric_lag_analyFILL.swift 2008-07-18 18:01:55 UTC (rev 2130)
@@ -0,0 +1,47 @@
+type file{}
+(file qout, file rout) run_query (string allcatargs, file config, file r_script){
+ app{
+ Mediator allcatargs stdout=@filename(qout) @filename(r_script);
+string user = @arg("user");
+string db = "EMBLEM1";
+string host = "tp-neurodb.ci.uchicago.edu";
+string baseid = "lh_NonParam";
+file r_script<single_file_mapper; file="scripts/FriedmanTest.R">;
+file config<single_file_mapper; file="user.config">;
+loop_query(int bvox, string user, string db, string host, string query_outline, file r_script, file config, string id){
+ int evox = bvox+499;
+ string r_swift_args = @strcat(id);
+ string theoutprefix = @strcat(id,bvox,"_",evox);
+ string med_args = @strcat("--user ","andric",
+ " --conf ", "user.config",
+ " --db ", db,
+ " --host ", host,
+ " --query ", query_outline,
+ " --r_script ", @filename(r_script),
+ " --begin_vox ", bvox,
+ " --end_vox ", evox,
+ " --outprefix ", theoutprefix,
+ " --batchstep ", "500",
+ " --r_swift_args ", r_swift_args,
+ " --subject ", id);
+ file q_result <single_file_mapper; file=@strcat("results/",theoutprefix,".qresult")>;
+ file r_result <single_file_mapper; file=@strcat(theoutprefix,".txt")>;
+ (q_result, r_result) = run_query(med_args, r_script, config);
+string regions = ["IDEAL"];
+foreach region in regions {
+ int mybatches = [4501,45501,152501];
+ foreach batch in mybatches {
+ string id = @strcat(region, baseid);
+ string query_outline = @strcat("select subject, vertex, speech_lag, emblem_lag, embspeech_lag from ccf_phase2_lh where seed_region = '",region,"' and vertex between BEGIN_BATCH and END_BATCH");
+ loop_query(batch, user, db, host, query_outline, r_script, config, id);
More information about the Swift-commit
