[Swift-commit] r2117 - in trunk: resources tests/language/working-base
Tue Jul 15 02:47:40 CDT 2008
Author: benc
Date: 2008-07-15 02:47:39 -0500 (Tue, 15 Jul 2008)
New Revision: 2117
Modified:
   trunk/resources/swiftscript.g
   trunk/tests/language/working-base/039-montage.xml
   trunk/tests/language/working-base/q16.xml
   trunk/tests/language/working-base/q17.xml
Log:
part 2 of commits for bug 148. change handling of backslash symbol in string literals.
Modified: trunk/resources/swiftscript.g
--- trunk/resources/swiftscript.g	2008-07-15 07:46:50 UTC (rev 2116)
+++ trunk/resources/swiftscript.g	2008-07-15 07:47:39 UTC (rev 2117)
@@ -50,7 +50,9 @@
 String quote(String s) {
-    return s.replaceAll("\\\\\"", """);
+    String s1 = s.replaceAll("\\\\\"", """);
+    String s2 = s1.replaceAll("\\\\\\\\", "\\\\");
+    return s2;
Modified: trunk/tests/language/working-base/039-montage.xml
--- trunk/tests/language/working-base/039-montage.xml	2008-07-15 07:46:50 UTC (rev 2116)
+++ trunk/tests/language/working-base/039-montage.xml	2008-07-15 07:47:39 UTC (rev 2117)
@@ -86,16 +86,16 @@
         <mapping descriptor="regexp_mapper">
           <param name="source"><function name="filename">
             <variableReference>img</variableReference></function></param>
-          <param name="match"><stringConstant>.*\\/(.*)</stringConstant></param>
-          <param name="transform"><stringConstant>proj_\\1</stringConstant></param>
+          <param name="match"><stringConstant>.*\/(.*)</stringConstant></param>
+          <param name="transform"><stringConstant>proj_\1</stringConstant></param>
         </mapping>
       </dataset>
       <dataset name="areaImg" type="Image">
             <variableReference>projImg</variableReference></function></param>
-          <param name="match"><stringConstant>(.*)\\.(.*)</stringConstant></param>
-          <param name="transform"><stringConstant>\\1_area.\\2</stringConstant></param>
+          <param name="match"><stringConstant>(.*)\.(.*)</stringConstant></param>
+          <param name="transform"><stringConstant>\1_area.\2</stringConstant></param>
         </mapping>
       </dataset>
       <call proc="mProjectPP" src="line 27">
@@ -225,8 +225,8 @@
             <variableReference>image1</variableReference></function></param>
         </mapping>
       </dataset>
       <variable name="image2" type="Image"><structureMember>
@@ -237,8 +237,8 @@
             <variableReference>image2</variableReference></function></param>
         </mapping>
       </dataset>
       <dataset name="diffImg" type="Image">
@@ -255,7 +255,7 @@
             <variableReference>diffImg</variableReference></function></param>
           <param name="match"><stringConstant>diff(.*)fits</stringConstant></param>
-          <param name="transform"><stringConstant>fit\\1txt</stringConstant></param>
+          <param name="transform"><stringConstant>fit\1txt</stringConstant></param>
         </mapping>
       </dataset>
       <call proc="mDiffFit" src="line 59">
@@ -439,15 +439,15 @@
           <param name="match"><stringConstant>proj_(.*)</stringConstant></param>
-          <param name="transform"><stringConstant>corr_\\1</stringConstant></param>
+          <param name="transform"><stringConstant>corr_\1</stringConstant></param>
         </mapping>
       </dataset>
       <dataset name="corrArea" type="Image">
             <variableReference>corrImg</variableReference></function></param>
         </mapping>
       </dataset>
       <call proc="mBackground" src="line 94">
Modified: trunk/tests/language/working-base/q16.xml
--- trunk/tests/language/working-base/q16.xml	2008-07-15 07:46:50 UTC (rev 2116)
+++ trunk/tests/language/working-base/q16.xml	2008-07-15 07:47:39 UTC (rev 2117)
@@ -38,7 +38,7 @@
         <variableReference>inputfile</variableReference></function></param>
       <param name="match"><stringConstant>(.*)txt</stringConstant></param>
-      <param name="transform"><stringConstant>\\1count</stringConstant></param>
+      <param name="transform"><stringConstant>\1count</stringConstant></param>
     </mapping>
   </dataset>
   <call proc="countwords" src="line 14">
Modified: trunk/tests/language/working-base/q17.xml
--- trunk/tests/language/working-base/q17.xml	2008-07-15 07:46:50 UTC (rev 2116)
+++ trunk/tests/language/working-base/q17.xml	2008-07-15 07:47:39 UTC (rev 2117)
@@ -43,7 +43,7 @@
           <variableReference>f</variableReference></function></param>
       </mapping>
     </dataset>
     <call proc="countwords" src="line 17">
