[Swift-commit] r2109 - SwiftApps/SIDGrid/swift/projects/skenny/openmx
noreply at svn.ci.uchicago.edu
Wed Jul 9 15:16:57 CDT 2008
Author: skenny
Date: 2008-07-09 15:16:57 -0500 (Wed, 09 Jul 2008)
New Revision: 2109
Added:
SwiftApps/SIDGrid/swift/projects/skenny/openmx/modelgen.swift
Log:
generating models for openmx
Added: SwiftApps/SIDGrid/swift/projects/skenny/openmx/modelgen.swift
--- SwiftApps/SIDGrid/swift/projects/skenny/openmx/modelgen.swift (rev 0)
+++ SwiftApps/SIDGrid/swift/projects/skenny/openmx/modelgen.swift 2008-07-09 20:16:57 UTC (rev 2109)
@@ -0,0 +1,26 @@
+### generate openmx models in parallel
+### by number of connections
+type file{}
+# produce .RData file for each model object to be tested
+(file mxModels) mxmodel_generator (int conn, int ncol, file dot_r, file sdat, file spdat){
+ app{
+ RInvoke @filename(dot_r) conn ncol @filename(sdat) @filename(spdat);
+# map input and output for generator
+file modelgen<single_file_mapper;file="scripts/mxModelGen.R">;
+file sdat<single_file_mapper;file="matrices/s.dat">;
+file spdat<single_file_mapper;file="matrices/sp.dat">;
+ file potentialmodels<single_file_mapper;file=@strcat("models.tar")>;
+ (potentialmodels) = mxmodel_generator(4, 4, modelgen, sdat, spdat);
More information about the Swift-commit
