[Swift-commit] r2095 - in trunk: src/org/griphyn/vdl/karajan/lib	src/org/griphyn/vdl/mapping src/org/griphyn/vdl/type	tests/language-behaviour tests/misc
    noreply at svn.ci.uchicago.edu
    Tue Jul  8 01:55:32 CDT 2008
Author: benc
Date: 2008-07-08 01:55:32 -0500 (Tue, 08 Jul 2008)
New Revision: 2095
Added:
   trunk/src/org/griphyn/vdl/mapping/ExternalDataNode.java
   trunk/tests/language-behaviour/087-external-dataset.swift
   trunk/tests/misc/ordering-extern.sh
   trunk/tests/misc/restart-extern.sh
   trunk/tests/misc/restart-extern.swift
   trunk/tests/misc/restart-external.in
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/New.java
   trunk/src/org/griphyn/vdl/type/Types.java
   trunk/tests/misc/run
Log:
externally stored datasets
Modified: trunk/src/org/griphyn/vdl/karajan/lib/New.java
--- trunk/src/org/griphyn/vdl/karajan/lib/New.java	2008-07-07 19:37:13 UTC (rev 2094)
+++ trunk/src/org/griphyn/vdl/karajan/lib/New.java	2008-07-08 06:55:32 UTC (rev 2095)
@@ -18,6 +18,7 @@
 import org.griphyn.vdl.mapping.Path;
 import org.griphyn.vdl.mapping.RootArrayDataNode;
 import org.griphyn.vdl.mapping.RootDataNode;
+import org.griphyn.vdl.mapping.ExternalDataNode;
 import org.griphyn.vdl.mapping.file.ConcurrentMapper;
 import org.griphyn.vdl.type.Type;
 import org.griphyn.vdl.type.Types;
@@ -79,7 +80,9 @@
 				type = Types.getType(typename);
 			DSHandle handle;
-			if (type.isArray()) {
+			if(typename.equals("external")) {
+				handle = new ExternalDataNode();
+			} else if (type.isArray()) {
 				// dealing with array variable
 				handle = new RootArrayDataNode(type);
 				if (value != null) {
Added: trunk/src/org/griphyn/vdl/mapping/ExternalDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/ExternalDataNode.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/mapping/ExternalDataNode.java	2008-07-08 06:55:32 UTC (rev 2095)
@@ -0,0 +1,299 @@
+package org.griphyn.vdl.mapping;
+import org.griphyn.vdl.karajan.Loader;
+import java.util.ArrayList;
+import java.util.Collection;
+import java.util.HashMap;
+import java.util.Iterator;
+import java.util.LinkedList;
+import java.util.List;
+import java.util.Map;
+import org.apache.log4j.Logger;
+import org.griphyn.vdl.type.Field;
+import org.griphyn.vdl.type.NoSuchTypeException;
+import org.griphyn.vdl.type.Type;
+import org.griphyn.vdl.type.Types;
+public class ExternalDataNode implements DSHandle {
+        private Map params;
+        public void init(Map params) {
+                this.params = params;
+	static final String DATASET_URI_PREFIX = "tag:benc at ci.uchicago.edu,2008:swift:dataset:external:";
+	public static final Logger logger = Logger.getLogger(ExternalDataNode.class);
+	public static final MappingParam PARAM_PREFIX = new MappingParam("prefix", null);
+	/** Datasets are identified within a run by this sequence number and the
+	    partial ID field.
+	    The initial value is chosen to aid human recognition of sequence
+	    numbers in the wild. There is no requirement that it start at this
+	    (or any other) particular value. Note that this introduces a
+	    maximum on the number of datasets which can be dealt with in any
+	    run to be about 2^62. */
+	private static long datasetIDCounter = 720000000000l;
+	/** This is used to provide a (hopefully) globally unique identifier for
+	    each time the datasetIDCounter is reset (whenever this class is
+	    loaded, which will usually happen once per JVM). No meaning should be
+	    inferred from this value - it exists purely for making unique URIs. */
+	private static final String datasetIDPartialID = Loader.getUUID();
+	private Map handles;
+	private Object value;
+	private boolean closed;
+	private List listeners;
+	final String identifierURI = makeIdentifierURIString();
+	public ExternalDataNode() {
+	public Type getType() {
+		try {
+			return Types.getType("external");
+		} catch(NoSuchTypeException te) {
+			throw new RuntimeException(te);
+	public boolean isPrimitive() {
+		return false;
+	public boolean isRestartable() {
+		return true;
+	 * create a String representation of this node. If the node has a value,
+	 * then uses the String representation of that value. Otherwise, generates a
+	 * text description.
+	public String toString() {
+		if (this.value != null && !(this.value instanceof Exception)) {
+			// special handling for ints...
+			if (this.getType().equals(Types.INT)) {
+				try {
+					Number n = (Number) this.getValue();
+					return String.valueOf(n.intValue());
+				catch (ClassCastException e) {
+					throw new RuntimeException("Internal type error. Value is not a Number for "
+							+ getDisplayableName() + getPathFromRoot());
+			else {
+				return this.value.toString();
+		String prefix = this.getClass().getName();
+		prefix = prefix + " identifier "+this.getIdentifier();
+ 		prefix = prefix + " with no value at dataset=";
+		prefix = prefix + getDisplayableName();
+		if (!Path.EMPTY_PATH.equals(getPathFromRoot())) {
+			prefix = prefix + " path="+ getPathFromRoot().toString();
+		if(closed) {
+			prefix = prefix + " (closed)";
+		else {
+			prefix = prefix + " (not closed)";
+		return prefix;
+	public DSHandle getRoot() {
+		return this;
+	protected String getDisplayableName() {
+		String prefix = getRoot().getParam("dbgname");
+		if (prefix == null) {
+			prefix = getRoot().getParam("prefix");
+			prefix = "unnamed SwiftScript value";
+		return prefix;
+	public DSHandle getField(Path path) throws InvalidPathException {
+		if (path.isEmpty()) {
+			return this;
+		} else {
+			throw new InvalidPathException(path, this);
+	public Collection getFields(Path path) throws InvalidPathException, HandleOpenException {
+		List fields = new ArrayList();
+		return fields;
+	public void set(DSHandle handle) {
+		throw new IllegalArgumentException(this.getDisplayableName() + " is an external dataset and cannot be set");
+	protected void setField(String name, DSHandle handle) {
+		synchronized (handles) {
+			handles.put(name, handle);
+	protected DSHandle getHandle(String name) {
+			return (DSHandle) handles.get(name);
+	protected boolean isHandlesEmpty() {
+			return handles.isEmpty();
+	protected void checkDataException() {
+		if (value instanceof DependentException) {
+			throw (DependentException) value;
+	protected void checkMappingException() {
+		if (value instanceof MappingDependentException) {
+			throw (MappingDependentException) value;
+	public Object getValue() {
+logger.warn("getValue called in an external dataset");
+return value;
+// throw new RuntimeException("cannot get value of external dataset");
+	public Map getArrayValue() {
+throw new RuntimeException("cannot get value of external dataset");
+	public boolean isArray() {
+		return false;
+	public void setValue(Object value) {
+		if (this.closed) {
+					+ " is closed with a value of "+this.value);
+		if (this.value != null) {
+					+ " is already assigned with a value of " + this.value);
+		this.value = value;
+	public Collection getFringePaths() throws HandleOpenException {
+		ArrayList list = new ArrayList();
+		list.add(Path.EMPTY_PATH);
+		return list;
+	public synchronized void closeShallow() {
+		this.closed = true;
+		notifyListeners();
+		logger.info("closed "+this.getIdentifier());
+	public boolean isClosed() {
+		return closed;
+	public void closeDeep() {
+		if (!this.closed) {
+			closeShallow();
+			Iterator i = handles.entrySet().iterator();
+			while (i.hasNext()) {
+				Map.Entry e = (Map.Entry) i.next();
+				AbstractDataNode mapper = (AbstractDataNode) e.getValue();
+				mapper.closeDeep();
+	public Path getPathFromRoot() {
+		return Path.EMPTY_PATH;
+	public Mapper getMapper() {
+		return null;
+	protected Map getHandles() {
+		return handles;
+	public synchronized void addListener(DSHandleListener listener) {
+		if (logger.isInfoEnabled()) {
+			logger.info("Adding handle listener \"" + listener + "\" to \"" + this + "\"");
+		if (listeners == null) {
+			listeners = new LinkedList();
+		listeners.add(listener);
+		if (closed) {
+	protected synchronized void notifyListeners() {
+		if (listeners != null) {
+			Iterator i = listeners.iterator();
+				DSHandleListener listener = (DSHandleListener) i.next();
+				i.remove();
+					logger.info("Notifying listener \"" + listener + "\" about \"" + this + "\"");
+				listener.handleClosed(this);
+			listeners = null;
+	public String getIdentifier() {
+		return identifierURI;
+	String makeIdentifierURIString() {
+		datasetIDCounter++;
+		return DATASET_URI_PREFIX + datasetIDPartialID + ":" + datasetIDCounter;
+        public String getParam(String name) {
+                if (params == null) {
+                        return null;
+                return (String) params.get(name);
+  public DSHandle createDSHandle(String fieldName) {
+throw new RuntimeException("cannot create new field in external dataset");
+        public DSHandle getParent() {
+                return null;
Modified: trunk/src/org/griphyn/vdl/type/Types.java
--- trunk/src/org/griphyn/vdl/type/Types.java	2008-07-07 19:37:13 UTC (rev 2094)
+++ trunk/src/org/griphyn/vdl/type/Types.java	2008-07-08 06:55:32 UTC (rev 2095)
@@ -55,7 +55,7 @@
 		return type;
-	public static final Type INT, STRING, FLOAT, BOOLEAN, ANY;
+	public static final Type INT, STRING, FLOAT, BOOLEAN, ANY, EXTERNAL;
 	// add built-in primitive types
 	static {
@@ -64,6 +64,7 @@
 		FLOAT = addPrimitiveType("float");
 		BOOLEAN = addPrimitiveType("boolean");
 		ANY = addPrimitiveType("any");
+		EXTERNAL = addPrimitiveType("external");
 	public synchronized static void resolveTypes() throws NoSuchTypeException {
Added: trunk/tests/language-behaviour/087-external-dataset.swift
--- trunk/tests/language-behaviour/087-external-dataset.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/087-external-dataset.swift	2008-07-08 06:55:32 UTC (rev 2095)
@@ -0,0 +1,19 @@
+type file;
+(external o) a() {
+    app {
+        touch "foo";
+b(external o) {
+    app {
+        touch "bar";
+external sync;
+sync=a();
+b(sync);
Added: trunk/tests/misc/ordering-extern.sh
--- trunk/tests/misc/ordering-extern.sh	                        (rev 0)
+++ trunk/tests/misc/ordering-extern.sh	2008-07-08 06:55:32 UTC (rev 2095)
@@ -0,0 +1,51 @@
+#!/bin/bash
+export CF=swift.properties.restart-extern
+cat $(dirname $(which swift))/../etc/swift.properties | grep --invert-match -E '^lazy.errors=' > $CF
+echo lazy.errors=true >> $CF
+rm -f *.rlog restart-*.out restart-extern.kml restart-extern.xml restart-*.out
+rm -rf _concurrent
+echo "localhost	helperA	$(pwd)/restart5-helper-success	INSTALLED	INTEL32::LINUX	null" > tmp.restartOK.tc.data
+echo "localhost	helperB	$(pwd)/restart5-helper-success	INSTALLED	INTEL32::LINUX	null" >> tmp.restartOK.tc.data
+echo "localhost	helperC	$(pwd)/restart5-helper-success	INSTALLED	INTEL32::LINUX	null" >> tmp.restartOK.tc.data
+swift -config $CF -tc.file tmp.restartOK.tc.data restart-extern.swift -dir=`pwd`
+PRECHECKEXIT=$?
+if [ "$PRECHECKEXIT" != 0 ]; then
+  echo Failed - attempt to run workflow without ordering configuration failed
+  exit 1
+fi
+rm -rf _concurrent
+# make A fail and B succeed.
+# extern dependency ordering should mean that B does not run.
+echo "localhost	helperA	$(pwd)/restart5-helper-fail	INSTALLED	INTEL32::LINUX	null" > tmp.restartB.tc.data
+echo "localhost	helperB	$(pwd)/restart5-helper-success	INSTALLED	INTEL32::LINUX	null" >> tmp.restartB.tc.data
+echo "localhost	helperC	$(pwd)/restart5-helper-success	INSTALLED	INTEL32::LINUX	null" >> tmp.restartB.tc.data
+swift -config $CF -tc.file tmp.restartB.tc.data restart-extern.swift -dir=`pwd`
+SECONDEXIT=$?
+if [ "$SECONDEXIT" = "0" ]; then
+  echo Failed - broken apps succeeded
+  exit 2
+fi
+if [ -f restart-extern.2.out ] || [ -f restart-extern.1.out ]; then
+  echo Failed - output files came into existence that indicate external dependency was ignored
+  exit 3
+fi
+echo restart-exterm success
+exit 0
Added: trunk/tests/misc/restart-extern.sh
--- trunk/tests/misc/restart-extern.sh	                        (rev 0)
+++ trunk/tests/misc/restart-extern.sh	2008-07-08 06:55:32 UTC (rev 2095)
@@ -0,0 +1,64 @@
+#!/bin/bash
+export CF=swift.properties.restart5
+rm -f *.rlog restart-*.out restart5.kml restart5.xml restart5.*.out restart5.*.out.single-run
+rm -rf _concurrent
+PRECHECKEXIT=$?
+  echo Failed - attempt to run workflow without restart configuration failed
+  exit 1
+fi
+rm -rf _concurrent
+echo "localhost	helperA	$(pwd)/restart5-helper-success	INSTALLED	INTEL32::LINUX	null" > tmp.restartA.tc.data
+echo "localhost	helperB	$(pwd)/restart5-helper-fail	INSTALLED	INTEL32::LINUX	null" >> tmp.restartA.tc.data
+echo "localhost	helperC	$(pwd)/restart5-helper-success	INSTALLED	INTEL32::LINUX	null" >> tmp.restartA.tc.data
+swift -config $CF -tc.file tmp.restartA.tc.data restart-extern.swift -dir=`pwd`
+FIRSTEXIT=$?
+# this invocation should fail, with restart-1.out in existence but
+# not the others
+if [ "$FIRSTEXIT" == 0 ]; then
+  echo Failed - workflow was indicated as successfully completed the first time round.
+  exit 2
+fi
+# now make A fail - we should have run it already, and so we want to make
+# sure it does not run again; and make B succeed this time round.
+# there should be only a single rlog here, because we deleted them all
+# at the start of this script.
+swift -config $CF -resume *.rlog -tc.file tmp.restartB.tc.data restart-extern.swift -dir=`pwd`
+SECONDEXIT=$?
+if [ "$SECONDEXIT" != "0" ]; then
+  echo Failed - second round failed
+  exit 3
+fi
+exit 0
Added: trunk/tests/misc/restart-extern.swift
--- trunk/tests/misc/restart-extern.swift	                        (rev 0)
+++ trunk/tests/misc/restart-extern.swift	2008-07-08 06:55:32 UTC (rev 2095)
@@ -0,0 +1,18 @@
+type file;
+(external o) a() {
+    app {
+        helperA @strcat(@arg("dir"),"/restart-extern.1.out") "/etc/group" "qux";
+b(external o) {
+    app {
+        helperB @strcat(@arg("dir"),"/restart-extern.2.out") "/etc/group" "baz";
+external sync;
+sync=a();
+b(sync);
Added: trunk/tests/misc/restart-external.in
--- trunk/tests/misc/restart-external.in	                        (rev 0)
+++ trunk/tests/misc/restart-external.in	2008-07-08 06:55:32 UTC (rev 2095)
@@ -0,0 +1 @@
+foo
Modified: trunk/tests/misc/run
--- trunk/tests/misc/run	2008-07-07 19:37:13 UTC (rev 2094)
+++ trunk/tests/misc/run	2008-07-08 06:55:32 UTC (rev 2095)
@@ -1,5 +1,7 @@
 #!/bin/sh
-for a in clusters no-retries dryrun typecheck path-prefix restart restart2 restart3 restart4 restart5 restart-iterate workernode-local; do
+for a in clusters no-retries dryrun typecheck path-prefix restart restart2 restart3 restart4 restart5 restart-iterate workernode-local \
+ordering-extern-notlazy restart-extern ordering-extern \
+; do
  ./${a}.sh
  R=$?
  echo test $a ended with return value $R
More information about the Swift-commit
