[Swift-commit] r2091 - trunk/src/org/griphyn/vdl/karajan/lib
Mon Jul 7 11:55:08 CDT 2008
Author: benc
Date: 2008-07-07 11:55:08 -0500 (Mon, 07 Jul 2008)
New Revision: 2091
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/IsLogged.java
   trunk/src/org/griphyn/vdl/karajan/lib/LogVar.java
   trunk/src/org/griphyn/vdl/karajan/lib/New.java
Log:
restarts based on variable name rather than filename
Modified: trunk/src/org/griphyn/vdl/karajan/lib/IsLogged.java
--- trunk/src/org/griphyn/vdl/karajan/lib/IsLogged.java	2008-07-07 16:17:57 UTC (rev 2090)
+++ trunk/src/org/griphyn/vdl/karajan/lib/IsLogged.java	2008-07-07 16:55:08 UTC (rev 2091)
@@ -3,6 +3,7 @@
 package org.griphyn.vdl.karajan.lib;
+import java.util.List;
 import java.util.Map;
 import org.globus.cog.karajan.arguments.Arg;
@@ -10,7 +11,6 @@
 import org.globus.cog.karajan.util.TypeUtil;
 import org.globus.cog.karajan.workflow.ExecutionException;
 import org.globus.cog.karajan.workflow.nodes.restartLog.LogEntry;
-import org.globus.cog.karajan.workflow.nodes.restartLog.MutableInteger;
 import org.griphyn.vdl.mapping.DSHandle;
 import org.griphyn.vdl.mapping.Path;
@@ -30,13 +30,12 @@
 			path = Path.parse(TypeUtil.toString(p));
 		path = var.getPathFromRoot().append(path);
-		String file = var.getMapper().map(path).toString();
-		LogEntry entry = LogEntry.build(file);
+		LogEntry entry = LogEntry.build(var.getRoot().getParam("swift#restartid") + "." + path.stringForm());
 		Map map = getLogData(stack);
 		boolean found = false;
 		synchronized (map) {
-			MutableInteger count = (MutableInteger) map.get(entry);
-			if (count != null && count.getValue() > 0) {
+			List files = (List) map.get(entry);
+			if (files != null && !files.isEmpty()) {
 				found = true;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/LogVar.java
--- trunk/src/org/griphyn/vdl/karajan/lib/LogVar.java	2008-07-07 16:17:57 UTC (rev 2090)
+++ trunk/src/org/griphyn/vdl/karajan/lib/LogVar.java	2008-07-07 16:55:08 UTC (rev 2091)
@@ -31,7 +31,14 @@
-		RestartLog.LOG_CHANNEL.ret(stack, var.getMapper().map(path).toString());
+		String annotation;
+		if(var.getMapper() != null) {
+			annotation = "" + var.getMapper().map(path);
+		} else {
+			annotation = "unmapped";
+		RestartLog.LOG_CHANNEL.ret(stack, var.getRoot().getParam("swift#restartid")
+				+ "." + path.stringForm() + "!" + annotation);
 		return null;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/New.java
--- trunk/src/org/griphyn/vdl/karajan/lib/New.java	2008-07-07 16:17:57 UTC (rev 2090)
+++ trunk/src/org/griphyn/vdl/karajan/lib/New.java	2008-07-07 16:55:08 UTC (rev 2091)
@@ -52,6 +52,8 @@
 			mapping.put("dbgname", dbgname);
+		mapping.put("swift#restartid", getThreadPrefix(stack) + ":" + dbgname);
 		if(waitfor != null) {
 			mapping.put("waitfor", waitfor);
