sieve-dev FIAT import question
    Matthew Knepley
    knepley at gmail.com
    Tue Mar 25 10:45:31 CDT 2008
On Tue, Mar 25, 2008 at 9:51 AM, Jed Brown <jed at 59a2.org> wrote:
> On Tue 2008-03-25 08:57, Matthew Knepley wrote:
>  > On Tue, Mar 25, 2008 at 8:47 AM, Jed Brown <jed at 59a2.org> wrote:
>  > > On Tue 2008-03-25 08:24, Matthew Knepley wrote:
>  > >  > On Tue, Mar 25, 2008 at 7:22 AM, Jed Brown <jed at 59a2.org> wrote:
>  > >  > > When I try to build the sieve examples, I get errors like the one below.  If I
>  > >  > >  move the `import FIAT.shapes' up to the top of the file, it works just fine.  I
>  > >  > >  don't know if there is something peculiar about my configuration, but this
>  > >  > >  problem hasn't gone away in the last weeks so I thought I'd mention it.  My
>  > >  > >  configuration included the options:
>  > >  > Do you have numpy in a weird place? You are the first to report this
>  > >  > error, and I
>  > >  > am not sure sure how moving an import would matter, but evidently on your
>  > >  > system it does somehow. In order to debug it, I need to know how you installed
>  > >  > numpy.
>  > >  No, it is in /usr/lib/python2.5/site-packages/numpy/.  I see the same problem on
>  > >  two systems, an x86 Ubuntu system with numpy installed via apt and an x86_64
>  > I have exactly an x86 Ubuntu apt system and do not get this error (and
>  > neither do
>  > my students, Bras at USGS, Charles at RPI, or Shi Jin in UMBC), so
>  > something must
>  > be different. There is something that prevents the import the second
>  > time, but it
>  > probably an error in some installed python package, and I would need
>  > to be on the
>  > system to find it (I already found one in the last version of numpy).
>  Well, that is indeed strange.  I suppose the purpose of importing after setup()
>  is to be able to fix paths, but in my case, FIAT is already available in my
>  PYTHONPATH.  Perhaps this has something to do with it.  It's not clear to me
>  that there is something wrong with my python install since ``do nothing'' is
>  exactly what needs to be done.  That is, just transposing the import line with
>  setup() works fine.  I'm not a python guru and hunting down the source of this
>  problem is really not interesting.  Apparently it doesn't affect anyone else.
If I ever get a system where this happens I can track it down, but for now I am
not sure what to do.
>  By the way, building with gcc 4.3.0 brought out the need for the following.
>  Without <cmalloc>, there is no std::malloc or std::free.
Yep, I had gotten that report, it just didn't get pushed yet.
    Matt
>  diff -r 6cfe5326613c src/dm/mesh/sieve/ALE_mem.hh
>  --- a/src/dm/mesh/sieve/ALE_mem.hh      Tue Mar 25 06:13:18 2008 -0500
>  +++ b/src/dm/mesh/sieve/ALE_mem.hh      Tue Mar 25 15:38:50 2008 +0100
>  @@ -6,6 +6,7 @@
>   #include <iostream>
>   #include <map>
>   #include <memory>
>  +#include <cstdlib>
>   #include <typeinfo>
>   #include <petsc.h>
>   #include <ALE_log.hh>
>  Jed
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
More information about the sieve-dev
