sieve-dev problem with multiple meshes
Shi Jin
jinzishuai at yahoo.com
Tue Nov 20 20:21:00 CST 2007
I have tried to convert my code from fibration to multiple meshes. It does not seem to be very difficult. However, I do have a problem about the shared meshes. For example, in the CreateMesh() of grade2 example, I added
int height=m->height();
int depth=m->depth();
int dimension=m->getDimension();
PetscPrintf(m->comm(),"height=%d,depth=%d,dimension=%d\n",height,depth,dimension);
For the new meshes transportMesh. The output is
height=-1,depth=-1,dimension=2
which is not the same as it should be. f it is sharing the same mesh as stokesMesh, it should be
height=2,depth=2,dimension=2
Do you have a fix to this? Thanks.
Shi Jin, PhD
____________________________________________________________________________________
Be a better pen pal.
Text or chat with friends inside Yahoo! Mail. See how. http://overview.mail.yahoo.com/
URL: <https://lists.mcs.anl.gov/mailman/private/sieve-dev/attachments/20071120/47f67c24/attachment.html>
More information about the sieve-dev
