[petsc-users] Questions on QR methods in PETSc
Matthew Knepley
knepley at gmail.com
Fri Mar 27 13:24:55 CDT 2026
Hi Leonardo,
On Fri, Mar 27, 2026 at 11:35 AM Leonardo De Novellis via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear Users Support Team,
> I have a couple of questions regarding QR decompositions in PETSc.
> 1) I would like to find the least-squares solution of a rectangular system
> of the form Ax = b, where A is a dense and tall-skinny matrix (size around
> 1000000 x 10).
> Since A has very bad conditioning, I want to avoid iterative methods (such
> as KSPLSQR), since the number of iterations can get very large, and would
> like to use a direct QR solving method.
> Currently, I am running my code on only 1 core, and A is of type seqaij.
> With this setup, the following code works fine:
> call KSPSetType(ksp, KSPPREONLY, ierr)
> call KSPGetPC(ksp, pc, ierr)
> call PCSetType(pc, PCQR, ierr)
> call KSPSetOperators(ksp, A, A, ierr)
> t1 = MPI_Wtime()
> call KSPSolve(ksp, b, x, ierr)
> t2 = MPI_Wtime()
> I eventually want to run this in parallel on multiple cores. Will PCQR
> work for an mpiaij / mpidense matrix?
No it is only serial. We could call the ScLAPACK or Elemental version of
QR, but we don't right now.
> If not, what would you suggest as a direct solving approach for this
> system?
It would be easy to make the normal equations (dot products would make the
matrix on all procs) and factor.
> 2) I would also like to compute an explicit QR decomposition of A, and
> want to do so in parallel. Is there any way to do so in PETSc? If not, as a
> possible alternative, would you recommend using SLEPc BVOrthogonalize
> function?
I would definitely recommend using BV. I have been meaning to pull that
into PETSc because it is so great, but have not done it yet. You can just
reconfigure with --download-slepc and run with it.
Matt
> Kind regards,
> Leonardo
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Z4T-_YeS6p8NNr11QP3I3s_AuA703BYFYU_kioU8FmIJV9NlyY9GTk0HN36-zO9hRinjxpI1ipiRQe8yYU1n$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Z4T-_YeS6p8NNr11QP3I3s_AuA703BYFYU_kioU8FmIJV9NlyY9GTk0HN36-zO9hRinjxpI1ipiRQTzD2Xzg$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260327/ab2adc23/attachment.html>
