[petsc-users] 20-node hexes
Noam T. dontbugthedevs at proton.me
Wed Mar 25 03:50:58 CDT 2026
Hello,
Is it possible to build/use a mesh consisting of 20-node hexes in PETSc?
I tried reading (-dm_plex_filename) an existing mesh, with a 20-node cube, from gmsh (using the option "SecondOrderIncomplete"); statistics show 20 nodes, however the "Entities" section still only contains 8 vertices, so that may not work here.
Using -petscdualspace_lagrange_XYZ I could not achieve this either.
I searched some old threads in the mailing list; there are a couple, but they don't specify how they build it; they just mention they are using such mesh.
Searching for "serendipity" in the documentation did not return anything either.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260325/00b59e7b/attachment.html>
