[petsc-users] Issue: Building PLC from STL for DMPlexGenerate_Tetgen and Geometry-Aware workflows
陈日刀
chenridao45 at gmail.com
Mon Mar 23 01:21:12 CDT 2026
Dear PETSc Team,
My name is Zhaoyang Chen, a senior undergraduate at Hunan University. I am
working on a meshing workflow using DMPlex and am particularly interested
in utilizing the geometry-aware features such as *DMPlexSnapToGeomModel()*
and refinement snapping.
My input data consists of *high-resolution STL triangulations*. I have
encountered a major bottleneck at the very beginning of the pipeline:
*constructing
the Piecewise Linear Complex (PLC)* from the STL to be used by
*DMPlexGenerate_Tetgen().*
Since the downstream geometry-aware operations (like
*DMPlexSnapToGeomModel()* ) rely on a valid underlying geometry
representation, I need to resolve the PLC construction issue first.
Specifically:
1.
*STL to PLC Ingestion*: Is there a native or recommended pathway in
PETSc to ingest an STL file and define it as the PLC for volume mesh
generation?
2.
*Compatibility with Snapping*: If the PLC is successfully built from an
STL, can the resulting* DMPlex* still utilize *DMPlexSnapToGeomModel()*?
Or is the "Geometry-Aware" snapping strictly reserved for analytical B-Rep
models (e.g., via EGADS)?
I am trying to understand if PETSc supports a workflow where a discrete
surface (STL) acts as the "GeomModel" for both initial volumetric meshing
and subsequent snapping/refinement. Any guidance on how to bridge STL data
with the DMPlex geometry-aware pipeline would be greatly appreciated.
Best regards,
Zhaoyang Chen
Hunan University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260323/2dacbcd7/attachment.html>
