[petsc-users] Different precision from MatAssembly/MatView
Matthew Knepley
knepley at gmail.com
Sun Mar 15 11:10:58 CDT 2026
On Sun, Mar 15, 2026 at 10:30 AM Noam T. via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello,
> Looking at the assembly of the Jacobian using MatView, I noticed values
> were somewhat different from the computed ones in the jacobian function
> (DMSNESSetJacobian). For the test, I used a single Q1 element, with 4
> quadrature points, so the exact Jacobian matrix can be computed
> analytically.
> In the jacobian function, after looping through all quadrature points,
> printing the matrix to stdout shows:
> 0.531360000000 0.066670000000 0.197333333327
> 0.066670000000 0.535360000000 -0.003333333327
> 0.197333333327 -0.003333333327 0.527413333333
> (showing only the 3 free DoFs). The 2x2 submatrix in [0:1] has exactly
> four/five nonzero digits, as shown above. The rest of the elements have a
> periodic 3 ending (a couple of digits at the end are off, but that's fine).
> This same matrix is the one added to the global jacobian during the
> quadrature loop, with "DMPlexMatSetClosure". After looping, calling
> "MatAssemblyBegin/End", then MatView:
> Mat Object: 1 MPI process
> type: seqaij
> row 0: (0, 0.531387) (1, 0.0666733) (2, 0.197338)
> row 1: (0, 0.0666733) (1, 0.535387) (2, -0.0033385)
> row 2: (0, 0.197338) (1, -0.0033385) (2, 0.52744)
This looks like a change in the precision of output (which here seems to be
6 digits), and not in the internal representation.
Matt
> Values are close, but definitely not the same as computed. Are these
> values from "MatView" the ones actually stored in the matrix? It seems
> there is some precision loss in the process.
> Interestingly, computing the jacobian through finite differences, shows
> the same result for the "hand-coded" jacobian, whereas the finite
> differences ones is the "exact" one (same as first one above):
> ||J - Jfd||_F/||J||_F = 4.90736e-05, ||J - Jfd||_F = 4.74265e-05
> Hand-coded Jacobian ----------
> type: seqaij
> Finite difference Jacobian ----------
> type: seqaij
> row 0: (0, 0.53136) (1, 0.06667) (2, 0.197333)
> row 1: (0, 0.06667) (1, 0.53536) (2, -0.00333333)
> row 2: (0, 0.197333) (1, -0.00333333) (2, 0.527413)
> Hand-coded minus finite-difference Jacobian with tolerance 1e-05
> type: seqaij
> row 0: (0, 2.66554e-05)
> row 1: (1, 2.66554e-05)
> row 2: (2, 2.6558e-05)
> The main code is in Fortran, using double precision variables, in case it
> is relevant.
> Thank you.
> Noam
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bCJxKi_fK-R4qOPIue1cGVfbUvleHUrCejE8OHc3uYgb5tFWMvumeRKgYa27f7q6xulACFMRRdrwtRXkP-2A$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bCJxKi_fK-R4qOPIue1cGVfbUvleHUrCejE8OHc3uYgb5tFWMvumeRKgYa27f7q6xulACFMRRdrwtenfIBGF$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260315/f6b020e5/attachment.html>
