[petsc-users] Problem running ex50 after compilation
Satish Balay
balay.anl at fastmail.org
Fri Jan 30 23:24:36 CST 2026
Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --download-mpich --download-fblaslapack
Ok - so you've installed MPI via --download-mpich - so you need to use:
mpiexec: /home/skirthy/petsc/arch-linux-c-debug/bin/mpiexec
[likely mpiexec used below is a different one]
Satish
On Sat, 31 Jan 2026, Srinivas Kirthy K wrote:
> Hi,
> I'm new to PETSc.
> I was able to compile ex50.c using:
> *cd petsc/src/ksp/ksp/tutorials*
> *make ex50*
> When I run: *mpiexec -n 1 ./ex50 -da_grid_x 4 -da_grid_y 4 -mat_view*
> I get the error message in *PETSC_mpiexec_error.txt *(attached)
> I've defined these in the ~/.bashrc:
> *export PETSC_DIR=$HOME/petsc # added on 31/01/2026 to define PETSC
> locationexport PETSC_ARCH=arch-linux-c-debug*
> Can you help me fix this?
> I've attached the *configure.log* file as well.
> Thanks in advance.
