[petsc-users] Mapping between local, partition and global with dmplex.
neil liu liufield at gmail.com
Tue Jan 27 22:39:55 CST 2026
Thanks a lot, Matt.
I assemble a matrix using MatSetValuesLocal(), where the cell-to-local
mapping comes from PetscSectionGetOffset().
With 2 MPI ranks, Valgrind (rank 0) reports uninitialized data being passed
to MPI_Isend during matrix assembly (inside matstash.c).
Two observations:
   If I hard-code the local mapping to always be 1, the Valgrind warning
   disappears.
   The warning occurs with PETSc *3.23.3*, but disappears when switching to
   *3.24.3* under the same setup.
This suggests either uninitialized local indices/values on my side, or a
change in PETSc between these versions affecting stash packing or index
handling.
Does this type of Valgrind warning usually point to user-provided local
indices being uninitialized, and were there relevant changes in this area
between 3.23.3 and 3.24.x?
Xiaodong
==683913== Syscall param write(buf) points to uninitialised byte(s)
==683913==    at 0xCAD15A8: write (in /usr/lib64/libc-2.28.so)
==683913==    by 0xBB9B0A9: MPIDI_CH3I_Sock_write (sock.c:2622)
==683913==    by 0xBBA12DF: MPIDI_CH3_iStartMsg (ch3_istartmsg.c:68)
==683913==    by 0xBB55F82: MPIDI_CH3_RndvSend (ch3u_rndv.c:48)
==683913==    by 0xBB70905: MPID_Isend (mpid_isend.c:159)
==683913==    by 0xB83EDB7: internal_Isend_c (isend.c:273)
==683913==    by 0xB83EFE9: PMPI_Isend_c (isend.c:363)
==683913==    by 0x82CAC1A: MatStashBTSSend_Private (matstash.c:793)
==683913==    by 0x6AA2BF8: PetscCommBuildTwoSidedFReq_Reference
(mpits.c:311)
==683913==    by 0x6AA9DAD: PetscCommBuildTwoSidedFReq (mpits.c:515)
==683913==    by 0x82CEB46: MatStashScatterBegin_BTS (matstash.c:920)
==683913==    by 0x82C009D: MatStashScatterBegin_Private (matstash.c:440)
==683913==    by 0x73E77BF: MatAssemblyBegin_MPIAIJ (mpiaij.c:768)
==683913==    by 0x81F0777: MatAssemblyBegin (matrix.c:5807)
On Tue, Jan 27, 2026 at 6:13 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jan 27, 2026 at 3:34 PM neil liu <liufield at gmail.com> wrote:
>> Dear Petsc users and developers,
>> I am exploring the mapping between local, partition and global dofs.
>> The following is my pseudo code, dof2Partitionmapping denotes the mapping
>> between the local dof (20 local dofs each tetrahedra) and partition dof.
> We usually say cell, local, and global dofs.
>> Is this mapping determined by Petsc itself under the hood
>> (PetscSectionGetOffset)?
> Plex just iterates over the points in the canonical numbering (cells,
> vertices, faces, edges). You can change the iteration order using
> https://urldefense.us/v3/__https://petsc.org/main/manualpages/PetscSection/PetscSectionSetPermutation/__;!!G_uCfscf7eWS!Z7m5oJFaTt_KCIUQJxJx-4SEoHIv5k1rWuDb3ClOur8MISuVMaOzs6WTo6lqZ2OWUBvBAKwK4hyKszJ1HUAjOw$
> You can use that, for example, to place all ghost dofs at the end.
>   Thanks,
>      Matt
>> For now, I am coding this mapping (local to partition) myself just based
>> on the edge and face number in the partition. It seems the results are
>> reasonable. But with this kind of self-defined mapping, the owned dofs and
>> ghost dofs are interleaved. Will this bring bad results for the
>> communication of MatStash?
>> Thanks,
>> Xiaodong
>> *1. set 2 dofs for each edge  and 2 dofs for each edge face respectively*
>> PetscSectionSetChart(s, faceStart, edgeEnd);
>> PetscSectionSetDof(s, faceIndex, 2);
>> PetscSectionSetFieldDof(s, faceIndex, 0, 1);
>> PetscSectionSetDof(s, edgeIndex, 2);
>> PetscSectionSetFieldDof(s, edgeIndex, 0, 1);
>> PetscSectionsetup(s)
>> *2.  Create matrix based on DMPlex*
>>  DMSetMatType(dm, MATAIJ);
>>  DMCreateMatrix(dm, &A);
>> *3. loop over elements to set local values for Matrix*
>> MatSetValuesLocal(A, dof2Partitionmapping.size(),
>> dof2Partitionmapping.data(), dof2Partitionmapping.size(),
>> dof2Partitionmapping.data(), Matrix_Local.data(), ADD_VALUES);
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Z7m5oJFaTt_KCIUQJxJx-4SEoHIv5k1rWuDb3ClOur8MISuVMaOzs6WTo6lqZ2OWUBvBAKwK4hyKszJveN_t0Q$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Z7m5oJFaTt_KCIUQJxJx-4SEoHIv5k1rWuDb3ClOur8MISuVMaOzs6WTo6lqZ2OWUBvBAKwK4hyKszK-GUW0Jw$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260127/d01dfd0f/attachment-0001.html>
