[petsc-users] Performance with GPU and multiple MPI processes per GPU
Junchao Zhang
junchao.zhang at gmail.com
Tue Jan 20 10:17:21 CST 2026
Hello Babriele,
Maybe you can try CUDA MPS service, to effectively map multiple processes
to one GPU. First, I would create a directory $HOME/tmp/nvidia-mps (by
default, cuda will use /tmp/nvidia-mps), then use these steps
export CUDA_MPS_PIPE_DIRECTORY=$HOME/tmp/nvidia-mps
export CUDA_MPS_LOG_DIRECTORY=$HOME/tmp/nvidia-mps
# Start MPS
nvidia-cuda-mps-control -d
# run the test
mpiexec -n 16 ./test
# shut down MPS
echo quit | nvidia-cuda-mps-control
I would also like to block-map MPI processes to GPUs manually via
manipulating the env var CUDA_VISIBLE_DEVICES. So I have this bash script
* set_gpu_device.sh *on my PATH (assume you use OpenMPI)
#!/bin/bash
GPUS_PER_NODE=2
export
CUDA_VISIBLE_DEVICES=$((OMPI_COMM_WORLD_LOCAL_RANK/(OMPI_COMM_WORLD_LOCAL_SIZE/GPUS_PER_NODE)))
exec $*
In other words, to run the test, I use
mpiexec -n 16 set_gpu_device.sh ./test
Let us know if it helps so that we can add the instructions to the PETSc
doc.
Thanks.
--Junchao Zhang
On Tue, Jan 20, 2026 at 8:21 AM Gabriele Penazzi via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi.
> I am using PETSc conjugate gradient liner solver with GPU acceleration
> (CUDA), on multiple GPUs and multiple MPI processes.
> I noticed that the performances degrade significantly when using multiple
> MPI processes per GPU, compared to using a single process per GPU.
> For example, 2 GPUs with 2 MPI processes will be about 40% faster than
> running the same calculation with 2 GPUs and 16 MPI processes.
> I would assume the natural MPI/GPU affinity would be 1-1, however the rest
> of my application can benefit from multiple MPI processes driving GPU via
> nvidia MPS, therefore I am trying to understand if this is expected, if I
> am possibly missing something in the initialization/setup, or if my best
> choice is to constrain 1-1 MPI/GPU access especially for the PETSc linear
> solver step. I could not find explicit information about it in the manual.
> Is there any user or maintainer who can tell me more about this use case?
> Best Regards,
> Gabriele Penazzi
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260120/6fb0fc66/attachment.html>
