[petsc-users] From explicit matrix using MatSchurComplementComputeExplicitOperator
Mon Jan 19 13:53:49 CST 2026
Note that you can do everything above with options alone. You do not need
the code.
     Matt
On Mon, Jan 19, 2026 at 2:35 PM Barry Smith <bsmith at petsc.dev> wrote:
>   Apparently. Just call ISSort() on the IS after forming it.
> On Jan 19, 2026, at 1:31 PM, neil liu <liufield at gmail.com> wrote:
> Dear Petsc developers and users,
> I am exploring Schur complement to reuse the inverse of A, for a block
> matrix [ A B; C D].
> Here A's size is much bigger than D. Therefore it is desirable to reuse
> the inverse of A. The code is listed below. It works well for 10k
> tetrahedra elements on 4 ranks . But it shows some error for a coarse mesh
> (260 tetrahedra cells) on 4 ranks.
> Do i have to sort *isNonPort and isPort? *
> Thanks a lot,
> Xiaodong
> *MatCreateSubMatrix(A, isNonPort, isNonPort, MAT_INITIAL_MATRIX, &A11);*
> *MatCreateSubMatrix(A, isNonPort, isPorts, MAT_INITIAL_MATRIX, &A12);*
> * MatCreateSubMatrix(A, isPorts, isNonPort, MAT_INITIAL_MATRIX, &A21); *
> * MatCreateSubMatrix(A, isPorts, isPorts, MAT_INITIAL_MATRIX, &A22);*
> * Mat S; *
> * MatCreateSchurComplement(A11, A11, A12, A21, A22, &S); *
> * MatSchurComplementSetKSP(S, kspA11);*
> * Mat Sdense; *
> *MatSchurComplementComputeExplicitOperator(S, &Sdense); *
> * MatAssemblyBegin(Sdense, MAT_FINAL_ASSEMBLY); *
> * MatAssemblyEnd(Sdense, MAT_FINAL_ASSEMBLY);*
> [1]PETSC ERROR: Argument out of range
> [1]PETSC ERROR: Column entry number 2 (actual column 0) in row 74 is not
> sorted
> [1]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!YH0t05h5r0tMJy6-pB5RzN_AwWN0iQY4UAOIQVHEfpxNqymQUvBLWIJYW1am1lI2_cmGA7muK6572KeG1ch8$
> <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!az-Ao1BxQdotvJlqia0i_iZ5sCx1AZNlDZwT2d1YUzJ4TE_esLV_bwZ-lyIBrsVlK3JJu36cOohpqoohAStoSQ$> for
> trouble shooting.
> [1]PETSC ERROR: PETSc Release Version 3.23.3, May 30, 2025
> [1]PETSC ERROR: ./app with 4 MPI process(es) and PETSC_ARCH
> arch-linux-c-debug
> [1]PETSC ERROR: Configure options: -with-cc=gcc --with-fc=gfortran
> --with-cxx=g++ --download-fblaslapack --download-mpich
> --with-scalar-type=complex --with-debugging=yes --download-parmetis
> --download-metis --download-hdf5 --download-scalapack --download-mumps -
> [1]PETSC ERROR: #1 MatCreateSeqAIJWithArrays() at
> /Documents/petsc-3.23.3/src/mat/impls/aij/seq/aij.c:5275
> [1]PETSC ERROR: #2 MatMPIAIJGetLocalMat() at
> /Documents/petsc-3.23.3/src/mat/impls/aij/mpi/mpiaij.c:5246
> [1]PETSC ERROR: #3 MatConvert_MPIAIJ_MPIDense() at
> /Documents/petsc-3.23.3/src/mat/impls/dense/mpi/mpidense.c:1393
> [1]PETSC ERROR: #4 MatConvert() at
> /Documents/petsc-3.23.3/src/mat/interface/matrix.c:4485
> [1]PETSC ERROR: #5 MatSchurComplementComputeExplicitOperator() at
> /Documents/petsc-3.23.3/src/ksp/ksp/utils/schurm/schurm.c:518
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!YH0t05h5r0tMJy6-pB5RzN_AwWN0iQY4UAOIQVHEfpxNqymQUvBLWIJYW1am1lI2_cmGA7muK6572PNFanx7$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!YH0t05h5r0tMJy6-pB5RzN_AwWN0iQY4UAOIQVHEfpxNqymQUvBLWIJYW1am1lI2_cmGA7muK6572OztM9Wn$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260119/8b000320/attachment-0001.html>
