[petsc-users] From explicit matrix using MatSchurComplementComputeExplicitOperator
Barry Smith bsmith at petsc.dev
Mon Jan 19 13:34:44 CST 2026
  Apparently. Just call ISSort() on the IS after forming it.
> On Jan 19, 2026, at 1:31 PM, neil liu <liufield at gmail.com> wrote:
> Dear Petsc developers and users,
> I am exploring Schur complement to reuse the inverse of A, for a block matrix [ A B; C D].
> Here A's size is much bigger than D. Therefore it is desirable to reuse the inverse of A. The code is listed below. It works well for 10k tetrahedra elements on 4 ranks . But it shows some error for a coarse mesh (260 tetrahedra cells) on 4 ranks.
> Do i have to sort isNonPort and isPort?
> Thanks a lot,
> Xiaodong
> MatCreateSubMatrix(A, isNonPort, isNonPort, MAT_INITIAL_MATRIX, &A11);
> MatCreateSubMatrix(A, isNonPort, isPorts, MAT_INITIAL_MATRIX, &A12);
> MatCreateSubMatrix(A, isPorts, isNonPort, MAT_INITIAL_MATRIX, &A21);
> MatCreateSubMatrix(A, isPorts, isPorts, MAT_INITIAL_MATRIX, &A22);
> Mat S;
> MatCreateSchurComplement(A11, A11, A12, A21, A22, &S);
> MatSchurComplementSetKSP(S, kspA11);
> Mat Sdense;
> MatSchurComplementComputeExplicitOperator(S, &Sdense);
> MatAssemblyBegin(Sdense, MAT_FINAL_ASSEMBLY);
> MatAssemblyEnd(Sdense, MAT_FINAL_ASSEMBLY);
> [1]PETSC ERROR: Argument out of range
> [1]PETSC ERROR: Column entry number 2 (actual column 0) in row 74 is not sorted
> [1]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!fXUit4Ume0pJ59Ww3NtLFk7wqiN1KvrU3kRM15Vb0xZ_2zuoO91UEuvSW3QPW4ieEuamNnC1uYRjn4xD126Bbzs$  <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!az-Ao1BxQdotvJlqia0i_iZ5sCx1AZNlDZwT2d1YUzJ4TE_esLV_bwZ-lyIBrsVlK3JJu36cOohpqoohAStoSQ$> for trouble shooting.
> [1]PETSC ERROR: PETSc Release Version 3.23.3, May 30, 2025
> [1]PETSC ERROR: ./app with 4 MPI process(es) and PETSC_ARCH arch-linux-c-debug
> [1]PETSC ERROR: Configure options: -with-cc=gcc --with-fc=gfortran --with-cxx=g++ --download-fblaslapack --download-mpich --with-scalar-type=complex --with-debugging=yes --download-parmetis --download-metis --download-hdf5 --download-scalapack --download-mumps -
> [1]PETSC ERROR: #1 MatCreateSeqAIJWithArrays() at /Documents/petsc-3.23.3/src/mat/impls/aij/seq/aij.c:5275
> [1]PETSC ERROR: #2 MatMPIAIJGetLocalMat() at /Documents/petsc-3.23.3/src/mat/impls/aij/mpi/mpiaij.c:5246
> [1]PETSC ERROR: #3 MatConvert_MPIAIJ_MPIDense() at /Documents/petsc-3.23.3/src/mat/impls/dense/mpi/mpidense.c:1393
> [1]PETSC ERROR: #4 MatConvert() at /Documents/petsc-3.23.3/src/mat/interface/matrix.c:4485
> [1]PETSC ERROR: #5 MatSchurComplementComputeExplicitOperator() at /Documents/petsc-3.23.3/src/ksp/ksp/utils/schurm/schurm.c:518
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260119/f42d2c6e/attachment.html>
