[petsc-users] SLEPSc and spectrum slicing
TARDIEU Nicolas nicolas.tardieu at edf.fr
Mon Jan 19 07:49:35 CST 2026
Thank you so much for your help Jose.
De : jroman at dsic.upv.es <jroman at dsic.upv.es>
Envoyé : lundi 19 janvier 2026 14:38
À : TARDIEU Nicolas <nicolas.tardieu at edf.fr>
Cc : petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Objet : Re: [petsc-users] SLEPSc and spectrum slicing
Expéditeur externe : Vérifier l’expéditeur avant de cliquer sur les liens ou pièces-jointes
External Sender : Check the sender before clicking any links or attachments
Ok, it is the right way to go.
I don't see any algebraic structure that can be exploited.
What you can try is compute eigenvalues in chunks. For instance, start with target=0 and compute nev=100. Then call the eigensolver again with a target moved to the right (close to the last computed eigenvalue) and passing the previously computed eigenvectors with EPSSetDeflationSpace(). Repeat this until you have all the wanted eigenvalues. This scheme will require a matrix factorization for each target, so overall cost may be higher, depending on convergence and the sparsity pattern. Spectrum slicing performs a similar scheme, but in an automated way and with guarantees that no eigenvalue is missed.
Jose
> El 19 ene 2026, a las 14:20, TARDIEU Nicolas <nicolas.tardieu at edf.fr> escribió:
> Thanks for your help Jose.
> B^{-1}*A  is not symmetric.
> I am currently using Krylov-Schur with  TARGET_MAGNITUDE set to 0 and shift-and-invert.
> Regards,
> Nicolas
> Nicolas Tardieu
> Ing PhD Computational Mechanics
> EDF - R&D Dpt ERMES
> PARIS-SACLAY, FRANCEDe : jroman at dsic.upv.es <jroman at dsic.upv.es>
> Envoyé : lundi 19 janvier 2026 12:38
> Is B^{-1}*A symmetric?
> Computing 0.01% of eigenvalues does not seem too much. For a problem size 10 million it's 1000 eigenvalues, which is manageable provided that you set a reasonable value of mpd, e.g., -eps_mpd 600. I don't think spectrum slicing is necessary.
> Are you seeing slow convergence? How are you currently solving the problem? Krylov-Schur with smallest_real? Or are you using shift-and-invert?
> Jose
> > El 19 ene 2026, a las 12:16, TARDIEU Nicolas <nicolas.tardieu at edf.fr> escribió:
> > Here are some details :
> >     • A and B are nonsymmetric
> >     • They both have a block structure
> >     • Since the underlying problem is conservative, the spectrum is strictly positive
> >     • I want to compute 1.e-2% eigenvalues with respect to the number of unknowns
> > Regards,Nicolas--Nicolas TardieuIng PhD Computational MechanicsEDF - R&D Dpt ERMESPARIS-SACLAY, FRANCEDe : jroman at dsic.upv.es <jroman at dsic.upv.es>
> > Envoyé : lundi 19 janvier 2026 11:28
> > To answer the question I would need more information.
> > - Is your B matrix symmetric? Is it symmetric positive-definite?
> > - Do your A and B matrices have a special block structure?
> > - Is your spectrum symmetric with respect to the origin?
> > - How many eigenvalues do you need? (in percentage)
> > Jose
> > > El 19 ene 2026, a las 11:17, TARDIEU Nicolas via petsc-users <petsc-users at mcs.anl.gov> escribió:
> > > Dear PETSc team,
> > > I am using SLEPc to solve a generalized non-symmetric eigenvalue problem. The underlying physical problem—coupled vibrations of an acoustic fluid enclosed in an elastic container—is actually conservative, so all eigenvalues and eigenvectors are real. The literature shows that a change of basis exists that makes the problem symmetric, but this transformation is computationally  expensive.
> > > Since I need to compute a large number of eigenvalues, I would like to use spectrum slicing, which is only available for symmetric matrices. I am not familiar with the internal workings of spectrum slicing in SLEPc, and I am wondering whether it could be possible to force the algorithm to handle these (pseudo-)non-symmetric matrices, given that the actual spectrum is real.
> > > Thanks,
> > > Regards,
> > > Nicolas Tardieu
> > > EDF - R&D Dpt ERMES
> > > Ce message et toutes les pièces jointes (ci-après le 'Message') sont établis à l'intention exclusive des destinataires et les informations qui y figurent sont strictement confidentielles. Toute utilisation de ce Message non conforme à sa destination, toute diffusion ou toute publication totale ou partielle, est interdite sauf autorisation expresse.
> > > Si vous n'êtes pas le destinataire de ce Message, il vous est interdit de le copier, de le faire suivre, de le divulguer ou d'en utiliser tout ou partie. Si vous avez reçu ce Message par erreur, merci de le supprimer de votre système, ainsi que toutes ses copies, et de n'en garder aucune trace sur quelque support que ce soit. Nous vous remercions également d'en avertir immédiatement l'expéditeur par retour du message.
> > > Il est impossible de garantir que les communications par messagerie électronique arrivent en temps utile, sont sécurisées ou dénuées de toute erreur ou virus.
> > > ____________________________________________________
> > > This message and any attachments (the 'Message') are intended solely for the addressees. The information contained in this Message is confidential. Any use of information contained in this Message not in accord with its purpose, any dissemination or disclosure, either whole or partial, is prohibited except formal approval.
> > > If you are not the addressee, you may not copy, forward, disclose or use any part of it. If you have received this message in error, please delete it and all copies from your system and notify the sender immediately by return message.
> > > E-mail communication cannot be guaranteed to be timely secure, error or virus-free.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260119/c93d1712/attachment-0001.html>
