[petsc-users] Having trouble with basic Fortran-PETSc interoperability
Matthew Knepley
knepley at gmail.com
Fri Jan 2 16:49:30 CST 2026
On Fri, Jan 2, 2026 at 2:48 PM Michael Whitten via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi PETSc mailing list users,
> I have managed to install PETSc and run some PETSc examples and little
> test codes of my own in Fortran. I am now trying to make PETSc work with my
> existing Fortran code. I have tried to build little test examples of the
> functionality that I can then incorporate into my larger code base.
> However, I am having trouble just passing vectors back and forth between
> PETSc and Fortran.
> I have attached a minimum semi-working example that can be compiled with
> the standard 'Makefile.user'. It throws an error when I try to copy the
> PETSc vector back to a Fortran vector using VecGetValues(). I get that it
> can only access values of the array on the local process but how do I fix
> this? Is this even the right approach?
No. You should just call VecGetArray(), to get back an F90 pointer to the
values. This is much more convenient.
> In the final implementation I want to be able to assemble my matrix and
> vector, convert them to PETSc data structures, use PETSc to solve, and then
> convert the solution vector back to Fortran and return. I want to be able
> to do this with both the linear and nonlinear solvers. It seems like this
> is what PETSc is, in part, built to do. Is this a reasonable expectation to
> achieve? Is this a reasonable use case for PETSc?
Yes, that should work getting the array directly.
Matt
> Thanks in advance for any help you can offer.
> best,
> Michael
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dmDhrQx1yGPd8y7YN9DUoj7jpohDJracq1zV5hiJ4GBq5ELNqsZZY7ymYloqOdThUhLu3seGNM2xrh36ooFV$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dmDhrQx1yGPd8y7YN9DUoj7jpohDJracq1zV5hiJ4GBq5ELNqsZZY7ymYloqOdThUhLu3seGNM2xrgy-5x4Z$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260102/e60566c6/attachment.html>
