[petsc-users] R: Fw: DG methods in PETSc
Matteo Leone
matteo4.leone at mail.polimi.it
Fri Feb 20 07:00:11 CST 2026
Yes it works,
but does not provide a correct solution and is stationary in time, I was just pointing this out.
I'll try to get as much as I can from the PetscFE object, PETSc provides already a lot of stuff, it cannot do everything.
Thanks for the support and time dedicated,
Matteo
Da: Mark Adams <mfadams at lbl.gov>
Inviato: giovedì 19 febbraio 2026 18:15
A: Matteo Leone <matteo4.leone at mail.polimi.it>
Cc: PETSc users list <petsc-users at mcs.anl.gov>
Oggetto: Re: [petsc-users] Fw: DG methods in PETSc
Just to avoid confusion with a convoluted thread, here is my response reposed:
This was a work in progress, but it does run: ./ex9 -dm_plex_box_faces 8,8 -dm_plex_dim 2 -dm_plex_simplex 0 -order 1 -ts_max_steps 10 -ts_monitor -velocity 1.0,0.5
I see that the Riemann solver is set:
PetscCall(PetscDSSetRiemannSolver(ds, 0, RiemannSolver_Advection));
I would not recommend using DG because there are no tests for it.
There are tests for PetscDSSetRiemannSolver that you could clone and replace the FE/FV construction in those with DG:
src/ts/tutorials/ex11.c: PetscCall(PetscDSSetRiemannSolver(prob, 0, user->model->physics->riemann));
src/ts/tutorials/ex18.c: if (user->velocityDist == VEL_ZERO) PetscCall(PetscDSSetRiemannSolver(prob, 1, riemann_advection));
src/ts/tutorials/ex18.c: else PetscCall(PetscDSSetRiemannSolver(prob, 1, riemann_coupled_advection));
If you get this far, you might want to look at internal examples (not tests) and clone these DG constructors:
src/dm/dt/fe/interface/fe.c: PetscFECreateBrokenElement - Create a discontinuous version of the input `PetscFE`
src/dm/dt/fe/interface/fe.c:PetscErrorCode PetscFECreateBrokenElement(PetscFE cgfe, PetscFE *dgfe)
src/dm/impls/plex/plexcreate.c: PetscCall(PetscFECreateBrokenElement(fe, &dgfe));
src/dm/interface/dmcoordinates.c: PetscCall(PetscFECreateBrokenElement(feLinear, &dgfe));
Sorry we do not have DG fully deployed yet.
Good luck,
On Thu, Feb 19, 2026 at 12:14 PM Matteo Leone via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Inviato da Outlook per Android<https://urldefense.us/v3/__https://aka.ms/AAb9ysg__;!!G_uCfscf7eWS!esCSra9pt1Q2VQtIwFRk5ds5BQ6-sbeQ66hUETSln-bCt8DbHI1HPvjOPOT6hyKlCgM8Xa4rlvZ6s9Gz4-MYSg9RvFGxWhhnjWc$>
From: Matteo Leone <matteo4.leone at mail.polimi.it<mailto:matteo4.leone at mail.polimi.it>>
Sent: Thursday, February 19, 2026 3:36:44 PM
To: Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>>
Subject: R: [petsc-users] DG methods in PETSc
Hello, I now have tested quite a bit the code, and I have some doubts.
Note I am quite new to PETSc.
I have modified a bit your code to test it and I tried to print from the functions to check if they were actually called with negative results.
The Riemann solver is never called and also the solution is just static in time.
I share the code. It's a bit modified and no more c but c++ (I do not know to write the csv file fom c, in case is a dealbreaker I'll try to give a look on how to do it).
(For reference I use PETSc 3.24.4 by means of nix, the nix flake is in the shared docs if you are used to it lmk).
There is also a small .py to handle the visualization (It was made by Claude code, but it just plots the results)
Hopefully we can go deep into this PETSc DG stuff.
Thanks in advace.
Matteo
Da: Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>>
Inviato: mercoledì 11 febbraio 2026 17:25
A: Matteo Leone <matteo4.leone at mail.polimi.it<mailto:matteo4.leone at mail.polimi.it>>; PETSc users list <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Oggetto: Re: [petsc-users] DG methods in PETSc
Great, and keep it on the list. Lots of people here to help!
On Wed, Feb 11, 2026 at 9:46 AM Matteo Leone <matteo4.leone at mail.polimi.it<mailto:matteo4.leone at mail.polimi.it>> wrote:
Wow thank you so much! I was almost hopeless, I'll deep dive into it and I'll give you a feedback.
Matteo
From: Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>>
Sent: Wednesday, February 11, 2026 3:38:30 PM
To: Matteo Leone <matteo4.leone at mail.polimi.it<mailto:matteo4.leone at mail.polimi.it>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Subject: Re: [petsc-users] DG methods in PETSc
DG (discontinuous Galerkin) is done with a "Broken" FE. Yikes I do not see a test.
Here is a test but it is not well verified.
On Tue, Feb 10, 2026 at 10:25 AM Matteo Leone via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hello, I already posted on Reddit but just to be sure I write even here.
First thanks for the job you do for PETSc, I have used it for several projects and is always nice.
I am writing cause I am getting mad trying to implement DG solver in PETSc, the target is the Euler equations, however I am failing even with just the simplest transport equation (u/t + u/x = 0). I was wondering if I am missing somenthing. I tried with the DSSetReimannSolver and DualSpaces, and more, but I keep failing, I tried also with LLMs, but seems like there is no DG code with PETSc on the web, however I see many papers that do it.
I was wondering if I am maybe missing something out or what.
For reference I use PETSc 3.24.3 by means of nix.
Thanks in advance, cheers.
Matteo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260220/f26948b3/attachment-0001.html>
