[petsc-users] Is use of Mirror Boundary with Box Stencil supported for 2D?
Macneice, Peter J. (GSFC-6740)
peter.j.macneice at nasa.gov
Thu Feb 19 20:08:51 CST 2026
>From my searching of the documentation, it looks to me as though this combination should work.
However for my modified version of the ex66.c tutorial code, I get the error message below.
Is this really not yet supported?
Regards
Peter MacNeice
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: No support for this operation for this object type
[0]PETSC ERROR: Mirror boundary and box stencil
[0]PETSC ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc!
[0]PETSC ERROR: Option left: name:-dm_view (no value) source: command line
[0]PETSC ERROR: Option left: name:-ksp_monitor (no value) source: command line
[0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!boqIOhIgncdTr1z60slIrCjusZEY0_bk-qkGbrlrmiepTiBAvCwW8s9c1IQ6vyT4fOeshVO3Bsu1F5HuERiBGRsq1r2LJ1zBtrM$ for trouble shooting.
[0]PETSC ERROR: PETSc Release Version 3.24.3, Jan 01, 2026
[0]PETSC ERROR: ex66_9pt with 1 MPI process(es) and PETSC_ARCH arch-darwin-c-debug on gs67-5186361 by pmacneic Thu Feb 19 21:03:16 2026
[0]PETSC ERROR: Configure options: --with-mpi-dir=/Users/pmacneic/mpich-install-3.3-gcc15 --force
[0]PETSC ERROR: #1 DMSetUp_DA_2D() at /Users/pmacneic/petsc-3.24.3/src/dm/impls/da/da2.c:212
[0]PETSC ERROR: #2 DMSetUp_DA() at /Users/pmacneic/petsc-3.24.3/src/dm/impls/da/dareg.c:17
[0]PETSC ERROR: #3 DMSetUp() at /Users/pmacneic/petsc-3.24.3/src/dm/interface/dm.c:807
[0]PETSC ERROR: #4 main() at ex66_9pt.c:77
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -dm_view (source: command line)
[0]PETSC ERROR: -ksp_monitor (source: command line)
[0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_SELF, 56) - process 0
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260220/813efebb/attachment.html>
