[petsc-users] Port existing GMRES+ILU(0) implementation to GPU
feng wang
snailsoar at hotmail.com
Wed Feb 11 04:47:51 CST 2026
Hi Junchao,
Thanks for your reply. Probably I did not phrase it in a clear way.
I am using openACC to port the CFD code to the GPU, so the CPU and the GPU version essentially share the same source code. For the original CPU version, it uses Jacobi (hand-coded) or GMRES+ILU(0) (with pestc) to solve the sparse linear system.
The current GPU version of the code only port the Jacobi solver to the GPU, now I want to port GMRES+ILU(0) to the GPU. What changes do I need to make to the existing CPU version of GMRES+ILU(0) to achieve this goal?
BTW: For performance the GPU version of the CFD code has minimum communication between the CPU and GPU, so for Ax=b, A, x and b are created in the GPU directly
Feng
Sent: 11 February 2026 3:00
To: feng wang <snailsoar at hotmail.com>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>; Barry Smith <bsmith at petsc.dev>
Subject: Re: [petsc-users] Port existing GMRES+ILU(0) implementation to GPU
Sorry, I don't understand your question. What blocks you from running your GMRES+ILU(0) on GPUs? I Cc'ed Barry, who knows better about the algorithms.
--Junchao Zhang
On Tue, Feb 10, 2026 at 3:57 PM feng wang <snailsoar at hotmail.com<mailto:snailsoar at hotmail.com>> wrote:
Hi Junchao,
I have managed to configure Petsc for GPU, also managed to run ksp/ex15 using -mat_type aijcusparse -vec_type cuda. It seems runs much faster compared to the scenario if I don't use " -mat_type aijcusparse -vec_type cuda". so I believe it runs okay for GPUs.
I have an existing CFD code that runs natively on GPUs. so all the data is offloaded to GPU at the beginning and some data are copied back to the cpu at the very end. It got a hand-coded Newton-Jacobi that runs in GPUs for the implicit solver. My question is: my code also has a GMRES+ILU(0) implemented with Petsc but it only runs on cpus (which I implemented a few years ago). How can I replace the existing Newton-Jacobi (which runs in GPUs) with GMRES+ILU(0) which should run in GPUs. Could you please give some advice?
Feng
From: Junchao Zhang <junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com>>
Sent: 09 February 2026 23:18
To: feng wang <snailsoar at hotmail.com<mailto:snailsoar at hotmail.com>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Hi Feng,
At the first step, you don't need to change your CPU implementation. Then do profiling to see where it is worth putting your effort. Maybe you need to assemble your matrices and vectors on GPUs too, but decide that at a later stage.
Thanks!
--Junchao Zhang
On Mon, Feb 9, 2026 at 4:31 PM feng wang <snailsoar at hotmail.com<mailto:snailsoar at hotmail.com>> wrote:
Hi Junchao,
Many thanks for your reply.
This is great! Do I need to change anything for my current CPU implementation? or I just link to a version of Petsc that is configured with cuda and make sure the necessary data are copied to the "device", then Petsc will do the rest magic for me?
Feng
Sent: 09 February 2026 1:55
Hello Feng,
It is possible to run GMRES with ILU(0) on GPUs. You may need to configure PETSc with CUDA (--with-cuda --with-cudac=nvcc) or Kokkos (with extra --download-kokkos --download-kokkos-kernels). Then run with -mat_type {aijcusparse or aijkokkos} -vec_type {cuda or kokkos}.
But triangular solve is not GPU friendly and the performance might be poor. But you should try it, I think.
Thanks!
--Junchao Zhang
On Sun, Feb 8, 2026 at 5:46 PM feng wang <snailsoar at hotmail.com<mailto:snailsoar at hotmail.com>> wrote:
Dear All,
I have an existing implementation of GMRES with ILU(0), it works well for cpu now. I went through the Petsc documentation, it seems Petsc has some support for GPUs. is it possible for me to run GMRES with ILU(0) in GPUs?
Many thanks for your help in advance,
Feng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260211/19f675de/attachment.html>
