[petsc-users] Switching between sections of the same DM
Aldo Bonfiglioli
aldo.bonfiglioli at unibas.it
Mon Feb 9 06:24:27 CST 2026
Hi there,
I am trying to switch btw two different sections (section_l(1:2))
defined on the same DM (one section for the dependent variable, the
other for their gradient)
> ! dependent variables and their nodal gradient
> PetscCall(DMSetLocalSection(dm, section_l(1), ierr)) ! dependent
> variables
> PetscCall(DMGetLocalVector(dm, localu, ierr)) ! dependent variables
> PetscCall(DMGlobaltoLocal(dm, u, INSERT_VALUES, localu, ierr))
> PetscCall(VecSet(gradu, 0.d0, ierr))
> PetscCall(DMSetLocalSection(dm, section_l(2), ierr)) ! gradient of
> the dependent variables
> PetscCall(DMGetLocalVector(dm, localdu, ierr)) ! gradient of the
> dependent variables
> PetscCall(VecSet(localdu, 0.d0, ierr))
> callinnerloop(dm, localu, localdu, section_l, ierr)
subroutine innerloop is supposed to do work on both Vecs.
When trying to do so, I get the following error:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: Clearing DM of local vectors that has a local vector
> obtained with DMGetLocalVector()
as if two sections living simultaneously on the same DM are not allowed.
Should I instead clone the DM and create the "second" section of the clone?
Aldo
Dr. Aldo Bonfiglioli
Associate professor of Fluid Mechanics
Dipartimento di Ingegneria
Universita' della Basilicata
V.le dell'Ateneo Lucano, 10 85100 Potenza ITALY
tel:+39.0971.205203 fax:+39.0971.205215
web:https://urldefense.us/v3/__http://docenti.unibas.it/site/home/docente.html?m=002423__;!!G_uCfscf7eWS!YVPmxuMFuutpshSi89LXW-8W6oF1lauFcuN2HzqwcvecXbGkhDoRlhVqyIdHvFHEXN7_zUPSCbdoeElWRBtO1fQ_1q-v4pzF0QU$
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260209/071f1f5a/attachment-0001.html>
