[petsc-users] Question about Pseudo Time Stepping
Aldo Bonfiglioli aldo.bonfiglioli at unibas.it
Mon Apr 20 08:35:54 CDT 2026
On 8/31/25 05:18, Barry Smith wrote:
>   I always like a challenge.
>   The MR https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/8675__;!!G_uCfscf7eWS!fSXpVkczcuYe90b4FecJoyBEJfrf0l19hyR_OWi9XPSUnhoSQyzSjcwtb3wgdBcTWxs5uVJnWLeGe-8xyu-XTRFBhS9R13eNP5U$  should
> eliminate both redundant TSComputeRHSFunction() calls in your code and
> thus decrease its run time.
>  Thanks for bringing the performance bug to our attention
>   Barry
>> On Aug 30, 2025, at 5:42 PM, Aldo Bonfiglioli
>> <aldo.bonfiglioli at unibas.it> wrote:
>> Barry,
>> thank you for the update.
>> Aldo
>> *Aldo Bonfiglioli*
>> Professore associato di Fluidodinamica settore scientifico
>> disciplinare IIND-01/F
>> Dipartimento di Ingegneria
>> Viale dell'Ateneo Lucano, 10 85100 Potenza
>> Tel: 0971.205203
>> Il ven 29 ago 2025, 20:52 Barry Smith <barryfsmith at icloud.com> ha
>> scritto:
>>       Aldo,
>>         I understand the situation you are facing.
>>         With pseudo-continuation, when you provide an RHS function,
>>     SNES is computing udot -
>>     F(u). Inside the SNESSolve(), specifically
>>     in TSComputeIFunction(), with the lines
>>         if (!ts->ops->ifunction) {
>>           ierr = TSComputeRHSFunction(ts,t,X,Y);CHKERRQ(ierr);
>>           ierr = VecAYPX(Y,-1,Xdot);CHKERRQ(ierr);
>>     But for the original system, we care about the norm for F(u). So
>>     in TSStep_Pseudo(), after the nonlinear solve
>>     there is the line
>>         pseudo->fnorm = -1; /* The current norm is no longer valid,
>>     monitor must recompute it. */
>>     and further down
>>       if (pseudo->fnorm < 0) {
>>     PetscCall(VecZeroEntries(pseudo->xdot));
>>         PetscCall(TSComputeIFunction(ts, ts->ptime, ts->vec_sol,
>>     pseudo->xdot, pseudo->func, PETSC_FALSE));
>>         PetscCall(VecNorm(pseudo->func, NORM_2, &pseudo->fnorm));
>>     this norm is needed to determine of the nonlinear system has
>>     converged satisfactory (or if more pseudo time steps are needed).
>>     Hence, your FormRHSFunction gets called twice with identical input.
>>     To make matters even worse your FormRHSFunction is actually being
>>     called THREE times with identical input. Because at the start of
>>     TSStep_Pseudo() it calls TSPseudoComputeTimeStep(ts,
>>     &next_time_step) which by default uses TSPseudoTimeStepDefault()
>>     which has the same chunk of code
>>     And the same norm is also recomputed.
>>     Now the diff
>>     diff --git a/src/ts/impls/pseudo/posindep.c
>>     b/src/ts/impls/pseudo/posindep.c
>>     index 7c013435f98..813a28311e7 100644
>>     --- a/src/ts/impls/pseudo/posindep.c
>>     +++ b/src/ts/impls/pseudo/posindep.c
>>     @@ -660,9 +660,11 @@ PetscErrorCode TSPseudoTimeStepDefault(TS
>>     ts, PetscReal *newdt, void *dtctx)
>>        PetscReal  inc    = pseudo->dt_increment;
>>        PetscFunctionBegin;
>>     -  PetscCall(VecZeroEntries(pseudo->xdot));
>>     -  PetscCall(TSComputeIFunction(ts, ts->ptime, ts->vec_sol,
>>     -  PetscCall(VecNorm(pseudo->func, NORM_2, &pseudo->fnorm));
>>     +  if (pseudo->fnorm < 0.0) {
>>     +  PetscCall(VecZeroEntries(pseudo->xdot));
>>     +    PetscCall(TSComputeIFunction(ts, ts->ptime, ts->vec_sol,
>>     +    PetscCall(VecNorm(pseudo->func, NORM_2, &pseudo->fnorm));
>>        if (pseudo->fnorm_initial < 0) {
>>          /* first time through so compute initial function norm */
>>          pseudo->fnorm_initial  = pseudo->fnorm
>>     will prevent the THIRD computation of the same function
>>     evaluation. So this is a good optimization
>>     But eliminating the second computation is not so trivial. To
>>     review, deep inside the TS code there is
>>     VecAYPX(Y,-1,Xdot);
>>     This code knows nothing about TSPPseudo etc.
>>     Then later in the Pseudo code
>>      again calls TSComputeRHSFunction(ts,t,X,Y); with the same X.
>>      (since Xdot is not used directly by TSComputeRHSFunction()).
>>     Now if all the code was custom for Pseudo we could simply put in
>>     a line
>>     VecNorm(Y,NORM_2, &pseudo->fnorm)
>>     VecAYPX(Y,-1,Xdot);
>>     into TSComputeIFunction() and have the norm available later for
>>     pseudo.
>>     It is not clear that there is any definitive benefit for pseudo
>>     to utilize the TS framework. It possibly gets some code reuse
>>     from TS but at the cost of extra code that won't be needed if
>>     written directly. Plus this performance hit.
>>     Anyways I will make a merge request to remove the third redundant
>>     computation of FormRHSFunction but will await input from others
>>     on if anything else could be done to remove the inefficiency.
>>     Thanks for reporting this challenging problem.
>>      Barry
>>     Note: I don't think providing the Jacobian improves the
>>     efficiency, it is just better at hiding the redundant computation.
>>>     On Aug 26, 2025, at 4:21 AM, Aldo Bonfiglioli
>>>     Hi there,
>>>     I am using -ts_type pseudo to find steady solutions of the
>>>     Euler/NS PDEs.
>>>     It looks like FormRHSFunction is called twice with the exactly
>>>     same value of the dependent variable (u)
>>>     before invoking TSRHSJacobianFn and then solving the linear
>>>     system with KSP (u is then updated)
>>>>     1 TS dt 0.141197 time 0.141197
>>>>     Calling FormRHSFunction; ||u|| =    60.489405479528003
>>>>            463.15635675129079        62.813532026019146
>>>>            5.9789502719351155
>>>>            463.1563567512907962.8135320260191465.9789502719351155
>>>>     Calling TSRHSJacobianFn with ||u|| =    60.489405479528003
>>>>            5.9789502719351155
>>>>          Linear solve converged due to CONVERGED_RTOL iterations 9
>>>>        60.489405476878737463.1563567560218662.8135320316169655.9789502710519811
>>>>     2 TS dt 0.155917 time 0.297115
>>>     Why is it so? Am I possibly misusing (or missing) some options?
>>>     months a
>>>     My .petscrc file is attached.
>>>     Thank you,
>>>     Aldo
>>>     Dr. Aldo Bonfiglioli
>>>     Associate professor of Fluid Mechanics
>>>     Universita' della Basilicata
>>>     V.ledell'Ateneo Lucano, 10 85100 Potenza ITALY <https://urldefense.us/v3/__https://www.google.com/maps/search/dell'Ateneo*Lucano,*10*85100*Potenza*ITALY?entry=gmail&source=g__;KysrKys!!G_uCfscf7eWS!fSXpVkczcuYe90b4FecJoyBEJfrf0l19hyR_OWi9XPSUnhoSQyzSjcwtb3wgdBcTWxs5uVJnWLeGe-8xyu-XTRFBhS9RHmXqJwA$ >
>>>     tel:+39.0971.205203 fax:+39.0971.205215
>>>     web:https://urldefense.us/v3/__http://docenti.unibas.it/site/home/docente.html?m=002423__;!!G_uCfscf7eWS!fSXpVkczcuYe90b4FecJoyBEJfrf0l19hyR_OWi9XPSUnhoSQyzSjcwtb3wgdBcTWxs5uVJnWLeGe-8xyu-XTRFBhS9RCdKy2vs$  <https://urldefense.us/v3/__http://docenti.unibas.it/site/home/docente.html?m=002423__;!!G_uCfscf7eWS!ci_aySHdF2Qx_B-37IOzELFDtcQRthJ2NItK-JNbfXB0M2_21B_z97WIfjxZUyKCVRRhd1mzL6b-rnCed_i8LLA56JvFdz7JBrw$>
Dear all,
I am sorry to bring back an issue raised months ago, but I still see
what looks a redundant (there where three, now seem to be two)
evaluation of f(u) in -ts_type pseudo.
I modified petsc/src/ts/tutorials/ex1.c (here enclosed) to print the
norm of the unknown each time FormFunction is invoked.
> timestep 0 time 0. ||u|| norm 0.989743
> TS 0 dt 0.125 time 0. fnorm 0.207564
> timestep 0 time 0.125 ||u|| norm 0.989743
> timestep 0 time 0. ||u|| norm 1.01305<--------------
> TS 1 dt 0.1375 time 0.125 fnorm 0.186587|
> timestep 1 time 0.2625 ||u|| norm 1.01305<----------
> timestep 1 time 0.125 ||u|| norm 1.0359<---------------
> TS 2 dt 0.169687 time 0.2625 fnorm 0.166314|
> timestep 2 time 0.432187 ||u|| norm 1.0359<------------
> timestep 2 time 0.2625 ||u|| norm 1.06045<---------------
> TS 3 dt 0.214308 time 0.432187 fnorm 0.144855|
> timestep 3 time 0.646495 ||u|| norm 1.06045<-------------
> timestep 3 time 0.432187 ||u|| norm 1.08663
> TS 4 dt 0.279101 time 0.646495 fnorm 0.12235
> timestep 4 time 0.925595 ||u|| norm 1.08663
> timestep 4 time 0.646495 ||u|| norm 1.11421
> TS 5 dt 0.379191 time 0.925595 fnorm 0.0990599
> timestep 5 time 1.30479 ||u|| norm 1.11421
> timestep 5 time 0.925595 ||u|| norm 1.14273
> TS 6 dt 0.547645 time 1.30479 fnorm 0.0754483
> timestep 6 time 1.85243 ||u|| norm 1.14273
> timestep 6 time 1.30479 ||u|| norm 1.17125
> TS 7 dt 0.86876 time 1.85243 fnorm 0.0523169
> timestep 7 time 2.72119 ||u|| norm 1.17125
> timestep 7 time 1.85243 ||u|| norm 1.19803
> TS 8 dt 1.61069 time 2.72119 fnorm 0.03104
ex1 has been run using -ts_monitor_pseudo -ts_type pseudo
Aldo
V.le dell'Ateneo Lucano, 10 85100 Potenza ITALY
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260420/8e6ff74e/attachment-0001.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260420/8e6ff74e/attachment-0001.bin>
