[petsc-users] setting correct tolerances for MG smoother CG at the finest level
Moral Sanchez, Elena Elena.Moral.Sanchez at ipp.mpg.de
Mon Sep 29 10:12:23 CDT 2025
This is the output:
    Residual norms for mg_levels_1_ solve.
    0 KSP Residual norm 2.249726733143e+00
    1 KSP Residual norm 1.433120400946e+00
    2 KSP Residual norm 1.169262560123e+00
    3 KSP Residual norm 1.323528716607e+00
    4 KSP Residual norm 5.006323254234e-01
    5 KSP Residual norm 3.569836784785e-01
    6 KSP Residual norm 2.493182937513e-01
    7 KSP Residual norm 3.038202502298e-01
    8 KSP Residual norm 2.780214194402e-01
    9 KSP Residual norm 1.676826341491e-01
   10 KSP Residual norm 1.209985378713e-01
   11 KSP Residual norm 9.445076689969e-02
   12 KSP Residual norm 8.308555284580e-02
   13 KSP Residual norm 5.472865592585e-02
   14 KSP Residual norm 4.357870564398e-02
   15 KSP Residual norm 5.079681292439e-02
    Linear mg_levels_1_ solve converged due to CONVERGED_ITS iterations 15
    0 KSP Residual norm 5.079681292439e-02
    1 KSP Residual norm 2.934938644003e-02
    2 KSP Residual norm 3.257065831294e-02
    3 KSP Residual norm 4.143063876867e-02
    4 KSP Residual norm 4.822471409489e-02
    5 KSP Residual norm 3.197538246153e-02
    6 KSP Residual norm 3.461217019835e-02
    7 KSP Residual norm 3.410193775327e-02
    8 KSP Residual norm 4.690424294464e-02
    9 KSP Residual norm 3.366148892800e-02
   10 KSP Residual norm 4.068015727689e-02
   11 KSP Residual norm 2.658836123104e-02
   12 KSP Residual norm 2.826244186003e-02
   13 KSP Residual norm 2.981793619508e-02
   14 KSP Residual norm 3.525455091450e-02
   15 KSP Residual norm 2.331539121838e-02
    0 KSP Residual norm 2.421498365806e-02
    1 KSP Residual norm 1.761072112362e-02
    2 KSP Residual norm 1.400842489042e-02
    3 KSP Residual norm 1.419665483348e-02
    4 KSP Residual norm 1.617590701667e-02
    5 KSP Residual norm 1.354824081005e-02
    6 KSP Residual norm 1.387252917475e-02
    7 KSP Residual norm 1.514043102087e-02
    8 KSP Residual norm 1.275811124745e-02
    9 KSP Residual norm 1.241039155981e-02
   10 KSP Residual norm 9.585207801652e-03
   11 KSP Residual norm 9.022641230732e-03
   12 KSP Residual norm 1.187709152046e-02
   13 KSP Residual norm 1.084880112494e-02
   14 KSP Residual norm 8.194750346781e-03
   15 KSP Residual norm 7.614246199165e-03
    0 KSP Residual norm 7.614246199165e-03
    1 KSP Residual norm 5.620014684145e-03
    2 KSP Residual norm 6.643368363907e-03
    3 KSP Residual norm 8.708642393659e-03
    4 KSP Residual norm 6.401852907459e-03
    5 KSP Residual norm 7.230576215262e-03
    6 KSP Residual norm 6.204081601285e-03
    7 KSP Residual norm 7.038656665944e-03
    8 KSP Residual norm 7.194079694050e-03
    9 KSP Residual norm 6.353576889135e-03
   10 KSP Residual norm 7.313589502731e-03
   11 KSP Residual norm 6.643320423193e-03
   12 KSP Residual norm 7.235443182108e-03
   13 KSP Residual norm 4.971292307201e-03
   14 KSP Residual norm 5.357933842147e-03
   15 KSP Residual norm 5.841682994497e-03
Sent: 29 September 2025 15:56:33
To: Moral Sanchez, Elena
Cc: Mark Adams; petsc-users
Subject: Re: [petsc-users] setting correct tolerances for MG smoother CG at the finest level
  I asked you to run with
 -ksp_monitor -mg_levels_ksp_monitor -ksp_converged_reason -mg_levels_ksp_converged_reason
you chose not to, delaying the process of understanding what is happening.
  Please run with those options and send the output. My guess is that you are computing the "residual norms" in your own monitor code, and it is doing so differently than what PETSc does, thus resulting in the appearance of a sufficiently small residual norm, whereas PETSc may not have calculated something that small.
Barry
On Sep 29, 2025, at 8:39 AM, Moral Sanchez, Elena <Elena.Moral.Sanchez at ipp.mpg.de> wrote:
Thanks for the hint. I agree that the coarse solve should be much more "accurate". However, for the moment I am just trying to understand what the MG is doing exactly.
I am puzzled to see that the fine grid smoother ("lvl 0") does not stop when the residual becomes less than 1e-1. It should converge due to the atol.
From: Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>>
Sent: 29 September 2025 14:20:56
Cc: Barry Smith; petsc-users
Oh I see the coarse grid solver in your full solver output now.
You still want an accurate coarse grid solve. Usually (the default in GAMG) you use a direct solver on one process, and cousin until the coarse grid is small enough to make that cheap.
On Mon, Sep 29, 2025 at 8:07 AM Moral Sanchez, Elena <Elena.Moral.Sanchez at ipp.mpg.de<mailto:Elena.Moral.Sanchez at ipp.mpg.de>> wrote:
Hi, I doubled the system size and changed the tolerances just to show a better example of the problem. This is the output of the callbacks in the first iteration:
    CG Iter 0/1 | res = 2.25e+00/1.00e-09 | 0.1 s
        MG lvl 0 (s=884): CG Iter 0/15 | res = 2.25e+00/1.00e-01 | 0.3 s
        MG lvl 0 (s=884): CG Iter 1/15 | res = 1.43e+00/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 2/15 | res = 1.17e+00/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 3/15 | res = 1.32e+00/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 4/15 | res = 5.01e-01/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 5/15 | res = 3.57e-01/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 6/15 | res = 2.49e-01/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 7/15 | res = 3.04e-01/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 8/15 | res = 2.78e-01/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 9/15 | res = 1.68e-01/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 10/15 | res = 1.21e-01/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 11/15 | res = 9.45e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 12/15 | res = 8.31e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 13/15 | res = 5.47e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 14/15 | res = 4.36e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 15/15 | res = 5.08e-02/1.00e-01 | 0.1 s
        ConvergedReason MG lvl 0: 4
        MG lvl -1 (s=524): CG Iter 0/15 | res = 8.15e-02/1.00e-01 | 3.0 s
        ConvergedReason MG lvl -1: 3
        MG lvl 0 (s=884): CG Iter 0/15 | res = 5.08e-02/1.00e-01 | 0.3 s
        MG lvl 0 (s=884): CG Iter 1/15 | res = 2.93e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 2/15 | res = 3.26e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 3/15 | res = 4.14e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 4/15 | res = 4.82e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 5/15 | res = 3.20e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 6/15 | res = 3.46e-02/1.00e-01 | 0.3 s
        MG lvl 0 (s=884): CG Iter 7/15 | res = 3.41e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 8/15 | res = 4.69e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 9/15 | res = 3.37e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 10/15 | res = 4.07e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 11/15 | res = 2.66e-02/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 12/15 | res = 2.83e-02/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 13/15 | res = 2.98e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 14/15 | res = 3.53e-02/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 15/15 | res = 2.33e-02/1.00e-01 | 0.2 s
    CG Iter 1/1 | res = 2.42e-02/1.00e-09 | 5.6 s
        MG lvl 0 (s=884): CG Iter 0/15 | res = 2.42e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 1/15 | res = 1.76e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 2/15 | res = 1.40e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 3/15 | res = 1.42e-02/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 4/15 | res = 1.62e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 5/15 | res = 1.35e-02/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 6/15 | res = 1.39e-02/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 7/15 | res = 1.51e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 8/15 | res = 1.28e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 9/15 | res = 1.24e-02/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 10/15 | res = 9.59e-03/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 11/15 | res = 9.02e-03/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 12/15 | res = 1.19e-02/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 13/15 | res = 1.08e-02/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 14/15 | res = 8.19e-03/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 15/15 | res = 7.61e-03/1.00e-01 | 0.1 s
        MG lvl -1 (s=524): CG Iter 0/15 | res = 1.38e-02/1.00e-01 | 5.2 s
        MG lvl 0 (s=884): CG Iter 0/15 | res = 7.61e-03/1.00e-01 | 0.2 s
        MG lvl 0 (s=884): CG Iter 1/15 | res = 5.62e-03/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 2/15 | res = 6.64e-03/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 3/15 | res = 8.71e-03/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 4/15 | res = 6.40e-03/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 5/15 | res = 7.23e-03/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 6/15 | res = 6.20e-03/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 7/15 | res = 7.04e-03/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 8/15 | res = 7.19e-03/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 9/15 | res = 6.35e-03/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 10/15 | res = 7.31e-03/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 11/15 | res = 6.64e-03/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 12/15 | res = 7.24e-03/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 13/15 | res = 4.97e-03/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 14/15 | res = 5.36e-03/1.00e-01 | 0.1 s
        MG lvl 0 (s=884): CG Iter 15/15 | res = 5.84e-03/1.00e-01 | 0.1 s
    CG ConvergedReason: -3
For completeness, I add here the -ksp_view of the whole solver:
    KSP Object: 1 MPI process
      type: cg
        variant HERMITIAN
      maximum iterations=1, nonzero initial guess
      tolerances: relative=1e-08, absolute=1e-09, divergence=10000.
      left preconditioning
      using UNPRECONDITIONED norm type for convergence test
    PC Object: 1 MPI process
      type: mg
        type is MULTIPLICATIVE, levels=2 cycles=v
          Cycles per PCApply=1
          Not using Galerkin computed coarse grid matrices
      Coarse grid solver -- level 0 -------------------------------
        KSP Object: (mg_coarse_) 1 MPI process
          type: cg
        variant HERMITIAN
          maximum iterations=15, nonzero initial guess
          tolerances: relative=0.1, absolute=0.1, divergence=1e+30
        PC Object: (mg_coarse_) 1 MPI process
          type: none
          linear system matrix = precond matrix:
          Mat Object: 1 MPI process
        type: python
        rows=524, cols=524
            Python: Solver_petsc.LeastSquaresOperator
      Down solver (pre-smoother) on level 1 -------------------------------
        KSP Object: (mg_levels_1_) 1 MPI process
          type: cg
        variant HERMITIAN
        PC Object: (mg_levels_1_) 1 MPI process
          type: none
        type: python
        rows=884, cols=884
      Up solver (post-smoother) same as down solver (pre-smoother)
        type: python
        rows=884, cols=884
Regarding Mark's Email: What do you mean with "the whole solver doesn't have a coarse grid"? I am using my own Restriction and Interpolation operators.
Thanks for the help,
Elena
Sent: 28 September 2025 20:13:54
To: Barry Smith
Cc: Moral Sanchez, Elena; petsc-users
Not sure why your "whole"solver does not have a coarse grid but this is wrong:
  type: cg
    variant HERMITIAN
  maximum iterations=100, initial guess is zero
The coarse grid has to be accurate. The defaults are a good place to start: max_it=10.000, rtol=1e-5, atol=1e-30 (ish)
On Fri, Sep 26, 2025 at 3:21 PM Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>> wrote:
  Looks reasonable. Send the output running with
On Sep 26, 2025, at 1:19 PM, Moral Sanchez, Elena <Elena.Moral.Sanchez at ipp.mpg.de<mailto:Elena.Moral.Sanchez at ipp.mpg.de>> wrote:
Dear Barry,
This is -ksp_view for the smoother at the finest level:
  type: cg
    variant HERMITIAN
  maximum iterations=10, nonzero initial guess
  type: none
    type: python
    rows=524, cols=524
And at the coarsest level:
  type: cg
    variant HERMITIAN
  type: none
    type: python
    rows=344, cols=344
And for the whole solver:
  type: cg
    variant HERMITIAN
  maximum iterations=100, nonzero initial guess
  type: mg
      type: cg
        variant HERMITIAN
      type: none
        type: python
        rows=344, cols=344
      type: cg
        variant HERMITIAN
      type: none
        type: python
        rows=524, cols=524
    type: python
    rows=524, cols=524
Best,
Elena
From: Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>>
Sent: 26 September 2025 19:05:02
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
Send the output using -ksp_view
Normally one uses a fixed number of iterations of smoothing  on level with multigrid rather than a tolerance, but yes PETSc should respect such a tolerance.
Barry
On Sep 26, 2025, at 12:49 PM, Moral Sanchez, Elena <Elena.Moral.Sanchez at ipp.mpg.de<mailto:Elena.Moral.Sanchez at ipp.mpg.de>> wrote:
I am using multigrid (multiplicative) as a preconditioner with a V-cycle of two levels. At each level, I am setting CG as the smoother with certain tolerance.
What I observe is that in the finest level the CG continues iterating after the residual norm reaches the tolerance (atol) and it only stops when reaching the maximum number of iterations at that level. At the coarsest level this does not occur and the CG stops when the tolerance is reached.
I double-checked that the smoother at the finest level has the right tolerance. And I am using a Monitor function to track the residual.
Do you know how to make the smoother at the finest level stop when reaching the tolerance?
Cheers,
Elena.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250929/f969e13e/attachment-0001.html>
